Not everything was designed correct, and things became more easier to use as the years went on. This is in face a spring compressorAll the valve spring compressor I have seen and used have some kind of a pocket to capture the spring?
I don't see anything like that?
It does resemble a piston groove cleaner.
I found this Sunnen flathead valve spring compressor at an estate sale on Friday. It took a couple of evaporust baths to be able to determine the brand. Must have been used hard as it has been welded back together in the jaw area.This is what Sunnen's valve spring compressor looks like:
