Strippers What's your Preference
mobiledynamics
Gotham City
Strippers.....
Playing around with Strippers this morning to settle into a groove.
I don't work much with stranded as opposed to solid. My GOTO stripper is always a pair of Ideal Reflex for solid work. On the occasional low voltage side, depending on angle of approach of how much stranded I'm working with, I'll generally use the Reflex or the Ideal Stripmaster.
Took a 10 stranded and ran through the motions on testing.
Stranded *due to the stranded friction* on the jacket, IMO does not strip as easily as solid. The Stripmaster seemed to be the most efficient, with the strip and then *pull* action mechanism of things. The latter auto-stripper I have *panduit I think-it's old*, does the same. I have hesitation using the autostripper cause on rare occasions, it has cut 1 or 2 outer strands on some wire I've worked with, and I end up starting all over again.
The Knipex variant in the pic, just weird overall.
I picked this up awhile back. I cannot find a application on where I would use this versus other tools in my lineup.
I think the Stripmaster would be most consistent out of the bunch, but the ergonomics is weird and you need to be in the proper position to use it. Not the tool if you are going to use it at all various angles of approach.
My Go to Stripper for solid wire, Reflex, they are -ok- on stranded. I've got like 4-5 pairs of the Reflex. One of them is just for Romex. It's a luck of the draw. On the very same wire, if I don't cut and pull hard on the insulation in one motion, sometimes it will just strip the outer nylon sheath-lube jacket. Then when I go to pull off the insulation, the OD has changed slightly so it's not a smooth removal on getting the insulation off.
On the latter times, if I just pinch the plier to strip with the Reflex and give it a good yank, the insulation comes off with no problems.
tshetter
Central, FL
I prefer brunettes.
But in all seriousness I have an older set of Klein 14/2R strippers.
They do 12/14 gauge stranded and solid. Cut #6/8 screws and has a Romex stripper at a 90deg angle at the end that also works well for stripping 12/10 gauge in close spots.
LS6 Tommy
Northern NJ
The ones on the left are closest to what I use, although the 11-160 Knipex are pretty nice. No disrespect intended, but I'd take the two in the middle back to Home Depot & let some oblivious gadget-loving home owner have 'em...
Tommy
Lassen Forge
This chick prefers her strippers early 20's, buffed, with some chest hair, high-n-tight head hair and cute ****... :drool:
OH! THOSE kind of strippers. Darn. Sorry about that. :eek:
My go-to live in the top of the toolbox pair is the twin to the light blue handle ones; they work well, doesn't matter if it's on stranded wire and solid... tight... buff... Sorry, mind wandered again. :D
Yeah, the all in ones work well - have a set that have lasted (and not failed once) for some 15 years. The ones on the left (yellow handles, but not ergo) are my back-up go-to's... they work, just not as well as the autoset ones I have.
Sus @ the Forge
Bobdog
South Jersey
19-24, slim brunettes work for me.
If we're talking tools......Klein.
Sent from my SCH-I535 using Tapatalk 2
Trucky
Bsaint, just what is that thing?
Personally I use regular ole' Klein strippers for tighter quarters stuff (rarely). But for PLC work or something with a ton of wires, out comes the Stripmasters. Got a spare pair at Sears for 13$ I think, not a bad deal. They strip wires like nothing else, nice and fast.
Zeke
No kidding.
bsaint
Manchester, CT
Stripmasters are nice except they are bulky.
The strippers above I use to make jumpers and what not. They have a really sharp cutter too. They auto size themselves for 22-14awg and strip in one shot. Takes a little used to not to pinch your palm. They also aren't SUPER durable. If they bang around a lot against other pliers they seem to break. But if they have their own spot in a pouch or drawer - they are great.
1/2 Cup
Member Emeritus
Shepparton. Victoria. Australia
I have several different types of wire strippers but rarely use them. As an apprentice we were taught to use the cutters of your pliers, this is for general electrical stuff mind you and heaven help you if you nicked the copper conductor as this usually resulted in a pasting from your supervisor. I still use this method to day.
Aura
Minnesota
Strippers.....
I wish I had been Playing around with Strippers this morning! I would love to settle into that groove.
ishiboo
Oshkosh, WI
Klein 1412 for NM.
Klein Katapult or Channellock 908 for low-voltage wiring.
Paladin 30-20 stripper (straight, not the curved one) for small wires.
Honest Bob
Easton, PA
A pair of dykes (is that a pair of strippers? haha) is my go to for stripping.
I do have one like the yellow handled ones and use it when I cant locate my dykes.
I picked up a stripmaster on clearance at lowes a while back and its nice but I dont really use it unless I'm stripping alot of little wires, its a little akward to use.
LifeLongWNYer
South of Rochester, NY
I just stopped in to see what kind of smart comment I could add, but it looks like everyone else has pretty much covered the waterfront.
Seriously, other than when working on little tiny stuff, ( 18 AWG and smaller ) I just use a pair of diagonals ( dikes ) or a linesman's pliers. I have done it for a while and I rarely kick the conductor.
TractorJeff
Elkhorn, WI
At work, we use the style like the Stripmaster. Once I stripped a Test Lead with a pair of Diagonals "dykes". Everybody almost fainted! You'll knick the wires! Consequently I don't strip much wire, but when I do, I use the Stripmaster style.
mrpizza
IL
I just got me a set of the klein 11055 strippers, seem to be really nice. When i was working on aircraft i used small folding razor blade. That was the best wire stripper ever!
Boiler
Indiana
Hot, fit, smiles, and doesn't stare at herself in the mirror or at the wall. And my ideal automatics from lowes work great.
