Craftsman table saw... Vintage???
Bad Jackson
Montana
How old is a Craftsman table saw model # 113 22452? It looks old to me, like 70'sish. Its $200 on craigslist montana. Good deal?
Thanks.
Munsk.
Jim85IROC
I just looked up that ad you're referring to. I'm no Craftsman table saw expert, but based on the pics, that looks like an outstanding saw for the money.
Red Leader
Denver, CO
Thanks.
Munsk.
Munsk,
If you have that number accurate, 113.22452, you have the exact same model # as mine:
$200 will be cheaper than mine after I picked up a motor mount and motor for it. Did yours come with a belt guard? If so, I'd give ya $50 for it:D
These saws were introduced in 1954 under King Seeley manufacture (code # 103.2xxxx) then were made by Emerson which denotes the 113 code. Production ended around 1966 or thereabouts. Given that yours is an Emerson (like mine) it was probably made in the 1960s. Did yours come with the original blade guard? If so, those are worth their weight in gold and you could probably recoup half the cost of the saw.
This saw is going to be my 'mainstay' 10" saw in the garage. Everything I have heard about these saws from owners of them is that they are an absolutely fantastic, well-built saw. The guts are mounted to the underside of the table, which while it makes alignment a little tough, it really is the most accurate and vibration-free design when you think about it, engineering wise. The trunnions are solid cast iron and the saw really has no deficiencies. Most report that the saw very easily cuts glass smooth.
Need some pictures!!!!!!! :)
porphyre
I, on the other hand, would probably have an issue paying $100 for it.
Although it looks like a cabinet saw, it's really your standard enclosed base contractor style saw. The motor is hanging off the back and, as Red Leader already mentioned, the trunnions are attached to the table, rather than the cabinet as in a proper saw. It's also got the cheesy webbed wings.
You can buy an Emerson manufactured CMan saw equal to this on Craigslist for $75-150 all day long in most major metro areas. It simply won't have the enclosed base.
To turn it into a high performance saw, you'd also need to spend $100+ on a fence and get a blade guard that incorporates a splitter.
If you're going to be using it for "serious" projects - ie presents for friends/family, built-in cabinetry for your home (that you'll have to look at day after day) - then I would pass on this saw.
mrbreezeet1
Moundsville, WV, 15 miles South Of Wheeling WV
I'm afraid I don''t agree, quality work can indeed be done on that saw.
What is the matter with this chimney cupboard I did using this saw?
Also an Emerson manufactured CMan saw, more like mine will have cheap plastic handwheels, not the heavy duty metal ones shown on Red Leaders saw.
You need to go get it if you think you want it IMO it won't last long.
Red Leader
Denver, CO
If porphyre is right, I'll take it off your hands:D
I own both this saw and two Unisaws, and I do prefer the Craftsman by design. A lot of folks seem to believe that a cabinet mounted internals automatically infer superiority to a saw and some designs this may be so, and some designs not so. Having owned both a 1960s contractor style Craftsman bench saw and this cabinet/floor saw, the two are very different. The 22452 has big, solid cast iron extensions, acme threaded table raising/elevation gearing, and overbuilt castings. Even with that said, some folks have been knows to get zero runout on the arbor and arbor flange of even just the contractor style bench saws. And even then this saw is in a different league than those saws, which tend to use pot metal in some of the internal parts, including the trunnions.
There has been many a discussion on the 'mounted to the cabinet' and 'mounted to the table' debate, with some choosing a specific camp and writing off everything else. Using both, I don't hate either, but if well built, like the Craftsman 22452 or say the General 450 12" saws, a well-implemented 'mounted to the table' has very few equals, as it displaces vibration and allows for much less tolerance stacking, as it relies on the direct connection to the table/surface unit, instead of relying on the location of the mounting points on a completely separate, sheet metal cabinet.
Another hot debate was the use of the term 'cabinet' to refer to a saw with internals still mounted to the table vs the actual cabinet. I guess you could say I am in the camp that uses that definition to refer to a saw that has an enclosed base that extends to the floor, so it is more of an identification point rather than a technical definition.
You can visit the thread here and see the various viewpoints and discussion/debate that follows:
http://owwm.org/viewtopic.php?f=1&t=106403&hilit=craftsman+cabinet
The webbed extension is cheesy, I'll give you that. However, that is not the correct extension that goes with that saw. The correct extensions that originally came with this saw, while still open, are big, hefty, cast iron and nothing like the rough cast aluminum extension show in my photo above.
