Good Offset Ratcheting Screwdriver?
Kenwc
You've never led me wrong yet...so thought I'd ask which of the offset (90 deg) ratcheting screwdrivers are the the bee's knee's?
I have a Crafstman and don't like it and don't need Snap-On's prices so there ya have it...have to work somewhere in between there.
Thanks
Ken
Bolster
Mexifornia
My favorite is the chapman set; bits stick through and allows you to spin the knurling. A detent keeps the bits firmly in place, and they can't push through due to a boss on each bit. USA made and very affordable, but you won't be calling your friends to talk about how beautiful it is.
Part of the Chapman charm is they have their own proprietary bit system which is, how do I say it, "closely spaced." If you need a bit slightly larger or smaller, they will make it. Sort of a gunsmith's tool, where you have to have very precise fit of the bits so the screws don't look cammy. And their standard bits are parallel ground not wedge, for the ultimate in "screw damage control." Very nice, and you can buy direct from Chapman in a wide array of selections.
http://www.brownells.com/.aspx/sid=11210/pid=4980/sku/Screwdriver_Set?source=CJ
I also own these SO/BP ones, they're OK but the magnets are a little weak and bit retention is nothing like the chapmans. They do allow you to spin the wheel as there is knurling for your thumb. These are basically tiny ratchets in 1/4" hex drive.
http://buy1.snapon.com/catalog/item.asp?item_ID=75044&group_ID=11620
There is also the SO or GW 1/4 bit driver you can put on a 1/4 ratchet, that's a good option too, if you have the room. Inexpensive if you get the gearwrench one, but why can't I find the 1/4" drive one, all I see is 3/8:
http://www.amazon.com/dp/B002YKFO0A/?tag=atomicindus08-20
And you also have the bit holder option for the gearwrench which seems it would be the ultimate in low profile.
http://www.amazon.com/gp/product/B000HBAI1I/?tag=atomicindus08-20
My favorite so far is the Chapman, but it's a little higher profile than some of the others. I don't own the gearwrench screwdriver bit adapters yet, but will soon.
DHCrocks
Hawaii
I have the gearwrench micro driver set and it's all I could ask for. I've had about 3 different offset drivers in the past and this is by far the best. It has a smooth fine tooth ratcheting action, same as the wrenches. it also has a knurled ring which you can use to finger spin the bit. A detent ring holds the bits in place so they don't fall out which is great in tight locations.
Monte
Germany
i like this miniature bit ratchet:
Same as the Gearwrench but with handle.
K
Kenwc
Thanks for the replies....I like the Chapman set and even the SO handle.
wreckercologist
cyber-tool hell
I've got the Craftsman three piece set. They're not that great........and even look just like my coworkers BluePoint (older version). They also carry the same date codes as the BP if you slide the grip off. I know the OP said no Snap-on, but this will be my next offset screwdriver:
http://buy1.snapon.com/catalog/item...group_ID=21944&store=snapon-store&dir=catalog
Coupled with this:
A little more money for sure, but very nice.
:beer:
jim faston
All of the 1/4 hex insert bits I've seen are about an inch long. Does anone have a source for shorter bits--half inch or even a little shorter? Modifying existing bits could be a real chore. Thanks.
Monte
Germany
Who makes this one? Thanks.
http://www.newtools.com/
Here are 2 sets with extra short bits
http://www.suekage.co.jp/new/mrg1431s/index.htm
http://www.suekage.co.jp/new/mrg1425s/index.htm
more pics:
http://www.garagejournal.com/forum/showthread.php?p=538079&highlight=pro-auto#post538079
Fedwrench
Valley of the sun
This is the best one since the invention of sliced bread. You buy it as Blackhawk, Husky, Vim, or others.
