The first order of business was getting the Lambo into position and to get it wrapped up. At this point we are still wondering how we were going to accomplish the wide body modification.
Our mission is to get the fender "lip" over the tires. I used a sheet of 1/2" foam and cut a radius in the shape of the lower lip, shimmed it, and taped it to the wheel radius to get the amount we needed to widen the quarter. You can see it under the tape back to my high tech blue arrow
The blue arrow marks the point where the quarter panel meets the rear bumper cover. We can pull the rear bumper cover out enough to match up to the widened quarter panel.
My high tech black line
shows where the factory body line is on top of the quarter. There is about 1" wide of metal there so what we will be doing is cutting the quarter right on that corner and pulling (the side) it out so there is a slight curve at the top of the fender. We have built the top of the quater panel out with foam to our desired width and then covered it will tape so we can see what it will look like. By widening the top of the quarter panel we are moving the stock quarter outward so the body doesnt look so modified.
This last photo shows the side vent and where we will cut and add 1 inch. This is another area where we will be moving the quarterpanel out so we can keep the body look as factory as possible.
I hope this makes sense. I will have some pictures of our cuts in a few days.