The fence for this saw I like much much better than the Unisaw style fence, having used both. It is heavy cast iron, weighs at least 20lbs, and is smoooooth. It doesn't have the wobbily factor that the Uni fence has.
All in all, it comes down to performance, and how well the saw cuts. While I have yet to do any extensive cutting with my Craftsman 22452 saw, every single owner I've talked to who owns one is mightily impressed with its cutting ability. When I get things all setup I'll be sure to do a lot of cutting with it and report back in my garage build thread.
Mandres
I think the saw is easily worth $200; even though it's designed more like a contractor unit. I would much prefer it to the 1990's era contractor saws I see for similar prices on CL around here, and they're all capable of doing good work if you take the time to properly align everything. Not to mention this model looks killer with the art deco design cues.
Having adjusted a few, I'll take cabinet-mounted trunions every time, but you won't find anything in the $200.00 range that has 'em. This would make someone a great first saw, but seriously consider adding an aftermarket splitter and blade guard (features that are standard on new saws now). A fence upgrade would be nice too, like a Delta t2 Biesemeyer clone for ~$150.
Super Sport
West Michigan
If it's listed for $200, see how far down you can get them. Bartering is expected on Craigslist, and many people list items for higher prices than they expect to get. If it's in really good condition $100 would be a great deal I think. $150 certainly wouldn't be too bad either.
porphyre
Red Leader -
Well, you've got your opinions and I've got mine. It just seems that every modern manufacturer of professional grade 3hp & 5hp 10" table saws holds the same opinions I do. :D
I wouldn't buy that saw for $200 when modern, used, quality contractor saws are available for $50 more and you can get Delta T2's for $150. Used cabinet saws can be had for $500-$1000.
Also, I'm talking about modern fences. A Delta T2 or a Biesemeyer. I have never, EVER, seen one of those fences be "wobbily". That's even referring to the ones installed on the floor demo models at Rockler and Woodcraft stores that have every Joe, ****, and Harry messing with them.
Red Leader
Denver, CO
Red Leader -
And such is the beauty of life and what makes the world go 'round:)
I will say that if a table saw can achieve glass smooth 'glue line' cuts, whether it has its trunnions mounted underneath the table or in the cabinet makes little difference to me. I will say that historically, the Delta Unisaw became extremely popular due to Delta's marketing, their relationships with schools, and there expansive manufacturing capability. It quickly became the 'IT' saw and when you look at most of the cabinet saws out there today, they are copies of Deltas design, with slight changes (true with their bandsaws as well). The fact that most production caliber cabinet-style saws use cabinet mounted trunnions doesn't discount a separate design if that design can achieve equal/better results. I will say that a LOT of it comes down to manufacturing quality and the table mounted trunnion design has been soiled with many cheap saws that were terribly executed.
For an exceptional example of table mounted trunnion saws, the original Canadian Generals are just about as best as it gets, and built much more heavily than it's Delta or Powermatic counterparts.
Still...if someone wanted to give me a free 'cabinet-mounted' saw...I'm sure I'd take it:D
Maybe I'm just jealous that the OP has to opportunity to pick up that saw, more complete than mine, at a price that is lower than mine:lol_hitti
To the OP - if I was you - I'd GET THAT SAW!!! You can retrofit a blade guard/splitter on it if you want (even though the picture of the saw shows a modern blade guard on it)...not to mention the extra 6HP 220v motor!
Lively debate guys:thumbup:
Stuart in MN
Minneapolis
Not in my major metro area...contractor saws are generally in the $250 and up range, cabinet saws are mostly nonexistent.
Bad Jackson
Montana
Thanks for everyone's help. I think I am going to buy it, I just won't get the opprotunity to go look at it until Sunday now. I hope he doesn't sell first. Mostly because its affordable and it is a pretty good saw... and also because its vintage!!! Lucky Me!!
Thanks again.
Munsk.
mrbreezeet1
Thanks again.
Munsk.
did he say he'd hold it for you?
Maybe you could pay pal him a deposit to hold it?
Red Leader
Denver, CO
The handwheels on this saw are it's one major downfall. They are cheap, hollow pot metal. The ones on that saw actually look fantastic, but be aware that they are easily broken - I would definitely check them once you see the saw in person and inspect for cracks. It uses a proprietary mounting system as well, so you can't just swap out wheels without some machining involved. It is possible, however, with the right tools, to use a different wheel.
I believe all of them, the King Seeley and Emerson versions both used these wheels.
