I'm just gonna leave this here:I think the colors for areas is going to be the ticket, only issue is that I am going to run out of colors that have normal names. I guess I could do two colors and have the QR codes half one color, half the other color. Basic colors that everyone understands are:
Red
Blue
Green
Yellow
Orange
Purple
Gray
Black
Brown
Pink
These are also common but not as easy
Silver
Gold
White (print using a black background)
Other colors could be neons.
This would give me ten areas to start with and then get into the non standard colors. I have to list all my spaces, ten might handle it if I go really broad, would be nice to have the shop space broken into multiple areas by color.
I always figure if I don't make some kind of mess I didn't do it right.
I definitely got paint where I didn't want it, but I also didn't want to take the time to mask things. In a perfect scenario, I should have painted the wood before putting it up, but I had help and took advantage of it. Otherwise the pieces would still not be painted and they wouldn't be mounted. I may put another coat on it, just depends on how the day goes.
I have decided how to move forward with the shop upgrade/stockroom installation, I just need to figure out if it is truly feasible. My plan is what I had originally planned years ago, a plan that everyone thought was dumb. I will still have to do things in stages, but I should be able to do it without too much effort, at least once I get things figured out. So I am going to jack up the roof (20' section at a time), pour a concrete vertical wall to set the existing walls back onto (or rebuild the walls using 2x6 lumber). the only real attachment I have to deal with is the electrical and my plan all along was to rework that into surface mount conduit as my inside the wall design *****. I think almost every planned outlet has been blocked or covered by something, at least with surface mount it should be easier to reconfigure. Once all the walls are done, I can replace the roof system with new trusses that will fit my intended usage. I would start on the stockroom end and work out from there as the stockroom setup will be the biggest PITA to move later. By doing it this way I should be able to have the stockroom setup sooner and that is my ultimate goal.
I am not going to ask the City for any help....
I am outside of the viewing area for any officials and the neighbors are on board. The reason I want to add the stem wall and replace my current walls is to gain height, the current walls are a mess, they were 2 x4 and I added an inner 2x4 wall, so there is jumbled mess. When I did that, I wasn't even pretending to be a carpenter, I can plumb a tower, but apparently not a wall. Plus the walls are directly on the slab and the level of the ground (not changeable) is almost even with the slab, so things get wet from time to time, especially with any snow pack. By adding a stem wall I get more height and still use 12' lumber to save some money.
This is exactly why I am taking time to figure things out well in advance. I can't go half way on a project like that, it would be a bad situation.It sounds like that's the best way forward for your situation. I just hope that this project doesn't end up like so many and be quite a bit late, that would likely throw a bit of a wrench into your plans.
Thats a biggin.four post mohawk lift, it lifts 25000
Whats the end goal? You have a ton of **** for one guy to handle. I don't have nearly the amount of stuff you have and my shop is a pig sty. You spend more than half your time shuffling **** around with no end in sight.
I admire your goal, not your task.lol I think most people just think you store too much stuff, and that is making your task more difficult. Admittedly you have some amazing stuff, but some of us think it’s just too much of it for your own good.I don't think I have an answer. Until I am physically unable, I will probably continue on the path I am on. I am hopeful that organizing things using an actual system is going to make a big dent in my time ****. With the move from the Hill the amount of stuff is going to get worse, but then it will consolidate and start to get more manageable, the transition is going to be an ordeal and I know that. I know that planning things out and implementing them are two totally different animals, I also know that I don't really comprehend that statement.
How many years ago was it that you were going to purge? You guys are owned by your stuff, not the other way around.I have a similar problem to Strouty, but just not to the same extent. I keep buying stuff for projects and then never doing the projects. I end up losing tools, or parts for projects, and then end up buying more tools or parts.
I have stuff everywhere in my house and two garages. The only things kept outside are my vehicle and a trailer. Everything else, including a 43 foot converted coach bus, is inside a building. My house is pretty messy, and it would drive a wife or girlfriend insane if I had one. I actually took the day off work for the next two days to clean and organize. I need to get off my computer.
I have a buddy who hoards classic cars, among other awesome toys, the problem is he pays hundreds of thousands of dollars for some of them, then lets them rust in a metal building sitting on and under multiple 4 post lifts. His stuff is cool, but it doesn’t change the fact that he’s a hoarder.I can't argue with that statement, stuff definitely claims ownership after a certain point, probably the point that you have to start calling it stuff rather than a specific type of thing...
