600SL
I now have my system up and running and it seams to be working with the default settings of just about everything. But there still seems to be a lot of tweaking that should be done. First off after about 12 hr of running I find the tater temp at the input and output of the manifolds to be ~ 140° and 70° F which I thought would be too high. So I increased the circulator speed from medium to high but there are flow control valve on the manifolds. So how do I balance that out. So there are several setting a need to know how to optimize:
1) Max heating temperature, Currently set to default of 180°F
2) Circulator pump speed High Medium or Low. Currently set to high.
3) Manifold metering valves. Currently running at ~ 0.6 GPM
