Old Man Roger
Nah, I just knew at a young age that she was a good one. As for her, I don’t know what the hell she was thinking..lolWe're y'all born in the mid 40s?
Wait a minute now i've been married 47.x years and I'm not that old.............We're y'all born in the mid 40s?
Teri Garr was, a few years older than me.Wait a minute now i've been married 47.x years and I'm not that old.............
She had a bit more then a decade on meTeri Garr was, a few years older than me.
Thanks.Your boat is really looking great! I love the cover support. Looks like one person could lift that in and out.
She was way funnier and prettier than me. I'm not sure she did all that much acting. She mostly seemed to be being Teri.She had a bit more then a decade on me![]()
Same here. Our 46th anniversary was last month and I just turned 67 in September. If you know, you know.Nah, I just knew at a young age that she was a good one. As for her, I don’t know what the hell she was thinking..lol
I want to rip out our entire pantry. I just haven't decided how I want to redo it. I just know I don't like the current layout.Cut down, sanded, and stained a couple of shelves for the pantry. Got to use up some old bits of plywood.
A lot of us out here. I need meds and sunlight, but every one’s depression is different. If you know someone with depression, you know one person with depression. Do what you need to do, Bud.Been a little depressed lately, so haven't wanted to do much.
I got out to the shop and replaced the ancient rear projection TV with a smaller LCD one. It freed up quite a bit of shelf space on this part of the shop.
I'll be able to shuffle some storage around to make it easier to get to some tools.
What does that do for the bike?
We had a dishwasher cause thousands of dollars of damage. When you get things repaired put a tray under the new dishwasher. You can get them that will push the water out the front. This save us from a repeat a year later.Cut down a couple old plywood shelving pieces to put under the dishwasher. It looks to have been leaking for awhile, the floors are buckling, but it didnt shut down until Christmas day. Trying to decide what to do next. Will call the insurance people tomorrow and see what the options are going to be. December sure did ****.
I tiled under mine so that any leaks flow out the front.We had a dishwasher cause thousands of dollars of damage. When you get things repaired put a tray under the new dishwasher. You can get them that will push the water out the front. This save us from a repeat a year later.
That's a pretty cool project!Just a little evening project. I bought an old cast-iron Detecto scale, ca. early 1920s, for a bargain price. It wasn’t in bad condition, although it had been painted at some point in its history and was a little rusty. Based on some photos of others like it, it appeared that one of the parts was installed backwards, and it was also a bit out of balance. There were traces of black paint under the green paint.
I took it apart, bead blasted the parts, primed the parts with self-etching primer, painted them satin black, sharpened the edges of the two hardened-steel center pivots, cleaned all six pivot grooves, and reassembled it, adjusting the amount of factory-installed steel buckshot under the right-hand platform to balance it.
I also cleaned up the 16-oz scale bar, blackened the markings to make them more legible, and gave the bar a protective coat of polyurethane. Total time spent, about three hours over two evenings. It’s now balanced and operates like new. I can blow on it gently and the platforms move up and down smoothly. I suspect it will probably just serve decorative duty, but I like knowing that it works.
I have so many long-term projects going on that once in a while I need to finish a quick project like this to get some closure.![]()
Hello fellow Unifi guy, I have a full Unifi Network and Video system. Love it. Hate the availability issue still going on.Went out to the shop and made sure I still have enough cat5e cable and rj45 connectors to run a cable for the new security camera.
Once I get this one installed and tested for a week or so I'll order cameras to replace the rest of the Arlo cameras.
I also watered the lemon tree while I was out there.
I also washed mine and put it back in but my garage is heated so its not a big deal to me .Gave the truck a wash (35 degree temps, neighbors think I’m nuts) and stuffed her back in the garage.
A Dreamsicle garage!Nearing the end on the drywall.
I wiped the last coat of mud on the ceiling yesterday.
I had to do it in halves. Did the north half first then move all the junk and do the So half.
I'll touch it with sandpaper today and get some primer on it.
And I played with some color.
Ive always been an advocate of color.
Sorry, thought it was a great PSA considering the topic.
I keep my face shield in a bag, if I don’t, they get blurry pretty quick.
Yep I still need to sit down and go thru the old harness to untangle the rats nest into a box full of coiled up wires ready in case I need a certain color and guage.I've used both Ron Francis and Painless wiring kits in the past on a few street rod/muscle car builds and I have kept the remnants that were left over because the wire quality that they use is quite good and can be used in other applications. When I have a small wiring project or need to extend some wires, the boxes of remnants are my first "go-to" source.
