Show your new tool arrivals
CHI_Tool&Die
Chicago, IL
Lots of new tools for the new year. 🤣Starting off strong by updating some stuff at work.
I ordered a 9/64” ADV hex bit socket and ended up leaving the Matco truck with the master 1/4 OptiGrip set. I’m still searching for the best hex bit sockets and I’m hoping either one will perform better than the ones I’m currently using.
Also ordered the Wiha hex and torx keys. The 8mm is jacked up and Wiha won’t warranty it so I’ll probably have to just buy a replacement. As with the hex bit sockets, I’m still searching for a great hex key set. These Wiha seem promising.
lund
I'm amazed Tekton runs 1/4 drive impact sockets out to 17mm. :thumbup:
Well ... I guess they want to have a lot of warranty requests for ratchet breakage if people are using their 1/4 drives for 17 mm on car suspension work!
I guess large sizes on 1/4 drive can legitimately make sense in very limited situations where you have an access issue on a low torque 17 mm. Sometimes I use 1/4 drive to snug thing up before applying final torque with a larger drive-size ratchet or torque wrench. The smaller size on 1/4 drive ratchets can help accessibility and speed things up.
YesIHaveAHammer
Saltus 1000 combination wrenches 17, 19, 24mm
New old stock, local. On the long side but not specifically long, to complement my Facom 440s (which are a bit short) just in these bigger sizes. The 440XL range does go up to 19mm, but these have certain attractions so it'd be a shame to have a lone 24mm. There is a 7-24 set but I've no need for it and there are better designs available nowadays. The choice of skips in that set seems a little odd for nowadays; 9 & 15 are included but not 16 & 18 (nor 20 & 23).
rust in the eye
Chicagoland
What am I missing here?
mdrawde
New Zealand
Ko-ken RSAS2405A, got the set for 74 NZD (~43 USD). Better polish and chrome, and a few thou smaller OD compared to the standard sockets.
Comparison to a standard 2405A socket:
CHI_Tool&Die
Chicago, IL
it’s cosmetic. The finish is completely different (it’s like sandpaper) instead of smooth like all the other Wiha keys. And like all the other German brands I have interacted with, Wiha told me that if it works and if it’s in tolerance then they won’t warranty it for non-detrimental cosmetic reasons.
The keys are really nice though beyond the 8mm and the holder is unbeatable for someone like me who is always using my hex keys. I’ll overlook the cosmetic stuff because of how much I like the keys overall.
rust in the eye
Chicagoland
Got it. I find it tough to refrain from casting aspersions.
Judging by price they they are quite proud of their product so the lackluster(no pun intended) Q.C. here surprises me, their attitude not so much.
lund
I have something very similar or identical to this. It is easy to use and helps narrow down poor start or battery life issues (I also write the install date on my batteries and become suspicious around 5 years). To me, it was worth the low cost not to need to lug a battery into an auto shop for a free out-of-car test. Usually when I work on one of my family's cars, I am also home with only the car that I am working on to make that a pain. So this is convenient.
neophyte
Pennsylvannia
Wiha has had the occasional quality control issue since the 1990s.
I never tried to warrantee the items, so have no clue how that would have gone.
I purchased from an industrial supplier, and didn’t want to bother the supplier over small items.
I just stopped buying Wiha for a while.
Monte
Germany
I have something very similar to this. It is easy to use and helps narrow down poor start issues. To me it was worth the low cost not to need to lug a battery into an auto shop for a free out of car test. Usually I would also be home with only the car I am working on making that a pain.
for a quick check its a good tool
Cheap chamfering tool from Amazon
Beerhippie
Far NE Oregon
Today's mail:
I threw away the bills and kept the good stuff.
The nut drivers are very clever:
I think they'll be a game-changer around the plant. I can't believe I hadn't known of these until last week, when someone posted this style here.
As blow-molded cases go, this one is nice. Metal hinge pin, over-centering hasp. Unfortunately, it's likely bound for the dumpster as I just don't have room for a case that's 80+% unusable space. I have some nice socket rails on the way.
All of this but the nut drivers is heading into the road tools bag.
lund
I have a similar Craftsman ball bearing tool cabinet. It is good but had some annoying plastic catches that you had to push drawers hard to clip closed. The hard push required for these to latch would jostle all the tools on close in spite of smooth ball bearing drawers that slide easy under load. That was a really BAD design. On mine, I took the drawers out, took off the plastic clip catches (think I also may have ground down some parts ... it was a long time ago and I am not sure), and then I epoxy glued some + - permanent magnets (calibrated for the right grab in terms of + and - strength and orientation ... was easy to do with standard Neodymium-Iron-Boron disc magnets). Now they close super smooth without shock AND stay latched with the magnet pull in close proximity.
The "grip-latch" version of these cabinets where the drawer rails tilt up to release a latch are super with no modifications. They do not have the slam close problem and also open easily. If you can find those versions, get them in preference. But the lousy retainer clips I described can be modified as I described to make them almost as good.
These Craftsman cabinets, if you dress them up and fix the problems, are very good values. They are not super heavy duty and lighter side sheet metal and frames. So they might not hold up for all day open/closed use and getting moved around in a pro auto shop or stuff like that. But they are good for even heavy DIY use for me. I do not move my cabinets much, but I have them very overloaded (tools stacked in every drawer) and they have held up well in that context while costing relatively little compared to pro grade cabinets.
SouthernIllinois
Astro Pneumatic kinda day.
Needle gun, blow gun and double ended 1/8” drill bits.
Went looking for a needle gun to deal with the thick a$$ undercoating on the Crusty Corvair. JB Tools had an AP on sale cheaper than the Harbor Freight Chief gun and I couldn’t say no to another blow gun and a pack of bits for $7.
Crazy fast and free shipping from JB Tools.
larry4406
Northern Virginia
I used the HF pneumatic scraper to take off the undercoating on my barracuda vert. Was loud (wore ear muffs) but it did a very good job. Helped that it was on a rotisserie.
SouthernIllinois
Nobody-named-Olli
pfbz
Picked up a 'DieHard' low profile 1/4" socket set yesterday... Not bad at $42, but was hoping it would be compatible with my Astro Nano 1/4" and Wurth 1/4" lo-profile (11mm wrench style) sets. Alas it is not.
Neither the Astro's or Wurth's will even fit in the DieHard wrench (close, but not cigar) and the DieHard sockets fall right out of the Wurth and Astro. Note that the Wurth and Astro are fully interchangeable with each other.
DieHard isn't a bad set, big range of sockets (4-19), but not being compatible with my other sets makes it kind of a skip for me. The case is pretty cheesy as well, kind of a hard. likely brittle plastic that you can tell will not hold up very well.
Pictured below, Ko-ken Zeal 1/4" (for reference), Wurth, and DieHard.
Video review should release on my channel later today or tomorrow if interested...
www.youtube.com/@toolsandtwisties
