Re: what did you do in your garage today?
Tried to adjust the clutch on my tractor. Started at niine this morning, finished at seven tonight. Wound up taking the clutch pedal off, boring the hole in it back to round, making a bronze bushing to fit it, and turning down the shaft that it sits on. I still have to weld up and re-drill the small hole that the linkage pins to. Maybe then there will be enough motion in the whole set up to actually release the clutch.
Oh yeah, while this was going on I got sidetracked. My neighbor brought up two tractor tires and rims, older than dirt, and leaking fluid from every where. I set him up with the pump and he pumped the remaining fluid out into a barrel. Then we beat on them for the next three hours and finally got them off the rims. He is going to clean up the rims and paint them, but one of them will need some welding before it can be used.
When the rims are all nice and shiny we will remount the tires with new tubes, and pump the fluid back in.
I would rather work on tractor tires with the rims still bolted to the tractor, but these were spares that he had gotten to replace the ones on the tractor.
