fourhour
I'd been wanting a place for the bottle caps to fall into . I considered making a small sheetmetal box but that got pushed back. Yesterday morning, there was a can that I thought might be the right size. I cut a strip of sheetmetal to hang it with and riveted it on. A coat of primer and paint yield this. I tried it out after hanging it, it needed lowered and the caps fall right in.
I cut the top off a large soda bottle and screwed it to the wall under the bottle opener. The screw will probably rot before it's time to empty/change it!
Steevo
43.49600, -112.04300
I don't like taking my MacBook out to the shop and getting it all dirty/greasy, so I dug out an old desktop (unfortunately a WinDoze machine), and stuck it in the cabinet above the bench. I made a metal bracket to attach the monitor screen under the cabinet.
I can take the keyboard and mouse down when needed, and stow them when not:
(I had pre-wired this location for network when I built the shop)
I may move that jack up into the cabinet, because that cord running up the wall bugs me.
The Boss
Connecticut
Yeah, I get it, cause your garage looks all dirty & greasy! ;)
akdiesel
Wasilla, AK
Steevo
Need to get a wireless keyboard and mouse. That way you can sit back and enjoy. Plus the wires would be gone. Wires tend to drive me nuts.
lisiecki1
SE Texas
Tore the crank our of a Honda d16 to use in the repair of my beater civic. I'll probably get the civic in tonight and start pulling the motor.
Hoping to get the charger in this weekend. Getting real tired of "hoping" to get the car in the garage that was built for it. :/
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Trying to clean up a mess in my garage. I have boxes all over along with bubble wrap. It hasn't taken long this winter to just make the garage look like a tornado hit it.
Jagmandave
Overland Park, Ks.
Replaced the front rotors and pads and wear sensor on my 2009 Cooper Clubman S. First time I got to use the lift for what it's intended!
Garage is still NOT big enough, dammit. :eek:
Jimmy_B
After doing some service work on my old Simplicity blower and not tightening the left side axle bolt, and then proceeding to blow snow, I managed to lose the locking mechanism for the drive. The transmission sends power to the right wheel, the pieces I lost lock the left side so both wheels drive. It really ***** without it. My dad bought this new in about 1968 and I feel a little foolish about this :sad:, so I made a new lock plate today.
There is supposed to be a spring and shoulder screw where I have the cap screw installed so that the plate can be pulled out and unlock the wheel, which makes moving it around the garage much easier. This will set up will have to work for now.
Found a few flame decals while cleaning out a closet a couple of weeks ago and was bored after the snow blower fix, so I dressed up my mill a little bit.
I couldn't throw out the last one and this looked like as good a spot as any.
340wedge
Great work as always Leanna, those valve covers are scary! Are they USA made or foreign?, I cannot believe quality control would allow those out the door like that.
rohartman
This week I got the rollbar back from the paint shop and installed it. Got the engine back from the engine builder and installed it and I put in V.I.R. gears in. I installed a steering sensor and Now I'm working on front and rear brake pressure sensors.
Lippyp
Shropshire, UK
Pulled both rear wheels off my lawn tractor as both were flat, turns out they both have about half a dozen blackthron thorns through them. Dropped them off at the local tyre shop and if they can't fix em then they're going to shove tubes in. I'm also going to get some tyres slime put in for the next time so they seal if they get a puncture.
Dusty-NZ
Canterbury NZ
Dull rainy day here , I spent ages pulling the dash on my old Benz 300D to pieces trying to trace an A/C gremlin , gonna have another go at it tomorrow :(
Steevo
rohartman,
What is the device connected via a belt in this picture?
1jjpop
Central Iowa
I start up my ""T"" bucket & let run & warm up, also let it run in in gear to warm up ******. To cold to drive & warm up.. Move so tires won't get flat.
rohartman
Looks to be the steering sensor.
That's correct it is the steering sensor. It draws a track map the way you drive it with the AIM's software. Also allows you to see oversteer or understeer, which is great if your driver can't tell you what the car is doing on track.