It has a fine 72tooth action, is reversible, will accept 1/4 or 5/16 bits and it even comes with a 1/4 square drive adapter for use as a ratchet. It's great for trim, under dash and other close quarters work. It runs about $15 and comes with a few bits too depending on where you shop.:thumbup:
mrholeshot
MEMBER EMERITUS
Thats just like the Gearwrench Microdriver. The Microdriver has quite a few bits and some sockets, Sears had it for 23.99 then they had it for 1/2 off last week end and while I was there picking up an order from in the back and because it took more than 5 minutes I got a 5 dollar off coupon so I buzzed back through the store and got a set for 11.99-5.00 so I got it for 6.99. Sweet!!
Bolster
Mexifornia
This one costs $12. General No. 807-SX
25mm depth.
Bit is not interchangeable.
That Sukeage is only 16mm depth, wow.
Will someone please measure depth of the GearWrench offset ratcheting driver?
Danglerb
SoCal
This place is terrible. I just got my set of precision bits from Amazon, their house brand I think MassTech, and they do look VERY nice. Last week I was at OSH during the 1/2 price sale on GearWrench and looked over their microdrive set and decided not to get it even on sale.
After reading this thread you all have me thinking about buying them again.
Does the wrench holder thing prevent the bit from sliding all the way thru?
How much force can you put "down" on the bit to hold it in the screw head?
jim faston
Monte
Germany
Looking at the two Suekage pages above it appears that only the #2 phillps is available in short length. (16mm - a whisker over 5/8) The remainder of the bits seem to be 25mm - a little under an inch.
after looking at the links again i think you´re right.
Ko-Ken has bits in 15 to 20,5 mm length. There is another japanese or taiwanese manufacturer who offers short bits iirc.
edit: Anex has 19mm bits http://www.anextool.co.jp/products/pdf/4/AK-51P.pdf
Fedwrench
Valley of the sun
My Husky version has what I'll call the capstop feature built into the speeder ring to prevent the bit from passing through the driver.
I've pretty much hung on mine with most of my body weight removing torx head screws holding the shift cable bracket above GM transmission pans.
It is one of the best tool purchases I've ever made. By the way, the design is patented and the speeder ring on my Husky model is stamped REVERSE GEAR.:thumbup:
Bolster
Mexifornia
Third time a charm?
Will someone please measure depth of the GearWrench offset ratcheting driver with a phillips bit in place?
I want to compare it to what I have. I need a short depth offset phillips and I am considering the GearWrench if it's really compact.
Will it beat 25mm? That's the shortest (least depth) I have now, it's the General I posted earlier.
The Motts
Third time a charm?
I just measured mine. It's one inch. Basically, whatever the length of the bit you put in would be the length.
K
Kenwc
After reading through all this I think I've settled on buying 2 products. I'm going to order the Chapman set and I want to try out a Wera tool so I'm going to get an 8001 bit ratchet. But...where does one wera in the US? I came across a "chadstool" but that's all I found.
Thanks
Ken
The Motts
bchee
Texas
I was checking out the Husky one and the packaging says it has 52 teeth
hofferwood
DownRiver Michigan
I have Chapman and Wadsworth
The Chaps are good, but no comparison to the Wad., fine tooth 12deg arc.
The cats *** for workin on Fanuc robots, (little tiny spaces).
The bits are marked with sizes.
Chaps are marked in Chapmaneze.:confused:
Chuck
mrholeshot
MEMBER EMERITUS
Third time a charm?
Your wish sir. #2 phillips in place. Gearwrench Microdriver
Metric
SAE
Danglerb
SoCal
I wonder how available that Wera bit ratchet really is, only two sources I found were Chadstoolbox and Sears, neither exceptional for actually stocking whats listed.
OTOH $35, yipes.
superautobacs
Vancouver, BC
Here's some pics that I found:
photostream
3258834829
3746729035
K
Kenwc
I ended up ordering the Wera bit ratchet from Chads...we'll see how it goes. Never ordered from them before.
As long as we're on the subject...I looked over all the bits that I have last night and I have a ton...I need some sort of bit storage for those...anyone have anything slick?
(this place is going to send me to chapter 11)
OTOH $35, yipes.
