Bad Jackson
How old is a Craftsman table saw model # 113 22452? It looks old to me, like 70'sish. Its $200 on craigslist montana. Good deal?
Thanks.
Munsk.
Thanks.
Munsk.
Thanks.
Munsk.
I, on the other hand, would probably have an issue paying $100 for it.
Although it looks like a cabinet saw, it's really your standard enclosed base contractor style saw. The motor is hanging off the back and, as Red Leader already mentioned, the trunnions are attached to the table, rather than the cabinet as in a proper saw. It's also got the cheesy webbed wings.
You can buy an Emerson manufactured CMan saw equal to this on Craigslist for $75-150 all day long in most major metro areas. It simply won't have the enclosed base.
To turn it into a high performance saw, you'd also need to spend $100+ on a fence and get a blade guard that incorporates a splitter.
If you're going to be using it for "serious" projects - ie presents for friends/family, built-in cabinetry for your home (that you'll have to look at day after day) - then I would pass on this saw.
The fence for this saw I like much much better than the Unisaw style fence, having used both. It is heavy cast iron, weighs at least 20lbs, and is smoooooth. It doesn't have the wobbily factor that the Uni fence has.
Red Leader -
Well, you've got your opinions and I've got mine.
Thanks for everyone's help. I think I am going to buy it, I just won't get the opprotunity to go look at it until Sunday now. I hope he doesn't sell first. Mostly because its affordable and it is a pretty good saw... and also because its vintage!!! Lucky Me!!
Thanks again.
Munsk.
And such is the beauty of life and what makes the world go 'round
I will say that if a table saw can achieve glass smooth 'glue line' cuts, whether it has its trunnions mounted underneath the table or in the cabinet makes little difference to me.
I will say that historically, the Delta Unisaw became extremely popular due to Delta's marketing, their relationships with schools, and there expansive manufacturing capability. It quickly became the 'IT' saw and when you look at most of the cabinet saws out there today, they are copies of Deltas design, with slight changes (true with their bandsaws as well). The fact that most production caliber cabinet-style saws use cabinet mounted trunnions doesn't discount a separate design if that design can achieve equal/better results. I will say that a LOT of it comes down to manufacturing quality and the table mounted trunnion design has been soiled with many cheap saws that were terribly executed.
if thats as nice as reds saw you need to buy it
bob
Ha ha... in that situation, trunnion mounting makes little difference to the wood either... a glue line is produced by a quality blade mounted to a low run-out arbor. You can cut a glue line with a Skil saw and a Bora guide.
Well..... I think the saw market is mature enough that you can discount the table mounted design as inferior. The market has spoken. Think of it as disc brakes vs drums. Drum brakes are still used on new cars. Economy cars. Could you get a table mounted trunnion design to work as well as a cabinet mounted design... perhaps. But how much extra effort would you have to expend and what would the compromises be? How about cost? It really IS possible to build a better mousetrap. Making it affordable is the hard part.
Why don't we talk about direct drive jobsite saws instead.....?![]()
I have had several table saws over the years. Currently I have a cabinet saw and an older high end contractors saw.
I think the deal with the cabinet mounted trunion is that people find it easier to dial in the setup for true and accuracy. That is not to say you can't do it on a table mounted setup it may take a little longer
Bob
Well, I spoke with the seller last night, and I have no way of knowing if I have "First Dibbs" on this saw. Unfortunately I cannot go look at it until Sunday due to babysitter logistical issues. I think I was first to inquire about it, it hit CL at 816 on Wed night, and I emailed him at 851 the same night. Roughly 30 min later.
I spoke with my Dad LN to see if he wanted to go to Helena to look at it with me and he was excited to go along. He also said that my Grandpa had a vintage, 50's Craftsman Radial Arm saw that I could have to go along with this one. I think that they will look great sitting next to one another in my Garage. It seams as though I may have a mini- 50's Garage of my own here... mostly on accident. The enthusiasim for vintage tools on this site, especially by Red Leader, is contagious and has easily spread to me. I hope that this is not yet ANOTHER hobby that I am compelled to funnel hundreds of dollars into, or maybe I do.
Weird how things work out.
Munsk.
You make some pretty good points. The market idea is tricky though, because popularity doesn't automatically equate to superiority. The market is also flooded with import tools because that is what the market has spoken. Can quality be correlated with trends?
My argument: I see a table-mounted saw of equal quality to be slightly superior to a cabinet-mounted saw of equal quality because the cabinet-mounted saw usually has its table bolted on to 4 corner tabs of the sheet metal cabinet which rely on the levelness of the sheet metal and the welding to align to the blade. I have seen examples of the sheet metal tabs that hold the table in alignment to the blade become bent or, if taking a load from above, become easily damaged while the table is still attached (mild sheet metal steel):
I'd love to hear your thoughts on why you have your perspective, I sincerely do![]()
red......you got some bitchen stuff there.......
Bob
Ug, I just had a nice reply typed and hit backspace at the wrong time and lost it....![]()
Red Leader is enhancing my appreciation of vintage Craftsman aesthetics, big time.
I probably would have been smarter to NOT purchase it, but I do like vintage items.
