My torch regulators are probably over 40 years old or I might have resorted to that. I need to do something about those regulators.
I was shocked at the cost of undiluted Asian coolant. I think the last time I bought any it was like $7. Peak from Amazon was $25.
Recently had to do the struts on a gen 1 CRV. First generation did not have any lubrication on the bottom of the shock. Bolts in control arm rust to it. Fun times. Usually rip bolt head off. Leaving welded nut on other side. And a whole mess in-between. Dealers, good ones, carry parts for this. And a large profit margin.I've been replacing the suspension and bushing on my budget project car. The rear suspension put up a fight with several bolts seized into the bushings. I haven't had to use the torch in a while. It looks like it's due for a new tip.
I broke one bolt which had to be cut and then a nut welded on to extract it from the trailing arm.
Giving it gas will wake up the engine. Not that this is a precise way to do something.There is no starter to hotwire. The hybrid system uses the traction motor/generator and the planetary transmission to crank the engine. There's no starter noise. The engine *seems* to just magically go from not running to running with no intermediate cranking. I'm not aware of any way to get the system to just bump it over without starting.
Yes it will, but I wouldn't really want the engine to start with a breaker bar/cheater pipe attached to the crankshaft.Giving it gas will wake up the engine. Not that this is a precise way to do something.
If that's what it took to get the crank bolt off, it was well worth the price of admission. If you never have to do it again, that's a bonus.I bought the most powerful HF 1/2" impact. Advertised as 1500 ft/lb. Brought it home, oiled it and plugged it in.
Oh, look! It's turning the crankshaft opposite the running direction. The other impacts didn't turn the crankshaft. And the bolt still isn't coming loose. But the impact starts off hitting pretty hard, and slows down fast. So it's probably not getting enough airflow.
Give it a 5 second burst. Stop and let the compressor pump up all the way and shut off. Give it another burst. And another, and another, and another. Still just turning the crankshaft. One more, and ugga dugga ugga dugga ziiiiing!
The bolt is off. I'm going to get a set of high-flow quick connects and a decent 1/2 inch hose so the impact will get enough air. That will probably ensure I never use the thing again.
burned some leather flyswatter parts.
I just came in for a break from continuing to work on the Highlander. I was out there swearing to find the Mongo who overtightened the living snot out half the fasteners and deliver the candygram personally.If that's what it took to get the crank bolt off, it was well worth the price of admission. If you never have to do it again, that's a bonus.
I'm putting front brakes on my daughter's '11 Forester. QST
Honda V6 has a ****** of a harmonic balancer bolt. There are several special tool sockets/holder available for them. Maybe the same is true for the Toyota? Available on Amazon.I bought the most powerful HF 1/2" impact. Advertised as 1500 ft/lb. Brought it home, oiled it and plugged it in.
Toyota dealership cut me a break at $26/galI was shocked at the cost of undiluted Asian coolant. I think the last time I bought any it was like $7. Peak from Amazon was $25.![]()
You may have missed that I (barely) got it off yesterday with the Earthquake XT 1500 ft/lb rated air impact from HF.Honda V6 has a ****** of a harmonic balancer bolt. There are several special tool sockets/holder available for them. Maybe the same is true for the Toyota? Available on Amazon.
Well some times I itch my self in the garage, but no one wants to here about that.If you did it in your garage, Roger, it counts.
That's what they're being marketed as. What they get used for is none of my business. If I owned one, I'd be pounding the living **** out of small insects."Flyswatters" huh?
I'm just the tool here, it's what the customer ordered. I will make the suggestion.I like those! Maybe a "screen pattern" for the blank part?
Wow yours is faster then mine, my next day shipping takes 3 days......The heavy socket would have been next. I may keep an eye open for a sale just to have one. I was contemplating rolling my own instead having to wait 3 days for Amazon Prime "2 day shipping".
Well it won't be attached for long.....Yes it will, but I wouldn't really want the engine to start with a breaker bar/cheater pipe attached to the crankshaft.
