bulletpruf
San Antonio
My Muncie was stuck in reverse. I pulled it out of my 66 Chevelle. I removed the tailhousing and found the rogue speedo gear floating around. Going to fix some small damage, clean the mating sources, new gaskets and throw it back in the car.IMG_4569.jpegIMG_4571.jpegIMG_4572.jpegIMG_4570.jpeg
We're gonna need to see some pics and hear more about the '66 Chevelle.
I had an Aztec Bronze 4 speed car that I sold years ago; love that body style.
JEFFREYWisconsin
My Christmas present of the Vyper cart is finally loaded with stuff I seem to use a lot and it is finally a useful, much loved and very mobile piece of my garage. I have a long way to get this place dialed in, but I am finally able to work out there.
JEFFREYWisconsin
Plugging away at the drywall in the garage but ran into an issue of the back left corner stud is 1/4" shallow to the others so gonna try and find a small strip to slide up behind it and finish the back wall. only 2 walls to go then the ever so fun mud and taping /s9P4AwbY.jpegSFiyHnP.jpeg
This is where you are required to complain about and blame it on the framers!
If you framed it yourself, then blame it on the sub par lumber available!
zarex
Saudbury Ontario
nah I didn't frame it lol, Garage was used as a music studio before we bought the house and they had 3 layers of drywall before and double walls behind the garage doors. I do wanna complain about them running coax cable out to the garage and not any form of ethernet/ fiber op cable when the house is only 13 years old
KFBR392
Not in the garage, but a garage project.
My dad passed away twenty five years ago. He had a bunch of vehicles and this old Uhaul trailer. I ended up dragging it home a parking it in the back 40. Never thought much about until my son recently brought it up in conversation.
It's a 1985 car hauler. It's probably not any good for hauling today's vehicles, but it will be a good utility trailer hauling firewood, lumber, garbage, etc.
Anyhow, twenty-five years outside in the PNW sort of took its toll on this poor trailer. Along with the old tires and scrap metal I piled in it, branches, yard debris, and weeds took it over. I spent about two and a half hours getting it unearthed and cleaning the **** out of it.
I spent some time with the wiring harness, but it's pretty much rotted away. The surge brakes are most likely needing attention as well. New tires are also on the menu. Then there's a need to sandblast the rust and repaint. At some point, a good used trailer from Craigslist might be a better option, but I don't mind a bit of a challenge.
I will sometimes purposefully take on a project that is possibly too far gone or not financially worth taking on, because it challenges me and I can very intentionally practice skills on a low-stakes project where a screwup wouldn't ruin my week. This looks like it might be one of those projects but it also looks like it might actually have some upside. It doesn't look that rotted out.
stonesfan68
Houston, TX
Dodged a bullet...
A few weeks ago I was out of town (of course) and my daughter called me and asked why her Volvo C70 sounded so terrible, "like a jet engine."
My wife heard the noise and had told her to put the car in the garage and turn it off.
This didn't sound good to me. My first thought was a timing issue and when I arrived home I popped off the timing cover I saw this.
The teeth on the timing belt had sheared off. I have no idea what happened. It is a Continental belt bought from Rock Auto so it should be a quality part. By some miracle, the engine stopped right at this point because if it had kept going for another revolution I think I'd of been doing a cylinder head replacement.
I think the belt slipped a tooth and that was what they heard. It was very fortunate that this happened in the garage and not on the freeway because then it would have been game over for the engine.
I installed a new belt and tensioner and got the engine timed. I then rotated the engine by hand several times to verify the timing and that there was no interference or metal clanking.
Sweating bullets, I held my breath, turned the key and it started up without any issues.
It lives!
Jay__Dub
Cold Country, Canada
Did a lot of putzin' around in there. Guess I better be careful how I spell that word. ;)
Did not accomplish a helluva lot.
Cleaned up a mess from a repair, and put the tools away.
Hung a couple of signs.
Put the old, what is now known, thanks to GJ'ers, as the Duplex tool box up, will have room on the left for another one. There will always be another one. I think I'm going to print off what they all are, so when I croak, my Wife and kids will know wtf they have there. Not that they are gold nuggets, but they all have history. Like most people in this forum, I love the old stuff.
niget2002
Josephine, TX
Finally welded up the stand for the little couch shelf my wife wanted. I started this thing back in January but kept redesigning it in my head. The original design was way overkill.
