EOC_Jason
Reed 104 handle needed...Anyone have one?
Just get a piece of steel round bar?
I wish I knew one, or I would. Anybody know of one in the Boston area?Just because of dimensions, angles, and fitting, it might be worth trying to find a local machine shop, or even an old retired machinist to do it.
....our faithful Autopts is trying out a fellow now to make a pair of Parker jaws. You might chat him up and see how he is doing.
Cecil.....I have done the unthinkable before...
Craig
I don't suppose anyone has any Wilton swivel hold down nuts...specifically for a C1.
If you have the bolt part:
Swivel nut and handle:
Nut:
For the threads on the bolt up from the bottom for the “stud” get an all thread coupler (long nut about 1-1/2” to 2” long) the same thread. Cross drill it for about a 5/16 or 1/4” clearance hole.
Locking lever:
Get a 5-6” bolt either 5/16 or 1/4” or so (for the hole you drilled, see above) also get a matching Jam nut. Grind the points off the hex of the bolt, and string it through the hole drilled in the coupler (above) and then run the jam nut down and jam it into the bottom of the threads of the bolt. Cut off most of the excess bolt. Peen the remainder into the nut flush as you can and file flat. Grind the points off the now captive Jam nut. You have just made a new locking lever and nut for the swivel base…
So I've spent the better part of the day searching for a freeze plug (or expansion plug, whatever) for the end cap of my Wilton C1. It appears to need a 49mm or 1-15/16" plug.
I have come up completely and utterly empty at the local parts stores and have pretty much had it running around burning $4/gallon gas. So I decided to search the internet and I can get 10packs of either size, at a hefty price + even heftier shipping costs. Am I left with that option or is there some other option I've missed. If anyone has bought a wheel bearing cap or something I'd love to have a part number to go to the auto parts store with. Hopefully someone has something that can lead me to the right part.
I did end up buying the hold down nuts from Outdooroutfitters2008 (ebay name). He's was great to work with.
Thanks!
For mine I used a 2" fence dome cap for about a buck at lowes or home depot. Requires a little grinding but looks great once painted.
I like that idea! I'm trying it next time I need one that size.
Hmmmm....Advance Auto Parts has them for $8
http://shop.advanceautoparts.com/we...de_22140426-p?searchTerm=1+15/16"+freeze+plug
I go with the 2" deep cup and I have to sand down the outside until it fits snuggly. Catalyst took a 2" and placed it over a 2 3/8 deep socket and actually peened the inside out and did one nice job. His post on that I think is somewhere in the VGJ thread.
Got the main nut for the Rock Island from viseparts.com. IT WILL WORK!
I just picked up a Wilton 300 3" bullet with swivel base that's missing the swivel locking nut/handles. They are 3/8"-24. I have the bolts just not the locking nuts.
If anyone has a set, please let me know.
Thanks
