Oil Filter Wrenches?
littletoes
NE Washington
OK, lets just say that just about everything out there *****, in some way or form, when it comes to working on/in the tight confines of some of these foreign jobs, and whatever is coming out of Detroit these days.
Tell me what you like guys! Tell me what you hate!
For me, the simple little "bands" that except an extension or a ratchet work best, the large socket "cups" slip, and jam on. I only have the KD Tools version, and yes, they ****. I have to pound 'em off.
My Dad gave me this little "three-wing" socket type of tool, IT SLIPS TOO. Junk.
Sometimes the only way is a very large pair of slip-joint pliers...but they are so bulky....
DrkMtnDew
well for most of the oil changes that i do and then come back for the next service don't need a wrench of any kind. but for the ones that Rambo put on i like the expanding wrench from Matco. if that doesn't work (only slipped one so far) then i use a Ridgid Nylon strap wrench. the nylon seems to works a lot better than the rubber strap especially when they get oil on them.
:thumbup:
air
I use Channel Lock Oil Filter/PVC pliers for my Mustang, and one of the 'socket' types for the wifeys ride.
crewchief888
NW indiana
for normal size filters, a use lisle wrenches, or a pair of bluepoint pliers type.
otc for larger filters,
large channellocks or a 24" chain wrench take care of the overtightened filters.
:beer:
Displaced Hokie
Western NC
I've usually had good luck with my Mac pair smilar to this, although I've seen some newer versions that look like they would be more agressive (a good thing).
jay50
I use the flex band type wrenches and caps.
On those really stubborn filters put on by an oil lube idiot, I use the Cman ratcheting 3 leg wrench, 20523. It has never let me down and well worth having in your home shoop:thumbup:
hotsam
Boxborough, MA
I just use a large pair of regular Channelocks...and if that doesn't work, I use the "stab-a-screwdriver-through-the-filter-and-twist" method.
kc-steve
Kansas City
He-he, yup the ole' "stab-a-screwdriver-through-the-filter-and-twist" trick works for me as well. But I always worry about stabbing a hole and still not getting the damn thing off though. Too embarrassing to have a car towed because I couldn't get the filter off. :)
Steve
williaty
On my wife's 2006 Saab 9-2x 2.5i (which is really a Subaru Impreza), the oil filter is up in a hole above the exhaust headers. I can JUST fit my hand through the hole but I scrape on all sides. Obviously, that doesn't work when the header is hot. I use a wrench with 3 fingers that grab the filter. When you rotate the center portion of the wrench counter-clockwise via the 3/8" drive, the fingers pull together and crush the filter to grab it. I put that think on top of a 6" extension, and the ratchet will just barely swing below the headers. The wrench looks like this, but it's not this brand and mine has teeth on the fingers rather than rubber gloves.
jeffk14
GA
If you can get it on the filter, the one pictured will get ANY filter off.
Tatsuya
Seattle, WA
My dad's Toyota pick-up, brother's Acura TL, and my Toyota Corolla all have filters that mount vertically. I prefer the cap type wrench but have to use a Craftsman "spider" type filter wrench on their vehicles. I don't like it but it works.
resize
My other brother's Honda Accord has a filter that mounts horizontally which is awesome. Way easier to catch the threads and I'm able to use my Channellock filter pliers. I love those pliers.
fflintstone
MOFnowhere Mi.
The tool “drkmtndew” pictured is what I use 95% of the time. I use the tool “displaced hokie” pictured 4% of the time and for the remaining 1% I use the tool pictured by “jeffk14”
I also have the socket kind but rarely use them anymore.
claymont
CLAYMONT, DE
A piece of 6'-3/8" hemp rope will get almost any filter off from anywhere. Two or three wraps, give it a tug, you're good to go.
Muffduster
Arkansas
I don't use oil filter wrenches. A good hand tightening will only get tighter over 3,000 miles. If you have to use a wrench to get it off, then you put it on too tight.
truckdriver
Miami,OK
bart1
Alabama the Beautiful
Perhaps I should show you the second filter on my Porsche 993 - it is vertical, up in a hole. You can get fingertips on it, but that's about it. I use either the socket type or the three finger type if it's being stubborn.
diesel research
gulf coast, TEXAS
Some members are not only removing their own oil filters, but customers...