Other than that, the saw has no major issues. You might have to replace the bearings (I know I will have to eventually). Just check function to the best of your ability. The saw does transport well. I would advise a pickup/minivan/hatchback/anything that will keep you from taking off the table - it is heavier due to everything being mounted to it and requires an elaborate lift out. I lifted it out and put it back in myself and will NEVER do that again (not worth risking back injury).
Good luck!!! Remember - we like pictures!
Red Leader
Denver, CO
I know the saws you are talking about, and you are right. We've got them in the Denver metro area. There are, however, some major differences between those saws and this one. One of the biggest is the trunnions. The trunnions on this cabinet style saw are big and cast iron. Most if not all the trunnions on the contractor style saws are pot metal. The extensions on the contractor saws are those cheap flimsy aluminum ones or if they are cast iron, they are rough. Some of the newer saws have the stamped extensions, which I don't really like either. The 22452 has heavier duty cast iron extensions. Everything on the 22452 is overbuilt compared to the contractor saws. Even then, some of the older contractor saws (not all) are fantastically accurate and many built homes and more. Probably more than half the contractor saws on C/L are imported. I'm not sure when that happened but there was a huge quality shift that happened in the power tool industry and it happened around 1959/1960 and continued to go downhill. You see it in Craftsman, Delta, DeWalt and others. Some of the designs stayed the same but getting into the 1970s and 1980s most everything changed.
You do make a good point, however, about some of the elements of these old saws that stand to be updated. This saw, along with the Unisaw, is a great candidate for a Biesemeyer fence system. I'm going to use the stock fence until something convinces my to go with a bies, but it would definitely be an upgrade. A modern blade guard/splitter as well. More powerful motors are an easy swap, since the motor mount on the back accepts most motor mounting plates. I like the fact that it is heavily built, 100% American made, and can easily take upgrades to modernize it. Even though I am a huge Craftsman fan, I'll be the first to admit that they put out some 1st class junk. However, this saw, after seeing it, inspecting it, and having to move it (haha), is different.
porphyre
Ha ha... in that situation, trunnion mounting makes little difference to the wood either... a glue line is produced by a quality blade mounted to a low run-out arbor. You can cut a glue line with a Skil saw and a Bora guide.
Well..... I think the saw market is mature enough that you can discount the table mounted design as inferior. The market has spoken. Think of it as disc brakes vs drums. Drum brakes are still used on new cars. Economy cars. Could you get a table mounted trunnion design to work as well as a cabinet mounted design... perhaps. But how much extra effort would you have to expend and what would the compromises be? How about cost? It really IS possible to build a better mousetrap. Making it affordable is the hard part.
Why don't we talk about direct drive jobsite saws instead.....? :lol_hitti
Red Leader
Denver, CO
You make some pretty good points. The market idea is tricky though, because popularity doesn't automatically equate to superiority. The market is also flooded with import tools because that is what the market has spoken. Can quality be correlated with trends?
My argument: I see a table-mounted saw of equal quality to be slightly superior to a cabinet-mounted saw of equal quality because the cabinet-mounted saw usually has its table bolted on to 4 corner tabs of the sheet metal cabinet which rely on the levelness of the sheet metal and the welding to align to the blade. I have seen examples of the sheet metal tabs that hold the table in alignment to the blade become bent or, if taking a load from above, become easily damaged while the table is still attached (mild sheet metal steel):
file.php
That being said, I am inclined to agree with you. I think 99% of all table mounted saws are **** compared to the professional woodworking quality cabinet mount saws. However, there are some table mount saws I would consider superior (in terms of rigidity, precision, able to hold true) to
some cabinet mount saws:
file.php
The saw in question:
...and visa versa. I suppose my true argument is not one of product, but of engineering. I think that the armature that controls the blade has a better chance of making a better cut if directly mated to the precision machined surface that the wood rides directly above than securing the whole shebang to sheet metal tabs that act as a 3rd link between the blade and the table.
I'd love to hear your thoughts on why you have your perspective, I sincerely do:)
And at the end of the day, there is a lot of respect that goes around and we are all still friends:beer:
-Dave, who just used his cabinet-mounted-trunnion pos Unisaw to build his workbench cabinets:lol::D
rsanter
visalia ca
I have had several table saws over the years. Currently I have a cabinet saw and an older high end contractors saw.
I think the deal with the cabinet mounted trunion is that people find it easier to dial in the setup for true and accuracy. That is not to say you can't do it on a table mounted setup it may take a little longer
Bob
Red Leader
Denver, CO
Bob
And that is the one HUGE advantage that the cabinet mount has over the table mount, by far.
