Yesterday, I got 2 smaller tarps and replaced the one on the red Sami, (sun took the other one) and today did alder leaf cleanup around the blue Sami so I can replace its tarp.
Also this AM started the "dig out" of the rotted 4X4 post for the front patio fence. all the other posts are good, just this one rotted? :dunno: So now I have a nearly clean 4X4 "hole" then only a couple of scraps of post and roots are left in the corners it I can get the last of that out, and the new post fits, I can simply drop/hammer it in. if not, then I need to bust out the concrete...
Motorman55
South Jersey
Started taking off some parts I want to keep from my '94 Chevy C1500 P.U. before it goes to the recycler. My truck's frame is too far gone from rust and needs a lot of other parts replaced. Steering box mount section is rusted thru both sides. Just too much to fix and no place to work on it. Feels like I'm losing a friend. 1759114602514.jpeg
SRU1436
Bay Area, CA
☹️ That *****, I can understand. I have a 2001 Chevy truck that I bought brand new off the lot. I can’t imagine ever getting rid of it. The shifter at least will give you a visual reminder.
kaymccampbell
Upstate New York
Spent the afternoon drilling holes and bench testing all the LEDs for the house. Looks like I can get away with only 2 power injections.
Cut a bunch of J-channel
Used the 3d printed template to put holes every 3" in the plastic J-channel.
Then hooked everything up to the power supply.
I have the two wled controllers syncing with each other.
I still need to cut all the extra LEDs out and install the waterproof connectors. The plan is to put connectors on each segment so if a led goes out I can pull the entire segment off the house and fix on the bench.
Looks nice. I'll share this. IME, power injection for every 60 LEDs minimum, but if you want real consistent brightness then every 30, if it's going to be real fast moving, every 10 or 15.
bugnut
Central Ohio
Yesterday, Installed the newly shortened axle, rerouted the brake and throttle on the grandsons trike. Test fire everything spun as it should, readjusted the chain tensioner bolted on the wheels & tires, took it for a test spin. Put it in the shop. Needs a little more love but its getting close.
Reworked the hand throttle on the tractor and it still won't hold position, need to dive into the linkage as there is a ping returning the throttle to a lower rpm.
Put the baja on the trailer and tied it down, off to an alignment this morning.
Put tools away, fiddled with the old shoptop (thanks, Kay) still not able to get firefox to work correctly, it will not search correctly-once a search is initiated it just sits. MS browser works fine, albeit slow. I have removed and reinstalled firefox. Time to quit and move on.
kaymccampbell
Upstate New York
Time to move up to Linux.
mrb1
Miami County, Ohio
I posted doing the front shocks on the Silverado a couple months ago. I kinda pushed the rears to the back of the bench. Wasn't too concerned, easy swap. Stuff comes up. So yesterday finally got setup to do the rears. Drinks flowing, baseball on, couple friends, neighbor stopped by. Perfect. Got the old rears off fine and when I pulled a new one out of the box, it's not even close to correct :LOL:
Of course the return window has expired. Yes, my bad for not checking back then. The ones I received are for a 2010-2016 Caddy with coil overs and an electronic adjustment. About as wrong as you can get. The Detroit Axle ad showed the correct ones. The new pair will show up Wednesday. Still a great day :) (the wrong ones are still going back as "wrong item received")
69charged
carberry, manitoba
I feel ya. How can one get so attached to an object. Weird to me, yet every vehicle I’ve owned has a personality. At least to me they do. I was also sad to see this one go…
It was such a good car!! I loved whipping around town with it, and it never let me down. Until it did. Timing belt went, and she was pretty rusted out. I was going to fix it, but with almost 500,000 on the clock, it was time
Miss ya buddy!! 🤣
racecougar
Missouri
Saturday: Stuck a larger carb on the Banana, made a few jet changes to get it dialed in using the portable WBO2, then hit the highway to run some errands before meeting up with Dad at the gym. It rips up to 80 MPH very well now.
Sunday: Finished stripping the front fender wells of Dad's '73 Mustang before seam sealing and coating them.
557434280_10101339542948203_2760897451527894479_n.jpg557779125_10101339543013073_2830585978945977703_n.jpg
niget2002
Josephine, TX
I'm currently injecting every 30->40 LEDs depending on where the start of a J-channel lands. I do have one segment that is the full 50 LED string of pixels. I could possible put another injector in the middle of that channel. Oh. Just thinking, I could swap the order of the last two strips. They're being used to fill a run longer than could be reached with 1 J-channel. If I do that, then I think I'll have the longest stretch be just over 40 LEDs.
I'm not looking for really fast animations.
aka Larry
Eastern, NC
OK, this is a what I did in the garage and a question for the techs.
I was helping a friend install the factory MOPAR aux switches in his '23 Jeep Gladiator. It was a huge PITA, but we got them installed and working correctly. The purpose for installing the switches was to run the rock lights and light bar. He had also purchased a set of side marker lights.
His new marker lights are tapped into the factory parking lamp circuit. To access the wiring, you have to unplug the junction inside the left front fender well. This connector also has the wiring for the fender-mounted front parking lights and turn signals. Once unplugged, and subsequently reconnected, for some reason none of the lights on that circuit worked afterwards (right side works fine). We disconnected the battery for about an hour to finish up some other stuff, but once reconnected, the lights on the left front fender still don't work. :unsure:
For a related back story, I decided to change the front corner markers on my Jeep over the winter to a different style. FYI, the front fender lighting wiring is identical on mine ('22 Wrangler). After I installed my new markers, I had the EXACT SAME issue. I quadruple checked all the wiring, fuses, etc, did a bunch on online research (Jeep forums are almost always no help) and had no clue what happened. I was really puzzled how a super-simple plug-n-play installation could cause this issue, but I ran out of time and had to leave it in my shop overnight. FWIW, the battery was NOT disconnected at any point on mine.