For other members who state "____ tool WILL get them off" I am living testimony that most of those tools are not as sure fire as one would believe.
I like my 215 channel locks when they fit. I like my nylon strap (the heavier duty model, not stamped steel) I also have a cheapy band that works sometimes.
None of them work all of the time. Not even the screw driver method. I knew it would happen one day, and it did. Sheered the whole filter canister off, leaving sharp edges all around, still threaded to the base. The chisel started to peel the remains instead of drive it off, but eventually worked. Coulda been in hot water had that not worked. No it was not my truck.
I have also had straps crush the canisters, which is what lead to the failed screw driver method. Combination of over torquing and cheap oil filters.
tpolley
kansas city
When I was in the oil changing business I used this setup 98% of the time. The other 2% were diesels with big paint can size filers or cartridge filters. The 3 foot long extension was for f-150's with the 5.4 and windstars with the 3.8. I tried the oil filter pliers and the strap wrenches and I could never get them to fit in the tight spaces and they usually ended up thrown across the shop.
kab00m
FL
What is the part number for the channel lock plier? And which brand three fingered expanding wrench do yall use?
tpolley
kansas city
I would seriously stay away from oil filter pliers. They're difficult to get in small places. They require a lot of hand force. When they slip off you smash your fingers. I've used 3 jaw expanding wrenches too and they don't work that great. I've found that the cup style I pictured above works best. They come in 2 sizes and cost about $12-$15 a piece.
airbatica
I use the cap type with a 3/8 socket hole in them. Found one that was specifically designed to fit on the OEM filter (Motorcraft FL400s). Which just happens to work perfectly on my Saturn and my Ranger. Also have a band type for the genset.
Elroy
kentucky
If you have a "*****" filter then this little jewel will flat take it right off:
The "band" needs to fit the OD of the filter. This particular wrench only fits the old time full size filter cans. Like a PH8A or other similar size "can". Elroy can assure you though, if it fits, the filter is coming off!
These have been discontinued for several years. Make that a few decades. Actually Elroy broke his at one time. Presented it to the Snappy man and he just laughed real hard. Long discontinued.
Elroy didn't pay attention using it once. Didn't have it fully pushed up on the filter can and twisted the spring and broke it. Elroy fixed it with some rivets:
I can tell ya, that blue tempered spring steel was a ***** drilling. It's good to go now but most vehicles today have the small filter cans so this tool now see rather limited use. When it fits the can, this wrench has NEVER failed :thumbup:
KEH
I got the strap wrench like jeffk14 showed to take off the hydraulic oil filter on a farm tractor with front end loader. The filter wasn't real tight , just in a very awkward place to get to.
KEH
CBradio
Hampton Roads, VA
Got a pair of the harbor freight plier type tool. I ground some of the 'teeth' into 'points' and have never slipped off a filter.
woody 73
The Great State Up North
The one with the square tube and the cotton sling has never worked for me,somehow the can always gets crushed.
On my current car the only tool that works is the cup type tool.
Facom at one time made a steel band connected to a round handle and it had a knob that when you turned it the band got tighter. I think no longer made but that was the best tool I ever used;mine developed legs and took a walk!
davidj
Georgia
I like the filter pliers the best. they have always worked for me. If you have the room id go with those. I have some from HF and they work great on my truck, but they didnt fit the filter on my brothers mustang. the jaws wouldnt close tight enough.
JayL
Manila, Philippines
We do commercial oil changing and this type of kits work for us well. IIRC its made by WolfHead.
Toptul makes a smaller kit too but compared to aluminum Wolfheads their stamp metal looks cheesy.
eurokid
Tacoma, WA
I have this AST oil filter wrench set. They are very high quality and I've never had any problems with them sticking or jamming on a oil filter. The bigger cups are cast aluminum, one of them is steel but It's nice and thick heavy gauge steel. The smaller ones are forged steel, not cast like some of the cheaper stuff.