1grnlwn
Central Illinois
Fixed my HX furnace. Used my stronghand weld table to offset some 1" pex with the heat gun. Started to put casters on a small toolbox for the stronghang clamping system.
56vette461
I added the HF welding cart to the shop. The drawers hold all the accessories plus the power cord, welding helmet and some misc plasma cutter tips. HF has them special priced for this upcoming 3 day sale
CudaChick1968
Member Emeritus
Northwest Tennessee (38230)
Lippy, if you have trouble finding any of that stuff locally check with a place in the U.S. called AgriSupply.com. They have tubes for about $6.
CudaChick1968
Member Emeritus
A local guy surprised me yesterday with a phone call and then actually showed up {!!!} with a 1948 Panhead frame to get restored, the oldest bike frame I've had here to date. The poor baby's seen much better days in her time and has had a rough life, but he's got ALL the matching-numbered parts -- scattered all over the country getting restored by various professionals -- and it'll be a fun one to do. I think it weighs more than I do LOL so I might have to get Billy involved when it's time to put it in the oven. Pics to follow when I get going on it ........ in about 3 months LOL ughhhhhhhh no rest for the wicked ............ :D
Lippyp
Shropshire, UK
Thansk for the tip, they managed to plug them, five in one tyre and one in the other! It's now got some sealant in so hopefully any others should get automatically sealed.
Today I stuck the wheels back on after cleaning up the stub axles and a good slathering in some new grease, then I cut the grass in the orchard for the first time this year. It has started to grow and didn't get the last cut it should have had in the autumn because of the weather. My sister should have picked up my ebay bargain tow behind roller so next weekend we'll nip over and pick it up so I can drag it around the garden behind the mower.
Tomorrow I intend to grab a good few hours garage time and finish up the roof light bar for the blazer.
edcantu9
Southeastern Iowa
Look up Logitech K400 keyboard with mouse pad. It is what I use in my garage. Great wireless range and responsive. Goes on sale regularly for $19.99.
shopboy13
NY
After putting a shoulder to the door to get in due to ice I put a new cap on the trailer jack. I lost the other one and the jack was freezing up without it.
Then I moved out my mismatched husky and Gearwrench ratcheting wrenches for the sears special (50$ for the 20pc set). Got my regular wrenches moved out of the cart and into the stationary box.
Put them in the drawer with the mismatched ratcheting wrenches. I also opened my new chanellock set from Home Depot I bought with a giftcard. The last thing was came up with what I thought was a brilliant idea instead of throwing drill bits in a drawer
The use of a tackle box made me think about summer how bad I want it to come. So I also threw the boat on the battery charger.
floridaguy
In the garage
Had to replace the battery in the Silverado. Decided to clean up and paint the battery tray and bolts.
Ragtop13
Fixed the gas leak on the snowblower. Ready for the next blast Monday :rant:
Ready for this winter to be over...
Jagmandave
Overland Park, Ks.
Fired up the genset and let it run for about 1/2 hour just to make sure the battery was up good, we are supposed to get an inch of ice tonight and maybe 15" of snow by Sunday afternoon, so I wanted to be prepared - that way we won't lose power!
I also made up a gallon of 50:1 for the snow blower and got 5 gal of regular for the genset - now I'm ready!
JVB
N.W. PA
I built a storage rack made to house 18 gallon storage bins. Had to organize and clean the basement out so I can start framing off the main area of the basement.
lhc_cj7
Decided the location of the 125a sub panel. I've wanted to have dedicated 220v welder and compressor outlets. Now that my son works for an electrician I get the labor free and supplies at cost. :beer:
SchuLace
I out together my toolbox and started moving tools into it from my old box. I tried to get my snowblower running but couldn't get it to run right. It was -2 outside and my garage isn't heated or insulated so it was a struggle. I finally gave up on both projects. I'm going to take my snowblower over to my parents tomorrow and work in my dad's heated shop.
