Bevis
so what became of the issue with your neighbor on the setbacks and the wall??
Congrats, your shop is looking fantastic! I thought you said it snowed? Guess we get more up North, we wouldn't call that snow.
So do you still need the variance for the breezeway vs. second electrical meter? Or has that been taken care of as well?
Or do you now have to take down the breezeway for the electrical inspection?![]()
I'm thinking road trip. You are buying the beer, right ?![]()
Why did the permit require a breezeway?
Looks great!
I just had the same lift (SPOA10) only in red, delivered last Fri, but have not been able to wrap mine up like you before our crappy weather![]()
How about some pics of your place? Surely we can get you a thread going, can't we? I'd be interested in seeing some more local stuff
Herb, you need to give up all the off roading and just build garages. Nice work!
I'm using a half dozen (and will be adding 6 more) of the 8' Pro HD cold weather ballast units. Got them from the local home depot, they are about $54 and you can get a pack (16) of the high output bulbs for $89. They put out some serious light. I put 2 fixtures in the house carport as well, because I get so sick of houses (even high dollar ones) with one or two 60w bulbs for the entire garage. In any rate, worth a look if you are at that stage.
5) Everything on the lower 48" will get covered by corrugated metal (another idea swapped here, thank you).
We just decided to use it in our shop when we were having a planning meeting this past Friday (we are using it in the common areas of some loft style condos). I thought I was an innovator.
I thought I invented the corrugated metal wainscoat.We just decided to use it in our shop when we were having a planning meeting this past Friday (we are using it in the common areas of some loft style condos). I thought I was an innovator.
No you're not. Better to have too much than too little. I hate working in garages where you really cannot see what you're doing. Better to have it so you can turn it into an OR!!!A couple of notes on lighting:
1) I KNOW I'm doing overkill here, but I HATE not having enough light to work by.
FYI, each of those outlets is either a 2-gang quad receptacle box or a dedicated 50AMP 240V welding outlet. On some of the longer runs (like the ones on the center and far right walls) we put 2 welding outlets on the same feeder, it would not be common to be welding on opposite sides of the same wall, but the extra positions are nice. #6 wire is FREAKIN' expensive these days!!!
I think Bluesman wins the award for having the most expensive set of sawhorses.![]()
