Country of Origin Labeling Requirements
wilbilt
NorCal
My favorite subject again.
I have been doing some browsing in the Federal Code of Regulations, Specifically Title 19, Part 134. I turned up some interesting things.
§ 134.43 Methods of marking specific articles.
(a) Marking previously required by certain provisions of the Tariff Act of 1930. Except for goods of a NAFTA country, articles of a class or kind listed below shall be marked legibly and conspicuously by die stamping, cast-in-the-mold lettering, etching (acid or electrolytic), engraving, or by means of metal plates which bear the prescribed marking and which are securely attached to the article in a conspicuous place by welding, screws, or rivets: knives, forks, steels, cleavers, clippers, shears, scissors, safety razors, blades for safety razors, surgical instruments, dental instruments, scientific and laboratory instruments, pliers, pincers, nippers and hinged hand tools for holding and splicing wire, vacuum containers, and parts of the above articles. Goods of a NAFTA country shall be marked by any reasonable method which is legible, conspicuous and permanent as otherwise provided in this part..
§ 134.41 Methods and manner of marking.
(a) Suggested methods of marking. Section 304 of the Tariff Act of 1930, as amended (19 U.S.C. 1304), requires that the marking of the country of origin be legible, indelible, and permanent. Definite methods of marking are prescribed only for articles provided for in §134.43 and for articles which are the objects of special rulings by the Commissioner of Customs. As a general rule, marking requirements are best met by marking worked into the article at the time of manufacture. For example, it is suggested that the country of origin on metal articles be die sunk, molded in or etched; on earthenware or chinaware be glazed on in the process of firing; and on paper articles be imprinted.
(b) Degree of permanence and visibility. The degree of permanence should be at least sufficient to insure that in any reasonably foreseeable circumstance, the marking shall remain on the article (or its container) until it reaches the ultimate purchaser unless it is deliberately removed. The marking must survive normal distribution and store handling. The ultimate purchaser in the United States must be able to find the marking easily and read it without strain.
This one make me think of "Neiko Tooks USA"...
§ 134.46 Marking when name of country or locality other than country of origin appears.
In any case in which the words “United States,” or “American,” the letters “U.S.A.,” any variation of such words or letters, or the name of any city or location in the United States, or the name of any foreign country or locality other than the country or locality in which the article was manufactured or produced appear on an imported article or its container, and those words, letters or names may mislead or deceive the ultimate purchaser as to the actual country of origin of the article, there shall appear legibly and permanently in close proximity to such words, letters or name, and in at least a comparable size, the name of the country of origin preceded by “Made in,” “Product of,” or other words of similar meaning.
And you know how the tool truck dealers remove the "Taiwan" tags from ratchets, etc....?
§ 134.4 Penalties for removal, defacement, or alteration of marking.
Any intentional removal, defacement, destruction, or alteration of a marking of the country of origin required by section 304, Tariff Act of 1930, as amended (19 U.S.C. 1304), and this part in order to conceal this information may result in criminal penalties of up to $5,000 and/or imprisonment for 1 year, as provided in 19 U.S.C. 1304(h).
This is great stuff. I will again be contacting the FTC with some specific examples of violations. They still won't care, but it will make me feel better.
W
wilbilt
NorCal
according to that though most tools wouldn't need to say its origin of manufacture.
Correct, but in the case of some specific, tools (i.e., pliers, knives), they must.
This is not being done in at least a couple of instances I am aware of.
chammyman
Glasgow, Scotland
on the other hand one could argue that it only needs to be the original purchaser of the tools which would be toolmansbigstore or somehtign and he could then remove the country of origin evidence.
W
wilbilt
NorCal
There are definitions of the "ultimate purchaser", which in this case would be the retail consumer. It also applies to Industrial and bulk purchasers, who would in those cases be the "ultimate purchasers". Origin information must be presented to the end user in an obvious and easily interpreted format.
In the cases of the specific items listed, it must also be permanent.
Stephenw
Utah
So, "Vermont American" with "made in China" in magnifying glass sized print on the back of the package is in violation.
W
wilbilt
NorCal
I guess so. I hadn't even thought of that one. According to the code, the "Made in China" information should be conspicuously near the "American" text, and at least as large.
If nothing else, the microscopic print used on the back is a violation.
Nice catch. :thumbup:
W
wilbilt
NorCal
Actually, 134.46 appears to apply to a LOT of HF stuff as well. "Pittsburgh", "Chicago Electric", etc.
