expfcwintergreen
- Joined
- Oct 16, 2011
- Messages
- 157
I was going to get Snap-on, but couldn't find them on their site.
I would like some bits, same answer there?
Go to Katun.com and they have JIS screwdrivers made by Snap on. The Katun brand screwdrivers also used to be made by Snap on.
I know many folks do not know about JIS screwdrivers. Guys I have worked with look at me funny when I tell them about JIS. There is a difference. I have attached some photos from the Vessel web site to show the difference.
As almost every knows, a JIS crosshead screw will be normally identified with a little dot on the head. Here's the JIS screw holding the air flow sensor on my Tacoma:
Do you get Vessels when you order JIS screwdrivers from McMaster-Carr?
Yes, that is where I got my Vessels.Do you get Vessels when you order JIS screwdrivers from McMaster-Carr?
The same applies to many local and european gear makers. For example, wera and wiha don't have JIS #000 which is essential for many electronic repairs. You have to go with Moody Tools for example. Hell, even Vessel doesn't make it.This is what truly amazes me. Toyota, Honda - motorcycles and autos/trucks just to name a few, all have JIS screws. Why then do the major auto tool manufacturers NOT sell JIS compliant screwdrivers? Snap-on... hint, hint.
That is incorrect. I pointed this out in a different thread. The actual name JIS is defunct. The correct standard is DIN-5260-PH.
Even Vessel states that while their screwdrivers are JIS compatible, they are not truly JIS (because the JIS consortium is no longer licensing the use of that name). They are made to DIN-5260-PH, which is compatible with JIS (and Philips as it just so happens).
Wera does indeed make some screwdrivers to this ISO spec. I cannot speak to other manufacturers.
Yes. I have a Vessel 930 +2x100 screwdriver (this one has a red handle, fits #2 Philips and has a 100mm long exposed shaft), and it fits standard Philips screws perfectly as well as JIS. However, I use it exclusively on JIS as I'd rather wear out my SnapOn screwdrivers on standard Philips screws.
Note that the 930 has a full length shaft that meets the striking cap on the back of the handle, so it is surprisingly heavy when you pick it up. It has the same balance as the old wood inlaid "perfect handle" screwdrivers, if you're familiar with them.
I also have a Vessel 900 +1x75 (teal handle). This one is much more lightweight (with no striking cap), and has knurling on the shaft (instead of the hex bolster that the 930 has). I prefer the lighter weight 900 style for the #1 size.
Note that these fit posi-drive screws about as badly as a Philips driver. For those, you need a posi driver.
FWIW, PB Swiss & CK Tools both conform to the DIN 5260-PH & DIN ISO 8764-1 standards as well.That is incorrect. I pointed this out in a different thread. The actual name JIS is defunct. The correct standard is DIN-5260-PH.
