GirchyGirchy
Changed the spark plugs and air filters in the Mazda3, then stared at it while continuing to debate whether I should fix the leaking timing cover or let the next owner worry about it.
Yeah pretty much. It hurt too much to cuss and I had to trim the broken thumbnail off the rest of the way.It appears that you were successful...![]()
A small barrel sander in a cordless drill works wonders on a thick toe nail.lolDid my nails. Metalflake green. It's handy to have a big bench and die grinders.
Best to do it immediately, just like washing road rash. It hurts waaaaaaay more if you wait. When it’s fresh, it almost doesn’t hurt anymore than it already hurts. If that makes sense.Yeah pretty much. It hurt too much to cuss and I had to trim the broken thumbnail off the rest of the way.
Oh it does.... Most only have pain in one area.....the area with the most pain wins...Best to do it immediately, just like washing road rash. It hurts waaaaaaay more if you wait. When it’s fresh, it almost doesn’t hurt anymore than it already hurts. If that makes sense.
I had just recently put a set of finger nail clippers in the garage. . . Then I had to clean the blood off them later. I believe that was a first cleaning blood off clippers.
Really? I use mine for surgery all the time.lolI believe that was a first cleaning blood off clippers.
I think we know who.I know a guy who’s had to do that more than once. He shall remain nameless.
I always manage to miss my thumbnail and just send the bit through the meat at the base of my thumb. I've had to pull a driver bit out of there with pliers more than once.Oh it does.... Most only have pain in one area.....the area with the most pain wins...
Usually use the X-acto knife for that.Really? I use mine for surgery all the time.lol
I've done the side of the finger a couple of times.I always manage to miss my thumbnail and just send the bit through the meat at the base of my thumb. I've had to pull a driver bit out of there with pliers more than once.
Thanks. It's a simple meter and rarely gets used but it works well and has sentimental value.Nice save.
< snip >
Meanwhile, I'm trying to get signed up for SS online. I may have to start drinking a little early in the day.
< /snip >
Took me 5 minutes, way back when. Might have had something to do with public service. Medicare was even easier. I did absolutely nothing. Again, being in public service took care of me.Meanwhile, I'm trying to get signed up for SS online. I may have to start drinking a little early in the day.
It was a couple of years ago but I remember signing up was not all that easy.I'm trying to get signed up for SS online. I may have to start drinking a little early in the day.
I modified my Cornwell CA 84 bit holder/driver to hold more than the three or four short bits it will hold in the handle.
A 1/2" Forstener fit just inside the threads and at 150 rpm, went through the plastic like a hot knife through butter--right down to where the lead spur hit the end of the shaft.
Now it holds all those (plus one in the bit holder) comfortably. I'm setting it up to be my electrical work driver, so need to get rid of the PH 3 and add a #1 & 2 square instead. It will easily hold six short bits now.
Now I'm trying to get the rust and crud out of my new-to-me pressure sprayer:
It holds pressure just fine, once I made a gasket for it, but the tip clogs almost immediately. I gave it several rinses with acetone and now have it filled with white gas and ball bearings. I'll give it a shake until my hands tire, set it down, rest, repeat until I can't do it anymore.
I may have to to fill it with sodium citrate solution and put it in the hot plate to simmer for a while--after the shake fest.
Uh, you shouldnt do that.
It's a PITA. Half the pages I need to go to show up as Page Not Found. This is clicking links within the system. Why do I get the feeling that the software is by Oracle? Oh, yeah, sue me Oracle, I don't even have my SS income.It was a couple of years ago but I remember signing up was not all that easy.
I was not able to do it all online, I had to call and call and call........I'm nearly deaf, calling is well....difficult. Even worse, the person I talked to didn't speak English very well.
Finally got it though.
I'm setting this one up to work electrical boxes and such--PH 2, ECX 1 and 2 (whoever came up with this idea, get in touch--I have a hammer to show you), Torx 15 and 25, square #1 and 2. A standard bit would be handy, but that about fills the increased storage.....
I've got a modern Ideal (with locking bit holder) as well as a "Bear Distribution" that is yellow doesn't have a locking bit adapter, but is otherwise identical--even the same patent in the cap. I assume it was Pratt-Read sourced. Both really don't hold more than 4-5 bits, so I may try something similar. Both all just hold the same 4-5 bits in the handle (though the Ideal came with a block full of US-made bits). Normally, I keep PH2 in the shaft, with Torx (typically, T15, 20, or 25--or 20, 25, and 27 when I can find short T27 bits) and PH1 in the handle.
I use that style wheels on my modified creeper seat that used to look like yours. I love how the wheels roll. I think you will be pleased with the upgrade.
I use that more for slicing out metal slivers that are too deep for the tweezers.Usually use the X-acto knife for that.
I add a pair of "geek googles"--2.5 diopter magnifying goggles. With the readers underneath.I use that more for slicing out metal slivers that are too deep for the tweezers.![]()
Maybe test for lead paint?As you can see, they taste better. I carry it in my mouth when running back and forth to the saw all day when I do a project!
I got it! that timeMy humor is wasted here.lol
Yesterday we loaded all the cardboard I cut up into my wife's Bronco Sport to take to the dump for recycling.
I marvel at just how much cardboard we turn in each week. I am starting my own No Amazon July to see how it even feels to not order anything for a month. I have always wanted to try to shop more locally, but it seems the stores never have what I am looking for. Wish me luck!![]()
I like that drain pan. Didm't know about them. I have the same ZT, so will give it a try.Nothing in my garage but in my grandmas garage I changed the oil, spark plugs and belt and fuel filter on her Toro ZX5400 zero turn mower. She mows all of her landlords properties in exchange for living in her house with my aunt so having the mower is important to her and I’m the only grandkid that will do anything for her so she counts on me but I really enjoy doing it. It’s helped me learn a lot about mowers too by doing this the last few seasons. The oil was very very dark so glad I changed it. This time I was able to find more information on the engine instead of buying the very expensive Kohler filter I just got a Fram and put on it and threw in 2 quarts of Castrol GTX 10W-30 same as last time. Castrol is my preferred brand of oil no particular reason just like it and it has kept my engines clean. The mower was running like **** probably because the fuel filter was black but I installed a new one and it runs like new. We didn’t realize the mower was a 2015 model as her landlord told her it was new when he bought it for her in 2019 but oh well it works so that’s the important thing.
Spark plugs for that thing are hard to find I had to go to the auto parts store to get them. I got there and realized I left my copper anti seize behind but I had brought silver so I just used the silver on the plugs it should be fine. I put in two fresh Autolite plugs. I wanted NGK or Champion but the store was out. But Autolite works fine I’ve never had a problem with them in my Ford cars before so I’m not worried. I also had already purchased the special 7/16 square pipe socket last year because I fought the drain plug with a wrench last year and this socket is so much easier to use. It’s a Sunex.
I also had bought one of those little 7 quarts open top drain pans and it fit under the mower perfectly. Most importantly I feel good about doing all of it so glad I got it done. My grandma is turning 79 next month. She kept hugging me and telling me how thankful she was I got it done for her and then slid me a Ben Franklin. I’m like you don’t have to give me anything but she insisted to like always.She also gave me two Gatorades which I chugged because it was 91 degrees outside.![]()