I got all of the sprocket bolts off. The cam sprockets required a sprocket holder around 4 feet long, and the bolts took a 24 inch Snap-On breaker bar and the handle from the floor jack as a cheater pipe, so a bit longer than the sprocket fixture.. (I'm not making any of this up). The "crack" sound as the bolts broke loose was quite sharp. I'm fairly confident that I didn't bend any valves. I really hope there are no bent valves.Well it won't be attached for long.....![]()
I've had them before makes you want to see the guy that tightened them up and with what.....I got all of the sprocket bolts off. The cam sprockets required a sprocket holder around 4 feet long, and the bolts took a 24 inch Snap-On breaker bar and the handle from the floor jack as a cheater pipe, so a bit longer than the sprocket fixture.. (I'm not making any of this up). The "crack" sound as the bolts broke loose was quite sharp. I'm fairly confident that I didn't bend any valves. I really hope there are no bent valves.
I already have a mental picture. Mongo crossbred with the stereotypical 900 pound gorilla in the room, and the kid took a lot of steroids and growth hormones.I've had them before makes you want to see the guy that tightened them up and with what.....
Tomorrow I get to scrub all of the gooey nasty parts, extract and replace the cam and crank seals in nearly inaccessible places, and put it all back together. Somehow, at 69, this is not nearly as much fun as it was in my 20s.I already have a mental picture. Mongo crossbred with the stereotypical 900 pound gorilla in the room, and the kid took a lot of steroids and growth hormones.
I seriously don't understand how anyone got all of these fasteners so tight in the extremely tight spaces that it all has to fit in.
I am not joking about making a 4 foot long sprocket holder and using the handle from my floor jack as a cheater pipe. I started as a professional mechanic in about 1980, and since then I don't ever recall having to deal with such overtightened fasteners in so little space.
Why are the legs in the middle of the table only supporting the front of the table?Been troubleshooting my CNC table; had an issue develop and I've been working on it since Sunday to no avail.
Today though, my bolt kit arrived so I finally put together my two fixture tables.
Took my time to get them set to the same height and removing two of the legs for a total of six. At this step now it's time to snug the bolt kit between both tables -
Next up is tightly clamping square or rectangular tube on each face, and on top. Snapped a picture before I got all the tubes clamped down and leveling -
Once leveled, you tighten the bolt kit, then unclamp the tubing and call it done -
Don't let the pics fool ya, I have a whole mess of tools and scrap steel cutouts on the ground in the second half of the garage -
Just glad to have expanded my welding table top work space.
Once I figure out my CNC table issue, I can proceed with making more tool holders; last one I made was a few days ago sitting on the table there (painted black).
I like to soak in Marvel Mystery Oil, then wipe down with Fluid Film.Between the basement workshop (house) and the garage (cottage), I resurrected 2 pairs of pliers. Pair with blue grips are mine from a set I bought a while ago when I was accumulating tools. Needle-nose were inherited from my Dad. Both were seized up tight, like rock solid tight.
So 72 hours in a vinegar and salt bath, carefully used the woodworking vise to open them with some force and "presto" they released their rusty bonds. Some brishing, a ton of oil and they are fully functional. Needle-nose will of course be handed down in the family.
I will finish the clean up and get them into the tool box.
Any suggestions on what oil to use on pliers in general? 3-in-One / light machine oil? 10W30?
I spray mine with WD 40. Used to have something called boeshield, but it's long gone, and the WD works well enough.finish the clean up and get them into the tool box.
The ugly - needed a wee bit of heat so I lit up the blowtorch. Flames came out where no flames ought to be. Sorry Dad (RIP), gotta get a new blowtoch that won't burn down the house.
And that’s why I outsourced my lawn work!Bursar reported riding mower steering was not working properly. Took a look and the steering gear is worn. Removed the deck and removed the steering gear. Stared at it a bit then counted teeth so I could order a new one. Put the old steering gear back on but added 3 washers, so it was hitting in a different less worn spot. Put it back together. Ordered new parts.
Moved on to the push weed wacker which will not start. I have checked spark, magneto gap, fuel tank, everything I can think of but still not running. I have had the carb on and off 4 times, putting it through the US twice, but still won't run. Thought it had a new carb, but in checking records it is not. So I decided to quit screwing with it and ordered a new $18 dollar carb.
Cleaned up the mess, swept all the grass and weed clippings up, followed with the handheld leaf blower.
Waiting on parts.....
Oh and brought the trash can up from the curb!
Only on a postage stamp yard round here. I can buy a garden tractor every year, or a nice ZT, and still be ahead of what it costs.And that’s why I outsourced my lawn work!