Testing putting weight on just one corner.
And then double checking height before welding.
Working on the finish now.
JEFFREYWisconsin
I would gladly keep a beer or 4 on that.
KwikFab
Central Valley, CA
Should run a router or whatever wood working tool you use and make a sort of "insert" for a beer or cup to sit in!
Or you could go a step further and make the hole, round the edges, and place a small "stop" underneath the opening so a drink can sit fully inside without the chance of tipping over!
niget2002
Josephine, TX
I thought about something like that, but I'm using threaded inserts to bolt the top to the stand. There's not enough wood thickness left once the holes are drilled to route anything off the top.
alinc100
Dearborn,MI
I was able to finish up some more pens. This time I had a bit more fun and made a video. The video and learning to edit,etc took way longer than it took to make the pen ,but I have an idea the end user will get a big kick out of the process. Hopefully this batch will get shipped to family soon and then I can tell Harper about her video on YouTube.
Beerhippie
Far NE Oregon
I consider my entire work area as my "garage". Of course, it all belongs to someone else, but I swing the wrenches, so....
Part of my job is photography for the pub menus. Today was our beer menu.
Back about twenty-five years ago, I did lot of food photography for local eating establishments. It was fun and profitable. Then folks decided that cell-phone pics were good enough, so that gig kinda' crashed. Fortunately, my current employers seem to want something a bit better than a cell-phone snap-shot, so I'm getting the work again--at my regular pay scale.
OTOH, I have gotten my employers to invest in some modern LED continuous lighting equipment. The stuff I did back in the day was all flash or "hot light". LEDs give one more time than "hot lights", which tend to cook things (including the photog) and are, unlike flash, WYSIWYG. Makes set-up much faster.
What I didn't much do was drinks photography. I did a little, but not much. So I'm not so much re-learning as starting over from scratch with this. Fortunately, my employers don't have the highest editing standards, cause photographing highly reflective, translucent subjects is HARD.
Before anyone mentions it, I do realize that the table isn't level. I think my next garage project will be a platform to go on top of a tripod (I have several) so I can easily level the subject and the camera.
Magnum440d100
Indiana
Been using the neighbors mower for a couple months.
Decided to get my trusty rusty Ariens up and going.
End of last season, a wheel bracket busted off, and the belt broke.
So I got her fired up, and pulled into the main garage on the concrete so I could line up/level the deck to weld the bracket back on.
Also installed a spare deck belt. I’ve got to order a new one, as this one was replaced because it was questionable. But it works for now lol
KFBR392
Would love to see how the shots are set up and what it looks like. Those pics look great and I didn’t really notice the table thing tbh.
zarex
Saudbury Ontario
I'd probably just sister a chunk of 2x to that stud, screw the drywall to the sister and be done with it.
found some cheap 1/4" x 2" 4ft poplar strips at the big box store and slid up behind the drywall and made it flush and able to screw the drywall to the stud without to much flex the screws popped through. only 1 stud and wasn't taking the whole sheet down again lol spray foam insulation so a bit hard to sister in a 2x4
KFBR392
The original binding chipped out really badly while pulling the old frets, so new binding is going on.
The rest of the old stuff chipped off cleanly with a chisel and little baby hammer taps.
The new binding material can be melted in acetone to be used as its own adhesive. So the strip of binding material to be installed was formed with a heat gun around the curves at the **** of the neck, and then a couple of excess pieces of plastic binding material were left to cook in a small glass jar of acetone.
When ready, I’d just swipe the melted tip of binding along a couple of inches of the binding channel, press the binding tightly into the channel, and secure it with blue tape. The whole process took about a half hour. It’ll cure overnight and from there I can move onto sanding with 400 grit on a radiused sanding block to clean up and smooth things out before installing the new frets.
Timm is his own worst critic, and takes excellent photographs when he does the full setup.
I agree its a round table and the angle of the butcher block pattern looks great. The cans and glass's are vertical (my nemesis when I take pics) and that's all that you really see.
