Maybe drive roller for something? looks like O-Rings at the ends?
Maybe drive roller for something? looks like O-Rings at the ends?Maybe the part where he found them with a metal detector, so presumably buried and not rusted?You sure about stainless? Magnet stick very weak or no stick at all?
Very weak. It's been in the ground for at least 8 years, probably many more.You sure about stainless? Magnet stick very weak or no stick at all?
A chainsaw that uses 7/16" bar clamp nuts and a 3/8" spark plug?
A keychain saw!A very small chain saw?![]()
Yea. Didn't you read Champion spark plugs? For the little people.A keychain saw!
Widely known as a 'Nordic Saw'. I have 2 similar except they have proper chain with teeth. One is army surplus in a kit bag, the other was from Orvis and rolls neatly in to a small round tin for storage. It lives behind my Land Rover seat, and is very handy for occasionally clearing fallen tree branches.
I would guess not. Head looks too small to hold a ratchet. I figure its to adjust something big (1/2" drive), like a front end using a drag link socket, as you can't tighten with that tool.Does it ratchet?
Just 2 months ago my buddy brought one for me, and turned the spicket on when I was ready. I was in the crawl space at the clean out, hoping for no mess. It worked well for a clog through roots. No mess.Ah, the old Donkey **** clog blaster. Remember the first time a neighbor offered to bring it over to a friend's house to clear a drain line that was clogged with roots. She was mortified.
No, it does not ratchet, just spins. It was part of a lot of tools at an auction. The lot had no "theme" to its contents, so there was no clue there to help identify it.Does it ratchet?
I like Farmer J.'s observation if you see a way to lock the drive; am sure you have tried push/pullThis one has me stumped. The red handle rotates the 1/2" anvil that takes a socket. The chromed shaft is long and ends in a wedge. No markings to be found anywhere.
Thread in?I like Farmer J.'s observation if you see a way to lock the drive; am sure you have tried push/pull
There was a similar looking gimmick sold in car accessory shops in the 1980's. The shaft holding the socket had some kind of mechanism or dog tooth to lock it or allow it to turn free with the spinner handle. The idea was to remove hubcaps with the pry bar end, then slacken wheel nuts with the socket locked, then unlock the socket and spin the nuts off with the little handle.
Nice, that’s kinda how I was thinking it worked. So you can break the lug nut lose with it locked, and then turn it by hand using the wing nut.Thank you FJ. I took a stroll out to the shop to look it over again. The spinner handle does pull up and that locks the anvil. It's not spring loaded so you need to push it in and out to change function.
I continue to be amazed at the knowledge of the forum members.
Trammel points. For making a giant compass from a yardstick or scrap wood. Lots of other uses.Well, IF these were bigger and could clamp onto a 2x4 (could clamp 1-1/2") and IF I had a couple hundred of them....
I could clamp them to the top of my fence to keep the squirrels from using the fence as their highway
...darn stupid varmits running around on the top of the fence really pisses the dogs off
Otherwise, I don't know what these are used for
Stanley No.4
And hook 220 to it. Fried squirrel every day. lol. My wife loves to watch em.Trammel points. For making a giant compass from a yardstick or scrap wood. Lots of other uses.
Here's what you need for the fence:
Stainless Steel Bird Spikes - Full Row Bird Control Spikes | Nixalite
Protect buildings with full row stainless steel bird control spikes that deter pigeons and other pest birds from perching on ledges, signs, and trim.www.nixalite.com
It should take the squirrels fifteen or twenty minutes to figure that out.
Your wife scares me.And hook 220 to it. Fried squirrel every day. lol. My wife loves to watch em.
Anyone know what these are? Found them in an old toolbox. Markings say CA 1001-16. 3/16 AN455
Naive question, what’s the difference? I thought a rivet gun was an air hammer run at much lower pressure, like 30 psi. ThanksUsed in a rivet gun and not an air hammer.
That's a fine answer!An air hammer, in general, has a trigger that is either on or off, while rivet guns always have variable flow triggers. For instance, with a rivet gun, I can control the flow well enough to get a single strike. A rivet gun will also function over a much wider range of air pressures than an air hammer. Rivet guns are rated by size as well. They range from a 2x all the way to a 9x and beyond, with the number giving you the design rivet diameter it's rated for. There are a number of configurations as well for barrel length, handle style and body size. There is also a big cost difference as well. You won't find rivet guns at the local auto supply or tool store.
In aviation I have no doubt that's a important distinction, in trailer repair not so much.....An air hammer, in general, has a trigger that is either on or off, while rivet guns always have variable flow triggers. For instance, with a rivet gun, I can control the flow well enough to get a single strike. A rivet gun will also function over a much wider range of air pressures than an air hammer. Rivet guns are rated by size as well. They range from a 2x all the way to a 9x and beyond, with the number giving you the design rivet diameter it's rated for. There are a number of configurations as well for barrel length, handle style and body size. There is also a big cost difference as well. You won't find rivet guns at the local auto supply or tool store.
When we lived on the farm, we had squirrels electrocute themselves regularly on the top terminals of the transformer that served our place. This happened dozens of times during the years we lived there--quite often we would hear a bang, see a flash out the window, and sometimes power would go out. I'd go outside and there would be a scorched squirrel carcase on the ground under the transformer pole.And hook 220 to it. Fried squirrel every day. lol. My wife loves to watch em.
