Old Man Roger
Agent CampbellI melt down hard drives for casting. And I get paid to provide certified destruction.
I prefer my Barrett Light 50 at 300 yards. Good practice for squirrels.For me, destruction usually involves high explosives.........
Squirrels can shoot a Barrett? One more thing to worry about while lying awake at three AM.I prefer my Barrett Light 50 at 300 yards. Good practice for squirrels.
When they team up. They can do anything.Squirrels can shoot a Barrett? One more thing to worry about while lying awake at three AM.
You need one of those stabby sticks that Pines bought.Heating and melting, wiping, cleaning trying to revive the Prusa printer hot end. Slow going, wondering if it can be immersed and if the bits will melt off and float?
A few weeks back I put new front lower control arms on the Taurus. I used the loaded arms so it was a fairly easy process. I had the old arms laying around so today I decided to see how hard it would be to change the front bushing. I don't have any experience with that so a great way to learn instead of being under the gun. I managed to remove the old one in about 3 hours and I had to destroy the rubber portion of the bushing so I could get a hacksaw in to cut a slot in the outer metal piece - it was rusted in solid. Made enough of a slot in it to use the air hammer to peel it back enough to loosen it up. I'm not going to put a new bushing in it but I imagine it would be easier than removing the old one. A useless exercise on the face of it but lessons learned and experience gained.
The victim and what a good bushing looks like:
Honestly I don't think that would have helped. The bushing has a metal sleeve on the outside and a metal core with metal ends attached to the core. So you can't push just the bushing through the outer sleeve as it curls inward making the hole smaller than the end. It's not until you knock those metal ends off that you can push the bushing through leaving the outer metal in the hole. That's metal on metal and rusted in pretty good. It's not just going to simply 'push' out like a rubber bushing normally would.
We dont talk about pines stabby stick on this forum.You need one of those stabby sticks that Pines bought.
Inspected, cleaned, and lubed (free to me) antique/vintage Western Field break action, single-shot shotgun. Don't have much info on this gun. Western Field was a Wards brand among others and might have been made by Savage or Mossberg. More research is needed....not sure I'll ever shoot it. Might end up being a display piece....
It's not marked. At least I haven't found a mark that tells me the gauge. Unfortunately, my knowledge of shotguns is lacking. I'm open to suggestions on figuring out the gauge....Nice acquisition! Is it a 12 ga.?
Measure the ID of the chamber--the part the shell goes into. You should be able to find the measurements for various shotgun gauges online.It's not marked. At least I haven't found a mark that tells me the gauge. Unfortunately, my knowledge of shotguns is lacking. I'm open to suggestions on figuring out the gauge....
So stuffing the biggest shell you can in there and seeing if it works wouldn’t be a good idea?Measure the ID of the chamber--the part the shell goes into. You should be able to find the measurements for various shotgun gauges online.
In theory, that would work. Knowing what the barrel was made for, propellant- and load-wise, might be nice if you don't want to see what a barrel explosion looks like from close-up. I don't know if that's old enough to be a black-powder gun, but, if so, high-pressure smokeless powder would be a very bad idea.So stuffing the biggest shell you can in there and seeing if it works wouldn’t be a good idea?![]()
Just went to grab some screw drivers and my ground strap - partially assembled a PC for someone in the east coast
Since he doesn't care about aesthetics, I'll revisit the rear wiring and rip out all of the RGB daisy chain wiring that came with the case along with the controller
I'll also have to remove the HDD/SSD cage that takes up space and adds weight in the PSU section
Yeah, I'll poke around and do some measurements and look again for markings. This piece is low on the priority list. I also recently acquired a Stevens 620a Trench gun (12 gauge) dating pre WWII that needs to be shot. I don't know it's history, but it has all the U.S. markings on it, so know it's authentic. I'm looking for what the right loads might be best. I'm sure it's robust enough to take some abuse, but since it's got some value, don't want to abuse it too much. I acquire 'em to shoot, not live in a safe....In theory, that would work. Knowing what the barrel was made for, propellant- and load-wise, might be nice if you don't want to see what a barrel explosion looks like from close-up. I don't know if that's old enough to be a black-powder gun, but, if so, high-pressure smokeless powder would be a very bad idea.
There are also different lengths of shell with differing amounts of powder to consider.
There really should be some stamping on the barrel near the breech (usually) to identify the gauge, at least.
Wall-hanger is always the safest call.
. New batched showed yesterday, so I commenced with doing 2 more as that's my limit per day. I just hate doing these, so 2 a day is it. 1st up...
Those are beautiful pieces. Nice for them to be returned home to the family.An old friend of my passed father sent me a few of his wood turnings that he did, oh, 40-50 years ago
Ugh, I did that to my dad’s D14 Allis a couple years ago. What a messy, smelly task that was!Two day project, due to interruption, and waiting for the pump. Tractor tires can be filled with various liquids to add weight for better traction. Water and calcium chloride has been standard for a long time, but is slowly being replaced with non-corrosive, more environmentally friendly materials. One of the worst problems with chloride comes from ignoring minor leaks, and just adding air to keep the tire up. Eventually the rim develops severe corrosion and fails. On the other hand, chloride is cheap, works, and doesn’t give problems if you keep the tires in good shape.
My friend brought his tractor over, and we pumped out the fluid, removed and replaced this rotting rim. I’m sure the only thing holding one bead on was the rust. There was not enough flange left for the bead breaker to bear against, so we had to go caveman, and get out the old tire hammer. Fortunately the inner flange was intact, and the bead breaker worked, but not easily. The tire came off easily, because there was no flange to pry it over. The tube was rusted to the wheel, and required some poking and prying to remove.
Surprisingly, the wheel bolts gave no trouble. Bolted the new wheel up, installed the tire with a new tube, and inflated it. It took five tries to seat the bead.
Because I don’t do this for a living, I use a cheap rubber impeller pump to remove and replace fluids. The impeller gave up and had to be replaced before we could refill the tire. It took ten gallons more to refill than was pumped out.![]()
A larger table so you can work standing up would make your life a lot easier. Add some tunes and zone out.After playing with the firearms, the less fun stuff commenced....window screen replacement. The house is nearing 30 years old and the screens are all original. I like to watch the wildlife (squirrels and birds) in the backyard. It was getting annoying to look out and all you saw was reflective screen. Did the research and ordered this:
...already had this...
I have a total of 22 screens to replace...all 3'x2'. I originally ordered 100' of screen, but have fallen short. I don't remember if I even tried calculating how much I need or just F'd up.... New batched showed yesterday, so I commenced with doing 2 more as that's my limit per day. I just hate doing these, so 2 a day is it. 1st up...
...spline removed and screen getting removed...
....old screen completely removed and discarded....
....sizing the new screen....
...in position to install....
...new screen on right and old screen on the left....
....and the clear view...
...next...
...only 11 more to do......![]()
