After seeing the custom built trays above, Elroy started to Jones for some real socket trays. Took some measurements and sketched up a tray. Ran it out of 20 Ga. stainless on a Vipros 357 CNC during a production run at work.
These didn't come off the truck. They came off the Cincinnati Form Master.
Flat bar delivered today.
Elroy-Those are the Mack-Daddy!
What is the "spread" of those, and did Elroy only make them for Elroy??? Either/Any way, they are nice, and would be a FINE addition to any too set!
Elroy likes them just fine.
Elroy built these for some of his 1/2" and 3/8" sets. Simply took measurements and built accordingly. We have enough projects on the books so if you want some stainless trays for yourself, have at it.
Matt has seen your thread and likes!
**Matt also gets a kick out of Elroy referring to himself in the third person and makes Matt wonder if he's got it all wrong and in all actuality Elroy has a narrator which would be really cool.
I don't think Matt realises that this thread is over 4 years old
and that Elroy was banned a long time ago.
#Jealous.
This is one of my favorite threads on GJ. I love the homemade metal trays that some of you have custom made![]()
#Jealous.
I personally prefer the Hansen trays for my 6 point sockets; no difficulty identifying or removing exactly the socket I need. As some of you have mentioned though, they have their shortcomings. I have snapped a few of the plastic posts in the past and had to repair with JB-Weld (no big deal).
For my personal setup, I didn't want to keep the 1/4" drive tray in front of the 3/8" tray because of how delicate the 1/4" drive posts are. I.e. I wanted to prevent snapping them when tossing / grabbing tools in / out of the top compartment of my rolling cart.
I made a little "stadium-seating" style block for the 1/4" drive tray that allows easy visibility and access to all the sockets (1/4" drive + 3/8" drive). The block sits on the back ledge of my cart and is kept from sliding around with a couple metal tabs that fit in the little gap in the lower back corner. The tray is screwed to the block with 2 small pan-head fasteners.
Enjoy and feel free to copy (God knows I have copied plenty of ideas from this forum).
A little scrap wood and gray paint:
"Delicate" 1/4" drive tray up and away from potential harm:
All sockets are easily identified and accessed:
No problems so far:
I've been kicking around ideas about how to similarly organize all the 'specialty' sockets I have that a post can't go through. E.g. Ball end allen, male torx, triple-square, pipe plug (square), etc.
Keep this thread going! I love seeing all the different effective ways of organizing sockets.![]()
This is an AWESOME idea. I'm copying this for sure.
I did this-
That's slick. Pretty serendipitous that the blow-molded case pieces fit so well in your drawer.
They didn't fit. I made them fit. I measured the width of the drawer and divided by two. I cut the extra off with a circular saw and cleaned up with scissors.
If I was to do it over again, I would use a table saw. The cut would be much cleaner. If you look at the edges, you can see that I did not do a perfect job.
Nobody's perfect
When you work with them everyday you get a feel for where they are at.how do you recoganize what size is what socket? they are all "burried" into the clips.. maybe since the tray can be marked with a sharpie so the sockets can be quickly picked up?
For a vintage look, how about metal trays? I don't know if or where you could buy them. It might require some custom fab work but I would bet that there are some talented guys here at GJ who could do it. Just a thought.
it might be hard to see, but i get a piece of 1/2 plywood and lay ouy my sockets how i want, drill the appropriate hole size (1/2, 3/8, 1/4) then put the same size dowel in each hole, then paint the whole thing to make it look cleaner. its easy to take sockets on and off and nothing ever falls over. Takes a while to build them though.
