Stuck Bolt - ideas?
Slowbra
NC
I sheared off a bolt on my xpipe while installing it (2004 Ford Cobra) . The threads were garbage so I was expecting this. It's one of the bolts that attaches the xpipe to the catback. The bolt has a knurl and resembles a wheel stud.
I've tried to hammer it out with a 3lb sledge and punch, but no luck. I then took a cut of wheel and cut it close to the flange expecting that to work better, but no luck.
I guess I could drill it or heat it. Before I tinker further I thought is ask for an opinion or two. Here are some pics.
C96
Use an air hammer / chisel; you can by a cheep one at Lowes, Home Depot or HF just for that job.
Techie1961
Pickering Ontario Canada
Drill it out. Using a torch will cause damage to parts that you don't want touched. Center up the punch mark that you made and when you drill close to the final diameter, it should knock out fairly easily. If you can manage it, don't drill all the way through on the larger holes you will make and you will have a blind hole to use a drift punch in.
atty5420
Kingman, Az
Heat, and lots and lots of Kroil, then patience. If necessary you can weld on a nut to get a better grip for the air ratchet.
Steroblan
Northern Calif
From experience, you will probably only get the one shot at removal before something is damaged. Find someone with a welder and weld a nut to the cutoff stud(weld in the center of the nut). The heat from the weld will help break the corrosion in the stud threads. Once it is cool to the touch, apply steady torque with a box end or 6 point socket. Using impact tools can shear the nut right off again.
Throbbin Rods
Lebanon, NH
Heat the knurled insert cherry red, then squirt some water directly on the knurl. The knurl will shrink quickly and the heat will be driven out into the flange. Drive the insert out of the flange with an air chisel using a pointed bit. Used it on lots of real tough jobs and it works.
btlegacy
NC
This is my usual go to
87jeepwrangler
X3
This is the best way. Period.
Buckgnarly
VT
Heat it cherry red, punch it right out. Replace with bolt. This is my standard practice in the rust belt, been done many times.
Buckgnarly
VT
It's not threaded, it's a pressed in stud.
MG44
An air hammer with a torch heating up the flange (not stud itself) will do it. If you don't have a big torch (most don't) a small handheld MAPP torch will usually do that trick but you may have to heat it for 5-10 minutes to get it hot enough. Take a candle and try to get some wax in on the pressed side if possible, it may help. We do a lot of exhaust at work, this is not uncommon but a lot of times a headache.
I wouldn't try to "blow out" or weld (which won't do you any good in that situation anyways) anything with a big torch if working on jack stands. The embers are hot and it is hard to get out of the way as everything comes falling down.
Good luck.
Jswain
Calgary, AB
I would either drill the stud out and tap it to accept a new bolt one size larger, or simply drill it out and use a bolt and nut going through the flange(quick and easy). It is going to be very hard to hammer it out by hand with it hanging on the car so unless you have a good air hammer or you want to remove it that option will be more difficult.
If you can mount it in a vice with a solid piece of tube or a socket larger then the insert underneath it that would help greatly and a few blows with a hammer would take it right out.
lksdrinker
You could just cut the flanges off altogether and weld on some new ones. Or you could skip the flanges and weld the x pipe to the cat back.
zkling
Heat and punch, but first I would try a ball joint press and suitable dies to back up the flange. A make shift press to push it out.
Slowbra
NC
Lots of heat and lots of punching using an air hammer. No luck yet. I'll try again this weekend
BioNerd
Undisclosed location in the middle of nowhere
I've encountered **** like this before... Here I'm drilling out a bolt for hours. I had ****** bits and only wd40 for lube.
(By the way, there is 4 jacks in this operation, the one in sight is a "just in case" one)
I've drilled thru the bolts using slow constant pressure and lubrication. Right at the center and then punched in the remaining thread and material. One time I had to use a tap and die bit to clean the threads that were damaged.
It worked.
Slowbra
NC
My dad suggested the same thing (drilling it). I just didn't have time to **** with it for hours tonight. I'm shocked how bad that sucker is stuck. It's not really even rusted.
GarageWarrior
Westerly, RI
If it's not stainless, you can try burning it out with oxy-acetylene torch. However last ranger I worked on had stainless, and stainless does not really burn - ended up drilling with air drill and carbide bit. It's a pain.
My advice - take it to the shop and let them do it at flat rate.
nicksnothereman
In the Mojave
I guess I could drill it or heat it. Before I tinker further I thought is ask for an opinion or two. Here are some pics.]
Heat then penetrating oil then punch+hammer.
If that don't work try to wedge it apart with a pry bar without damaging the flanges; not ideal but sometimes that can help. Otherwise you'll be drilling it out I suppose.
FunkyfullWidth
Three Rivers, ma
I've done tons of these... Just a little heat from a torch and punch it out, either an air hammer (a good one) Or a hammer and punch. It's gotta be cherry red and swift swings.
It isn't threaded.
It's a stud.
Slowbra
NC
I picked up a torch last night and tried the hear and air hammer approach. However, I did not get the flange cherry red. How long do you think that would take with a propane torch on a stainless steel flange? Should I get it up from the bottom of the flange?
nehog
Jaffrey, NH
Well, I can't believe all the hard work everyone suggests. My ball joint press has adapters to press these out easily. Life's too short to mess around!
Slowbra
NC
That presumes the OP has a ball joint press.
For the pictured tool, you can just stick a small socket in there.
I need a picture. I can pick up the tool, but not sure how to make it work as I don't have leverage unless I weld a nut on the head of the bolt.
ishiboo
Oshkosh, WI
It's pretty simple... you put the forked open end over where you want hte stud to come out, and the bottom flat jaw part would press on a small bolt/socket/etc. to push the stud through.
I still think you're going to need heat.
Chuck
Smithfield, VA
Another "me too" on this one. Yes yes yes.
ishiboo
Oshkosh, WI
Except there are no threads, it's a splined bolt... the threads are gone and not relevant. It will be difficult to TURN as you need to strip all the splines... the goal is to push it out.
