clark_nicholas
I looking a buying a new set of pry bars. Is it worth the extra mony to buy brand name, or will the HF work just as good?
The Cman Pros I bought in the 5 pc set were $48 when I got them a few months ago. Looks like they don't even offer them anymore...kinda a bummer as those were a smoking deal.
There is the 3 pc still available:
http://www.craftsman.com/shc/s/p_10155_12602_00943288000P
Use the Sears site, it's not great but better than their craftsman tool site....
I was mistaken earlier, it's the 5 not 4 piece set....wish I had gone that route but got the in store 3 piece set..
http://www.sears.com/shc/s/p_10153_12605_00947410000P?prdNo=2&blockNo=2&blockType=G2
So since we are talking pry bars, anyone recognize who might make a bar numbered "5517" and "USA" (no other markings) and about 14-1/2" ling?
Every shop should have either a 30 inch OTC or a Klein, the guy that tuned it knew the exact angle to put on it and they are tough. Most of the time a small shop could get by with most anything but there are occasions its just the right tool.I have OTC sleever bars,
diesel_research,The snap on bars are really the top of the line deal.
Especially since they are gonna hit the $99 special soon enough.
Everyone says ____ is good "enough".....but I haven't really cranked on them. Nonesense. The whole point of a prybar is to be cranked, beat, reamed on.
Wasn't born with the knowledge their prybars are best, that came through a lot of trail and error and asking around.
It didn't take long to pick one up and be able to feel an actual difference.
You wouldnt think so until you have one.... then all the guys in the shop ask to borrow after they bend their screwdrivers.do you find you use your 8" pry bar very frequently?
diesel_research,
Have you ever used Mayhew Dominator Pry Bars before? No, I couldn't find them any dominator stuff until a few weeks ago. I was disturbed to see the USA with global parts label and loosely/poorly assembled handles. Visibly loose, so I didn't want to pound on it with a hammer and risk stuff flying. The shank end looked/felt like it was up to the task.
Also, do you think Snapon uses or specs a better alloy or heat treatment to make them better? Compared to who? I have no idea.
I don't know if Snapon is an original manufacturer for their pry bars or not? Lots of speculation going on here.
Also, do you find you use your 8" pry bar very frequently? MOST DEFINITELY!!! This is my favorite one because it tackles those light prying jobs that you used to break cman/stanley flat tip screwdrivers with. It also works for light duty chiseling. I am not sheering bolt heads with them nor carving granite, but it works quite well for a bit of weld slag, panels/covers stuck with adhesive, etc. Even works as a punch sometimes when a pin or ***** punch is not appropriate.
I probably use it more than my 18". My 18" was my next most used one, although the 24" still got plenty of use. Someone stole my 18" so now most all my prying and banging and scraping is done with the 8" or the 24". I find the 12" personally rather useless, and I believe it is completely unused after nearly 2 years of owning them. If you can only own 1, get the 8" and make your screw drivers last longer. The 18" is likely the next most useful.
Those hard handles are also wonderfully designed.
dieselresearch,
I have recently purchased two Mayhew Dominator sets from tooltopia with links to them in a previous post earlier in this thread. I can vouch for those particular sets in my possession and there is no looseness at all. The grips and their striking caps are firm and tight. I haven't used them yet though. You can read my post above but I really liked the grips in comparison to the CMan Prof Pry Bar grips.diesel research said:Have you ever used Mayhew Dominator Pry Bars before? No, I couldn't find them any dominator stuff until a few weeks ago. I was disturbed to see the USA with global parts label and loosely/poorly assembled handles. Visibly loose, so I didn't want to pound on it with a hammer and risk stuff flying. The shank end looked/felt like it was up to the task.
I was thinking Mayhew primarily. I knew it wasn't likely you'd know the answer. But in your post you'd mentioned trying a lot of them, so thought you might at least have given your impression of the bar steels' ability to hold up to use/abuse. I agree, that pry bars normal use is rather abusive.diesel research said:Also, do you think Snapon uses or specs a better alloy or heat treatment to make them better? Compared to who? I have no idea.
Thanks.i realize this was a question to dieselresearch but i have used a Dominator before and it was a really good bar. it was a very sturdy bar that took a lot of abuse, as prybars are intended to do. the only reason i didn't get one was because i was able to find my 48'' SO for $75. if it came to pushing and shoving i don't think either one is better or worse than the other.