I get up the next day and decided to start on the right side to see what might be different since I had not disturbed anything on the passenger side yet. When I turn on the lights to check out that side, somehow (magically) the driver side now works! W-T-F!? I did nothing to 'fix' it, but since it was now working I didn't really care.
Fast forward to this weekend and this same problem happens on my buddies Jeep. I have NO IDEA what causes this, but I sure as hell would love to know, and any help would be appreciated!
P.S. My buddy lives an hour away and doesn't DD his Jeep so I have no idea if his are also 'magically' working again today.
69charged
carberry, manitoba
The BCM on these truck is crazy. It will do things like that. I installed new LED headlights in my Gladiator and tapped into the turn signal circuit to have my halos flash orange when I turned on a signal. One side worked, the other didn't. I had to play around in the settings of the BCM with my AlfaOBD program and finally settled on the factory LED headlight and flasher setting to make it work.
aka Larry
Eastern, NC
I do understand the difference (as far as the BCM is concerned) when going from incandescent to LED. On my Wrangler, I have all LED lighting so no changes other than I wanted a different style. I literally unplugged the factory LED, installed my new LED, and the whole LF assembly stopped working until 24 hours later it magically fixed itself. We do have a Tazer on his Gladiator now, so we can access the menus you are talking about if that's what is needed.
nadogail
Coronado, CA
The technician from the garage door service company arrived and said that because of the nature of the problem and that they had recently replaced the torsion springs there would be no charge to get my door closed.
We did find that when the opener was installed it wasn’t done properly. He is working on it with new tracks.
kaymccampbell
Upstate New York
You'll be fine.
larry4406
Northern Virginia
Nice to hear that there are still honorable firms out there.
Wrench97
Southeastern Pa
The TIPM on those will sense overload or open circuits and shut the circuit down, there are no fuses for these circuits the system relies on sensing power draw and being able to turn it off. That said adding extra lights can be problematic either by overloading the switching transistors and causing early failures or by having them shut the circuit off.
Whenever I have to add lights I use the trailer light circuits if I can and add relays and fuses so the only load on the OEM is a relay control circuit.
The posts on these is more proof of the stupidity of modern vehicle design. just a bunch of "stuff" to go haywire and make it impossible for Joe average to even try to work on them. No added value but greatly added costs.
a computer circuit is less expensive than a ****** fuse? really? :withstupi
lolaetype
North Western Arkansas
I have a Harbor Freight drill press that does what I need a drill press to do except that there is insufficient distance from the chuck to the cross slide vise which adds 5" to the height of the table. I decided to extend the length of the pipe that the drill motor sits on by 5". I had a 4'' piece of exhaust pipe that tightly slipped over the existing pipe and modified second piece of pipe to match the diameter aof the existing pipe on the drill press. Pictures can probably explain it better than words.
Wrench97
Southeastern Pa
It allows the car to shut off just one light not all of them like a fuse would this is a plus, the stupidly comes in when you include the module in the light itself run 1 power 1 ground and 2 twisted pair network wires and the tail light becomes a $1500(Ford) module with a radar sensor to turn on the little light in the mirror so you know someone is passing you. Then when it gets cracked and water intrusion shorts out the network the truck won't start...
Beerhippie
Far NE Oregon
Believe it or not, probably yes. Maybe not just a fuse, but a fuse block? Yep.
I had another "fifteen-minute" job planned for today. A while back, I tried to shut off the water to our frost-free hydrant, only to discover that what I thought was the isolation valve for the hydrant shut off the water to the entire facility, but not the hydrant.
Today we had the city come by and shut off the water to the entire property so I could pull the stem of the hydrant and replace the valve **** at the bottom of it.
I got an early start. Getting the "head" of the hydrant off was a matter of heat, impact and a couple of BA pipe wrenches, but not bad, considering it hasn't been apart for over thirty years.
That was the easy part.
The stem, which should "just" pull right on out, didn't.
Time to improvise!
Hippie slide-hammer. Baling twine has nearly no stretch and works very well for this, but... the plumbing down at the bottom of that is 30-plus year old galvanized pipe... maybe beating the hell out of it isn't a great idea.
Plan B:
A hippie-improvised puller. This was much gentler... and didn't work, either.
The bottom end of that hydrant is five feet down, through old riverbed full of rocks and boulders, and I really don't want to have to dig it up, cut and replace pipe ('though I could then install a proper isolation valve) today.
I bought the rebuild kit for the hydrant, so at least I can look at what's down there and see that the "gasket" is a great big rubber stopper.
I rebuilt the head part and repainted it while I had it off. With new parts and the old parts clean and lubed, that meant that I was able to lift the purchase of the over-centering valve handle on the stem to provide more closing force on the big stopper when closed.
Sounds good to me, anyhow.
It works--and I think the fresh paint job really pulls the yard together.
Fifteen minute job done in less than four hours!
Sorry 'bout the crappy cell phone pics. It was raining off and on and I didn't feel like hauling the good camera out there.
Jgaz
Time to improvise!
Plan B:
I do like the “Hippie slide-hammer”
