TimeWarpF100
Just counted 41 new pics....
Next up is swapping the engine and trans from the old frame to the new.
Think I finally have all the proper hardware to do that.
Once I get it on a rolling chassis I can then get proper position for the cab, fab up the cab mounts, figure out the floor, firewall, height of cab channeled over the chassis how low the cab can go without major rework of the box.
Since the wheelbase on new chassis is 2.9" shorter than the '66 chassis I will then need to see if I modify the '66 box to fit or change location of the rear axle in the new 2012 frame. I painted the new '12 frame knowing full well I may have to cut out the spring mounting brackets and move them.
I can gain approx 1" in wheelbase by moving the front axle centerline rearward so it will be under 2" I will have to re-locate the rear axle.
Still not 100% sure the new Rear axle is going to fit in wheelwells of the '66 box. Eyeballing and a quick measurement said it would but I do not have tires for the 18" wheels and have not mocked them up yet. Fingers crossed on that one.
Once the cab is mounted on frame I can then begin the tedious task of how I am going to get all the electronics to work in that tiny '66 Dash.
Do have some ideas but not sure how they will play out yet.
Lets just hope its not another 9 DAYS before another update!
Awaiting progress reports
