Hey guys, a few of you were having image posting issues. We are working on that now... Please give it a go as a reply to this thread. If it works, we will see images. If it does not, please let us know as a reply with details...
I only use the mountain logo. Maybe that's why it hasn't been a problemokay.. just ran into it again with these two images, neither of which would upload when I attempted to upload them using the "Attach files" button at lower left:
^ I just uploaded that first image using the little "mountain" icon at the top.
But the second image will not upload here using the little "mountain" logo.
Did you try the same images that failed earlier after Ryan posted post #10? I don't know what they did, but the three photos that would not post for me with the [@ Attach files] button recently - actually would post, but appear blank, like a loading fail - are now posting....it seems to only be happening to me when I am trying to use the "Attach files" button at lower left.
I don't know if file size matters but resaving them might be changing that?^ What is odd is that it seems to only be happening to me when I am trying to use the "Attach files" button at lower left.
Generally I don't have any issues uploading images using the little "mountain" icon at the top unless the filesize is overly large, in which case I can just resize it - that's not a big deal.
I'll let you know if I hit any more.
What's the filesize before and after cropping? Or maybe it's similar to four cycle where it's just the resaving that matters?
No, because when I run into the problem, I start manipulating the file, so I don't have the same file that originally was at issue.Did you try the same images that failed earlier
Any chance your file names are too long?so... the second image (filename Ellrich Hardware Mfg. Co. ratcheting screwdriver (patent 293957)(ebay 294239536971 03) ) will not upload using the little "mountain" icon above....
.... but if I open the files in Windows Paint, select "Save as" and save it as a *.jpg image, I can get them both to upload using the "Attach files" button at lower left:
I think I've only ever used the mountain icon a half dozen times. I almost always use the attach function. There is no drag and drop on the phone.No issues loading.
I NEVER use the "attach" functions.
Understood. I kept the last three occurrences original for that reason.I start manipulating the file, so I don't have the same file that originally was at issue.
Same. But I am hopeful Ryan & Team have it licked now. I thought it was a recent Windows 11 upgrade thing, but that was apparently just a false coincidence.It's really weird. It's not consistent. I'm not seeing a pattern at all, so I don't know what is causing it.
