JAKE-THE-TOOL-MAN
Replaced a starter and soldered a couple new fusible links so my truck would start again
Scary big pics of a nice little pet!
Sorry! I'm using image shack and the pics are huge.... any advice?
I hope to be released from Powder Prison some time soon.
You are the powder princess for sure!
Yes we miss your posts. Your work is great.
John
Installed the Coxreel power cord my boss' wife gave me. I put it right next to my HF 50' air hose reel. Now i just have to find out why it doesn't have much rewind tension.
Tommy
That is looking really good!
Have you considered that flue pipe? you could hit that with a contrasting High heat paint so it "dresses up" a bit. I painted exposed water and gas pipes in my garage, (color coded as well) and the planned air line pipe is already painted the code green for compressed air, and I haven't even installed it...
Tommy,, I have two of those reels in the shop and they both had soft rewind tension. To fix the issue on the first one I adjusted the spring by taking off of the cover and manually winding the spring back. It was a PITA and I don't recommend that. The second I took the junction box off and rewound the reel by hand until it had the tension and "pull back" speed that was fast and strong enough to rewind but not whip the end around as it wound back up.
John
Eric, I take it you had the "Lisle" tool? I've got to do that job on my Explorer.
Thanks, stay safe!
John
How do you know you got all the pieces out? #1 looks like a chunk on the light side...
