Speed wrenches…anyone use them?
I
impactims
Speed Wrench =/= Speed Handle
Either way, the wrenches in the pic I posted is what I am talking about
neharr41
Southern Nevada
Never used them but always wanted to get my hands on a set. I’ve seen some older Snap-on sets that have one speed end and one flare nut end. Would be nice for hydraulic/pneumatic lines.
finn
The UP, God's country
I have a set, but rarely, if ever use them, and if I do, it’s usually the box end.
I always called what you guys are calling a speed handle a speed wrench, though. Always wanted one as a kid, but never bought one . Went straight to pneumatic , and then battery tools
olsenmotorsports
Chicago, IL
I use them in specific spots where otherwise we would need to use an open end. Complete game changer when you need it, but for sure not a daily use.
I could live without them, but once you use them and understand the application they are super nice to have around.
willf650
I had a Craftsman set of those years ago. Used them a couple times and sold them to on eBay. I didn't care for them.
Hannahranga
I kinda want to try them but suspect I'd A) never think to grab them out and B)the intersection of fastener I can't fit a ratchet on and also can't be snugged up by hand is slim.
I
impactims
Whatever they are called, no way for this boy. Those are a real knuckle skinner when they slip off - and slipping off isn't a matter of if, but when.
If that’s what has happened, then there must have been a significant load against the wrench. Lots of weight behind it. Which, as I understand it, is not how they are supposed to be used. You should break loose with something else, then if too much resistance to spin by hand, use these wrenches to speed up the otherwise tedious spinning out of the fastener, what ever type it may be.
Etchase
Hawaii
I have several varieties, because they are tools and a little gimmicky. Who could ask for more? Mine are in brand new condition. There is probably some industry where they see use. Anyone know what task that is?
DAWrench
Central AR
I agree with Impactims. They are very useful for their intended purpose. I have a few Craftsman that I picked up dirt cheap at a garage sale thinking they would be good to throw in junk drawer to cut or bend to make custom wrench. Turned out they work better than I expected. Just don't use to break fasteners loose
larry_g
oregon
I agree with this. These are stored right next to the crowfoot wrenches. Not used much but in some applications they are great. In the machine world they were great for reaching under a machine and blindly adjusting a leveling foot.
lg
KnurledNut
n/a
As with any tools, there are different designs and levels of quality.
I have a few applications for them where nothing else really works as efficiently.
After trying several brands, I found Facom to work the best.
53128000846_3630487c86_b-jpg.1939607
IMO, the absolute strongest design which exceeds even a standard open end is the old Craftsman Extreme Grip.
The grip those things have is unbelievable! The disadvantage, or advantage in some circumstances I have found, is they are long pattern. This makes it more of a specialty tool. But, yeah, none compare in raw strength to these.
They offered them in a combo version with the old clunky ratcheting box end.
Craftsman raised panel combination wrenches were a shorter pattern. The only long pattern version I am aware of was available with the speed wrench open end. I never understood why they didn't offer these with a regular open end.
The old Bluepoint Supreme RS series were a predecessor to the Snap-on version and worked quite well.
I have a set of these that are branded Lockjaw. I believe they are a later version as the jaw profile is slightly different, perhaps revised to work better. The stainless steel has held up very well in a nasty environment. These also have a thin profile that will work on jam nuts and such. A lot of good features in these.
In ending, I consider these specialty tools.
If you are expecting these to replace your regular open ends, yeah, you will be disappointed.
But for their intended use, many of them work quite well.
txvwnut
Bedford, Texas
If I remember it right when Snapon introduced them you weren't supposed to use the speed end for high torque applications, that's what the other end was for. They never appealed to me so I never gave them a try. A speed handle has gotten many turns put on it as that is/was my go to tool when assembling engines, started using a T handle lately as it takes u less room on the bench.
J.A.F.E.
Formerly Area 49 now Area 52
Yes, I use them in certain situations and like them quite bit, at least the Snap-On's. Impactims is correct they are mainly for running the fastener not final tightening or breaking loose.
rust in the eye
Chicagoland
If you guys complaining about skinning your knuckes are using these on tight fasteners you asked for it. Break 'em loose with the box end, pretty much as with any combination wrench.
That said, I have a few accidentally acquired but don't use them much, mostly because I work on a lot stuff with bolts that fight all the way off and know better. Working with new/clean fasteners these would be great.
Speed HANDLES I like quite a lot for running down lots of bolts, say as on an oil pan when assembling an engine.
I
impactims
Are those speed wrenches or open ends that grip....like an alternative to flank drive, RBRT etc.?
Or more of a hybrid between a flare nut wrench and an open end wrench?
jbltwin1
Godfrey, IL
I use my SPEED HANDLES a LOT more than I would ever use those wrenches. I alwas thought they were broke! I use my speed handles to run the bolts in on oil pans so they don't get away from me. Also use my 1/4" handle to get the side bolts out of the John Deer side covers. It's easier than getting long extensions. We used to use 3-3 1/2 foot speed handles back in the day to pull the spark plugs out without having to reach down inside the engine compartment. They were great when we DID tune ups. These days, you tune it up by buying a new car!
KnurledNut
n/a
More like if a modified open end like Proto ASD and a speed wrench had a baby.
Easier to place than a standard open end since it has short angled jaws that locate the bolt, but not a true quick wrench.
Ducky
Southeast, Alaska
I have a Snap on set that I used a lot when I worked on boats. I used them mostly to drop the lower units on Mercury outboards and for splitting the upper and lower halves of a Mercruiser sterndrive unit.
308guru
I've put them into use in production settings where the torque requirements were not very high, it's the same thing all day, and you can't fit any other pneumatic/electric tool. They are great in that application.
I would never have any use for them in typical maintenance/repair work though.
bonneyman
Desert SW
I have an older Snappy DOE with the Snake Bite ends. Nice for restricted areas where you can only use an open end but don't need to remove the wrench and re-install it to get another bite. The "ratcheting" action seems to help out.
I also have a pair of pressed steel models I use on bike hub cones.
olsenmotorsports
Chicago, IL
Funny I used my speed wrenches today. Air cooled Porsches have the worst bumper mounts. Through bolts buried up against the washer tank.
I’ve got a couple sets of them, the regular combination ones and then the brake line style
I’m a fan of the brake line ones as the open ends are so wide that they cover the entire surface area. Really improves your chances of success!
I’ve only ever tried the snap on ones. Interested how the other manufacturers compare!
lardy1
The only Snap-On tool I own is a speed wrench. They're the cat's *** for adjusting the clutch cable on a Harley Davidson.
I
impactims
So I got a couple sets coming.
Snap on with flank drive open end on one end and speed wrench on the other end.
Also ordered a set of vintage ratchet action speed wrenches. Pretty sure they are stamped stainless steel. Speed wrench at each end.
I
impactims
These showed up today. Used them a little just to be able to say I used them. And to see what they are like.
Overall, pretty cool. I like the way they work. They have coolness factor. Nicely made. USA made. Stainless. Worthy of space in the tool box for sure.image.jpg
Dig Doug
I’ve got these in sae & met
Thought they were cool and would work well
but never really used them
I won’t get rid of them they are mixed in w/ my craftsman wrenches that I never use….
lol