Bad Jackson
Montana
Well, I spoke with the seller last night, and I have no way of knowing if I have "First Dibbs" on this saw. Unfortunately I cannot go look at it until Sunday due to babysitter logistical issues. I think I was first to inquire about it, it hit CL at 816 on Wed night, and I emailed him at 851 the same night. Roughly 30 min later.
I spoke with my Dad LN to see if he wanted to go to Helena to look at it with me and he was excited to go along. He also said that my Grandpa had a vintage, 50's Craftsman Radial Arm saw that I could have to go along with this one. I think that they will look great sitting next to one another in my Garage. It seams as though I may have a mini- 50's Garage of my own here... mostly on accident. The enthusiasim for vintage tools on this site, especially by Red Leader, is contagious and has easily spread to me. I hope that this is not yet ANOTHER hobby that I am compelled to funnel hundreds of dollars into, or maybe I do.
Weird how things work out.
Munsk.
Red Leader
Denver, CO
Munsk,
I'm happy that it sounds like it is still there for you! But the best news is that sounds like it should be a great time with your father, which is where things really count.
What can I say? I am passionate about old tools, especially old Craftsman:) I know that they are not the 'best' in every category and they did put out quite a few 'duds' in their time...but I'll tell ya...they made some real gems. For a 2-car garage like mine where throwing in a 36" Yates snowflake bandsaw or an Oliver 60D dual arbor mega saw (which are heavy, industrial machines) just isn't feasible, compromises on size/capability are made. If you are going to do so, why not do it with some style?...
http://vintagemachinery.org/photoindex/images/9368-E.jpg{?IMG}
It has been a very fun adventure thus far. Welcome to the slippery slope:)
Red Leader
Denver, CO
Munsk.
About the radial arm saw...I'm curious, does he happen to know the tag's model # on it? If it is a 113, it is Emerson made and most likely a power bronze saw (which, if it comes with the bottom 3 drawer cabinet, is a nice find) or if it starts with the code 112, that means it is a Parks saw which are more rare and pretty cool.
Bad Jackson
Montana
First off Red Leader, Those are some VERY NICE Pieces! The bench grinder is my fav!
As for the Radial Arm Saw, I do not know which model it is, but he did tell me that it DOES have a cabinet base... If that helps. Unfortunately, things in my world move slow. I probably will not get the RAS until spring or summer as it is in another town and is burried behind some stuff.
As for Craftsman, it is of my limited expierience, that the older the better. As with MOST things!
Thanks for all your help.
Munsk.
porphyre
Ug, I just had a nice reply typed and hit backspace at the wrong time and lost it.... :(
My opinion is that the manufacturers could not engineer/manufacture your hypothetical "improved" table mounted saw within the price points demanded by the market. Speaking plainly, manufacturers decided that if a table mounted saw cost as much as a cabinet mounted saw, the market would choose the cab saw due to ease of adjustment. Manufacturers dictate what's on the market, then the market dictates what sells. Look at Europe with the sliding table saws...
file.php
Never seen a cab saw bent like that, unless it was dropped. The steel used in cab saw chassis is generally 1-2 gauge thicker than what's used in table mounted chassis due to holding the weight of the motor, trunnions directly, also having to handle drive torques and blade adjustment forces. My Ridgid contractor saw starts bowing the chassis out any time I get more than about 40* bevel.
Anyway, all that weight keeps vibration down. Cab mounted trunnions put the vibrations into the cab instead of into the table. That's why so few contractor saws pass the nickle test.
Bull
Red Leader is enhancing my appreciation of vintage Craftsman aesthetics, big time.
Red Leader
Denver, CO
Man, I hate it when that happens!
Good point about the vibration - when I get my Atlas saw together, I'll try and do some nickel/penny/dime tests and see how it compares to the Uni. Then again, my garage floor is probably the worst for that kind of test:lol:
About the tabs, the picture I show definitely was a 'extreme' case. More common are bent tabs or the tab plate weld breaking. The main point was that with a cabinet design, it attaches the cutting surface to a welded up sheet metal surface vs the machined underside of the table.
Its pretty amazing to see something like an Oliver pass the nickel/penny/dime test while turning on, cutting wood, then turning off.
That's always fun to watch:)
I think we can agree that if any saw is built heavily enough and precise enough, vibration/accuracy won't be a problem with any design.
