IIRC, Puma was a Brazilian body on various other manufacturers' chassis.Neat project!
Aftermarket body on a VW bug chassis?
Those nozzle kits work great and have some serious flow to them. I told my wife not to use ours, we have an older 5 gallon can she uses if needed.
Shop or Christmas?![]()
Excuse the bad photo, but earlier today I removed and replace the old garage door side/top seals and caulked all around. Was a bit of a pain because a previous owner nailed a new seal on top of the old seal boards plus I have one of those garage framed openings with those 45 degree corner angle pieces. So instead of 3 simple straight cuts, I had to make 8 angle cuts while making sure I didn't cut the rubber seals wrong or short where they overlap.
Next I'll replace the bottom seal and then it's just a matter of painting a second coat of white paint on the door and frame and its good for a couple seasons or at least until I square off the corners of the door frame to match the door windows. But hey, that's another project for another day.![]()
Cool I might try that. Probably make for a better seal at that spot too. In any case I want to square off the door at some point. You have the nice real wood casings like my old house. Unfortunately this house has aluminum siding, which is in great shape except for the aluminum casing around the garage door opening which has some dents, so not as nice and smooth as they could be. All the houses in this HOA have aluminum siding except of course those that had their homes redone in vinyl which I'm not a big fan of either.
I have the maintenance free-ish PVC wood casings. They do look nice, with graining and everything.Cool I might try that. Probably make for a better seal at that spot too. In any case I want to square off the door at some point. You have the nice real wood casings like my old house. Unfortunately this house has aluminum siding, which is in great shape except for the aluminum casing around the garage door opening which has some dents, so not as nice and smooth as they could be. All the houses in this HOA have aluminum siding except of course those that had their homes redone in vinyl which I'm not a big fan of either.
Cleaned, flung, put away. Dragged out the Dingo's waterhog. Cut the bottom inch off the garage door rails. Started shoveling out and scrubbing down the lift. Lugged out a couple file cabinets and the remains of a screw lathe. Brought in 10 sheets of 3mm ply and a big mahogany board.
It would definitely stiffen the place up, and help with sound.In-out. In-out.
I’m wishing more and more to have a door between the house and garage. Instead of having to go outside and then into the garage.
Anyway, I digress.
Got 2 more sheets glued and screwed. Now I have enough room on this side of this wall (will be a bedroom), to stage the construction stuff to finish the rest of this side of the house. I have enough OSB to sheet the walls and keep the dust contained to this area.
Now I’m wondering if I should sheet the walls with OSB, THEN drywall. Hmm.
I lined my 3000 sq ft 1700's Latham house with 5/8 plywood, internal and perimeter walls, to keep it from swaying in the wind. Then drywalled over the ply. It made a world of difference in temperature stability and noise penetration. OSB should do just as nicely.In-out. In-out.
Anyway, I digress.
Thanks for the tip. I will look into PVC wood since I'll have to remove the aluminum facing when I square off the casing anyway.I have the maintenance free-ish PVC wood casings. They do look nice, with graining and everything.
If you pulled the tin on your garage door casing and did it over with PVC wood it would look tons better.
The two brands I'm most familiar with are Kleer and Azek. There may be others. Some have more realistic graining than others.Thanks for the tip. I will look into PVC wood since I'll have to remove the aluminum facing when I square off the casing anyway.
It's always something. Small wins theory, right? One "tuck" at a time!Yeah. Chimney is 40-some years old. Put up by someone with no clue. I'm fighting a dead man on that house.
Maybe that's my problem, I'm using the wrong word.It's always something. Small wins theory, right? One "tuck" at a time!
No I did not insulate the floor.It would definitely stiffen the place up, and help with sound.
Probably raise the r factor too, but I think you said you didn’t insulate the floor?
That’s the plan then.I lined my 3000 sq ft 1700's Latham house with 5/8 plywood, internal and perimeter walls, to keep it from swaying in the wind. Then drywalled over the ply. It made a world of difference in temperature stability and noise penetration. OSB should do just as nicely.
I've seen a few people in south Florida do a stucco skirting with vents, and an access hatch. It keeps the critters out.No I did not insulate the floor.
The plan eventually is to get a crawlspace company down here to do their thing. But that’s far future.
As is now, any soft material gets made into nesting material.
Though now that I’m home more (not driving as far for work), I can start mitigating pests and critters better. I never did set traps (hav-a-heart traps) for fear of catching a critter early in the AM and then it being caged for up to 12-13 hours until I can deal with it. I thought that would be cruel.
I have a cinder block “foundation” under the perimeter of the house. The house touches it in most places.I've seen a few people in south Florida do a stucco skirting with vents, and an access hatch. It keeps the critters out.
Instead of skirting, they used like firing strips, paper back lathe, and then a coat of stucco.
Isn't a smaller dog house warmer?Trying to save money on the cost of an insulated dog house in preparation of the coming winter, I decided to build one large enough to fit 3 of my dogs. Well I didn't work from plans, only an idea in my head, and when it was all said and done, it wound up costing much more than the cost of a new dog house. It did turn out way heavier than the ones you could buy in the store however and should last for many dogs lifetimes. I will have to get some pictures.
I was able to talk the wife into letting me get a new battery powered framing nailer out of the deal. She thought it was only going to cost "about $50", she was a bit shocked at what they actually cost after the fact.![]()
Been trying to make the garage to the point I dont need to move much to get at anything else. Best part is I can get my car and her Honda in whenever I need to and still open both side doors. Ram3500 not so much but the garage is coming along. Waiting to get my last paycheck in two weeks then might see about one more Husky bottom as well intermediate box to put the red one on, which will free up the box and a half to go back to being my side work bench. It’s nice having my bike up on a bike lift, chainsaws hanging until I know exactly which one will live in this and that.
Has to be big enough for 3 dogs, plus it will have a wall mounted heater.Isn't a smaller dog house warmer?
If you're lucky.Just a replacement battery costs that...
