I'm with wrenchr here - grab a mid 90's half ton pick up. GM (occasional rear end prob) or Ford (alignments and watch out for ****** issues). Grab one with either a 4.3 or the 300 and you'll have more elbow room under there. OE and aftermarket parts for both are dirt cheap and available almost anywhere.
Above all, remember the KISS method - Keep It Simple Stupid. No electric windows, no electronic dash ****, no controls in the steering wheel, 2 wheel drive. Think basic.
late model 1989 to 1991 BMW E30 325i or 318i
honda's are bringing insane money. an early 90's with 200,000 mi's are running 4 to 5 grand. i'd be looking at an ******, other than timing belts not much ever goes wrong.
I can't quite agree. Numerous ground/instrument panel or other dash issues necessitate removal of large parts of dash. Rust problems. Timing belt every 60k. Interference engine. Might be hard to smog depending on state. Automatic transmission models refered to as "autotragic". Manual trans models develop slop in linkage (not a simple task to rebuild). That's just what I remember from the top of my head.
maybe a price range could help to determine what you may want............i'm partial to subarus..........only owned a beater but others i know who own them swear by them..................
If it was me I would be looking I would be looking for a early 90s f-150 4x2 with a 300 a 5 speed. Pretty darn well built trucks that get over 20mpg.
It looks like American cars will be cheaper to fix and used Janpanese cars are over-priced.
I heard Buick is reliable, is that true?
Thanks.
be carefull with the m5od trans, they are prone to leaks and many are worn out due to being run low on fluid. most times the rear bearing will have spun in the case and will not be able to be repaired. the last one i looked for was $800 well used. i think an aode trans would be the better choice.
Remember Suburus and BMW's lets just say foreign cars are going to cost quite a bit to repair!! My wife's friend has a 98 bug with alot of issue's and every part cost's quite a bit more than domestic stuff.I can pay up to $10,000, but I do not mind buying a cheap but reliable one.
Thanks.
Oh yah did I mention I'm partial to trucks? I get it from my Dad!!
The jeep grand cherokee with the 4.0 is a dream to work on, everything is right out in the open. A blazer with a 4.3 is one of the more difficult vehicles I have worked on. In cars, I usually look under the hood to see what things look like before I even consider buying something. Most things with 4 cyl's are fairly simple.
edit: Just remembered... seats expensive to reupolster, and most of the leather ones look horrendous by now. Cheaper to get aftermarket ones. Dashboard invariably develops cracks.
