From what I have found is massey vise was purchased by Morgan vise. The 36 clincher and the 160 Morgan are almost identical. Hollands has a very **** transition into the jaws. Very nice lines. I think Ridge tool bought Hollands foundry?I am intrigued by this. post pics when you get a chance. I've have a long standing hunch that Hollands, Yost, and early reads were all cast in the same place, either Erie castings (the EC stamp on most reeds) or by hollands. I can't find definite info on this, though. The early yost, hollands and reed 4 bolt stationary models are all identical as far as castings go. the spindles, and hardware were brand specific from the handful of each I've seen. And lastly, they were all located within 25 miles of each other. Therefore my initial hunch is that the 106Y might stand for the yost casting..... look at yost combo vises from the mid century to the 80-90's.....before yost changed the casting slightly and added an anvil. They are a spot on copies of the reed 31-34C's.. I'm talking about the castings. Yost jaws were bolt on, and the pinned pipe jaws are single pins vs the pre 1940's reeds that were threaded and a square headed jam nut held the pipe jaws in place. Again just speculation at this point.
What month would be zero?Does 026 sound about right for a date code on a 104?
Still trying to find the codes on the 105 and the 314.
Here are more pics of the 104.DC: if you can show full view of your 104 it might help us help you? Round hub or hockey puck style tell us a range and there are other things too that changed throughout the years for Reed.
Your date might be 10 26 with the 1 faded out?
Usually, the heavier stamping is an assembly number--meant to keep fitted parts together. The faint numbers are the date.Here are more pics of the 104.
I’m thinking maybe the 420 is the fate and the 026 May have been added later for some reason. There’s definitely no “1” worn off I front of the 026.
Thanks!
Because the same number is on both jaws…does that mean it’s an assembly number rather than a date?Did some cleaning up on the 314.
227 on both the stationary and movable jaws.
The date should also be on both--but often so faint you'll struggle to see it through any dirt or paint.Because the same number is on both jaws…does that mean it’s an assembly number rather than a date?
There are usually two sets of number. The one that's usually most clearly stamped is an assembly number to keep all the fitted p[arts together. The fainter one is usually the date--mo.yr. So I doubt that your vise was made in the 14th month of '41. 1241 sounds plausible, but the date stamps I've seen were on the jaw towers opposite the patent.Here’s my 203 1/2 with 3 patent dates. I’ve been slowly cleaning it and found 1441 (large and clear) on both jaws, but I haven’t found any smaller date stamps. However, underneath the dynamic jaw I found this potential date stamp. The best I can figure is that it says 12 14. But obviously the 14 is in smaller font which is strange. Did they put date stamps underneath like this? Any input appreciated!
Agreed that 1441 is an assembly number. I have not found any smaller date stamps on either side of the jaws. I’m gonna keep looking, but the one underneath the dynamic jaw is the only potential date stamp I found. Does anybody have a date stamp under their dynamic jaw?There are usually two sets of number. The one that's usually most clearly stamped is an assembly number to keep all the fitted p[arts together. The fainter one is usually the date--mo.yr. So I doubt that your vise was made in the 14th month of '41. 1241 sounds plausible, but the date stamps I've seen were on the jaw towers opposite the patent.
The date stamps are very faint. I found assembly numbers in the usual places, but the date codes are barely readable. I am letting a tiny spritz of oven cleaner sit and try to remove 100+ years of gunk so I can finally date my 405-1/2.Agreed that 1441 is an assembly number. I have not found any smaller date stamps on either side of the jaws. I’m gonna keep looking, but the one underneath the dynamic jaw is the only potential date stamp I found. Does anybody have a date stamp under their dynamic jaw?
Nice. I was able to clean mine up and get a positive ID on the date stamps as well.Success! After careful cleaning I found the date stamps. 122. January 1922? The other larger stamps were 141 (I goofed when I said they were 1441) Thank you everyone for your input and help!
"Sometime in mid 1958 standoff pads were added to the bottom of the swivel bases."I've thought for awhile now that I've seen date stampings on the Reed R series. Well, actually on a lot of Non R models also.
After having more than a dozen of these, I don't think they are assembler's stamps. I've had too many 44-58 date stamps that just seem too coincidental. So... let start a date thread to try and gather some pictures of date stamps.
When Reed went to the R series, they had a 10 year unconditional warranty and they had a 20 year warranty on the major parts of the vise. When they went to the R series, they had a forged nut instead of a cast nut. according to this sales ad, they went to a steel nut in 1942...
when sears sold the reed made vises, they offered a 10 year warranty... so, without a receipt how could you tell it was within the 10 year window??? had to have a date stamp. Reeds Warranty was 10 years from the date of manufacture for all cast parts and 25 years for all other parts excluding handles...
From what I've seen and when I started actually taking pictures of the "stamps" it seems that prior to 1954 the stamps where on the left hand side as you were standing in front of the dynamic jaw with the handle/spindle in front of you. after 1952, they were on the right side. Both the Dynamic and Static are stamped. after 1952, the stamp size is larger approximately 1/4" stamps where as the older stamps were approximately 1/8". Stamps are on the Lower right hand side of both the static and the Dynamic. usually the stamp on the dynamic is below the right side of the Pat number. the swivel lockdown hides this. these stamps are usually very lightly stamped and using a knotted wire wheel would remove or damage the stamping.
Maybe this post will evolve into the older reeds, but I'm not certain the stamps on those are related to dates. I have only had a handful of older non R series reeds and haven't been a solid evidence that the random stampings are actually dates. I don't have pictures of all of them, but heres a few...
Craftsman Built Reed 5185 (reed 203 1/2 R) 1/45 or 7/45 small stamp. LH side
Reed 104R 7/53 stamp LH side large stamp
Reed 214R 7/56 stamp RH side large stamp
Reed 203R 7/58 stamp RH side large stamp
reed 2C 4/44 date stamp LH side large stamp.
reed 1C 5/56 RH side large stamp
Reed 204R 6/55 RH side large stamp
Reed 204 1/2 R 7/56 RH side large stamp
Reed 202 1/2 R 4/46 LH side small stamp
craftsman 5185 (reed 203 1/2 R) 1 or 7 of 45. meatball style spindle
Reed 2C. 1 or 4 of 44. Meatball style spindle. interesting that this one has a cast nut..... which according to the later reed sales ad, should be a forged steel nut....
reed 203 7/58 hockey puck style spindle
reed 104R 7/53 hockey puck spindle
Reed 214. 7/56. hockey puck spindle
Post you R series date stamp pictures and see if my theory is actually a date stamping or not....