When you mentioned the fact that sheet metal is thinner on table mounted saws and that therefore contributes to flex/noise/vibration/etc, I think you are probably referencing newer saws, like the Ridgid you mentioned. One particular saw, the Darra James 95 (1940s) is a table mounted design with a floor length cabinet. I had heard that they were built pretty stout. I went to go check one out a few months back (didn't end up purchasing it) but still had a pretty good look at it. It had the thickest steel cabinet I'd ever seen - I think it was 3/16". Definitely more than 1/8". That saw is every bit of 500-600 lbs.
While it is true that to add those type of features to sturdy up a table mounted saw and really build it like they should, it would cost a lot of money. That is exactly why I go for the older 1940s-1950s tools when they did build them like that. The above mentioned saw I looked at was $150 and included a bies fence:D
Then again, since most brand new professional cabinet saws are upwards of $2000-$3000, I'd think that would give plenty of leeway in the design. However, I can see where most folks would not want to fiddle with the difficulty of adjustment in a table mounted trunnion saw. Taking off the table can be torture as well. But for crazy people like me, I enjoy things like that:)
Perhaps the ultimate in design and flexibility would be to have a cabinet mounted trunnion but attached it to a cast iron bracket (holding the trunnions/innards) that mounts to the sheet metal cabinet at non critical points and also has precision machined surfaces that the top table mounts to.
EDIT: actually, I did a little research and it turns out that one of my other quest saws, an Atlas-made Craftsman 9" cabinet saw, actually incorporated this design. Check this out:
Cabinet:
Cast iron mounting bracket:
Together:
This seems to be the both of best worlds - the precision of machined surfaces between the arbor/armature and table top, yet retains the ability to adjust the table like a true cabinet-mounted saw. Now, this saw is not the most heavily built (pot metal trunnions and elevation gears) but I think it is a pretty advanced design.
That saw debuted in 1940:D
BFBOB
Number one upgrade for belt-driven saws: Pulleys and belt. I have a Rockwell 10" Contractor Saw dating to about 1975 that always was a pretty good saw. It was transformed into an excellent saw by replacing the die-cast aluminum pulleys and v-belt with machined steel pulleys and micro-v belt. The decrease in noise and vibration is astounding, and having the whole saw not shaking makes the blade run truer. I'd seen ads for these things for years before finally biting, and thought it was probably just hype. It's not.
Bad Jackson
Montana
So I decided to purchase the vintage saw. When I first posted my question a couple of days ago, I knew nothing of these saws. Now, I know somewhat more. I picked it up today and it is safe and sound in my garage. Between Day 1 and today, I was given 2 table saws and a Radial Arm Saw. I probably would have been smarter to NOT purchase it, but I do like vintage items. One table saw I was given was a 80's era Craftsman, and the other, a much higher quality Delta table saw that I have yet to see. I will probably decline both table saws, but gladly accept my Grandpa's Vintage Craftsman RAS.
My new table saw needs a little work, but is all there. I can't wait to put it to work.
Thanks for everyone's input, free advice is always welcome by me.
Munsk.
BFBOB
My wife picked up a Rockwell 10" Contractor's Saw for a good price because the PO said said it just wasn't very good; he needed a precision saw. On my advice (kinda amazing since we weren't much more than friends yet) she bought it. I spent several hours carefully setting it up; not that big a deal because we had to disassemble it to get it down the stairs anyhow. But, with careful attention to alignment, it cut very well. It had more vibration than she liked, but some years later I succumbed to the advertising and bought a set of machined steel pulleys and a micro-v belt to replace the original die-cast aluminum pulleys and v belt. The difference was amazing. The saw runs tremendously smoother and quieter, and the kerf is measurably narrower and the cut smoother, just from eliminating blade flex from all that shake. Precision begets precision. So, a table mounted saw can be set up to do precision work, but it does indeed require more time and effort. For 1/3 the price, I'll take it.
Red Leader
Denver, CO
Anytime you decide you don't want it, just PM me and I will take it off your hands for what it cost you. I've always wanted to visit Montana anyway.
Heck, I'll even through in a case of beer:) :beer:
And when you get some pictures of that saw and the vintage radial arm, I'd LOVE to see them. Feel free to post them up in my thread!
Congrats:thumbup:
KennethH1556
Hey, I am new to this and I need help. I have a Craftsman 113 tablesaw. The blade binds up when I am ripping anything over 12" long. As I inspected my saw, it appears that the blade is not square to the table. It is about 2 millimeters out of square. The back edge of the blade is about 2mm farther to the right than the front. I cleaned out the groove that houses the blade angle guide but that did not help. Does anyone know how to get the blade back square to the table? Thanks. K
