I would move the garage onto the neighbor's pad behind his garage.
Maybe his lot isn't wide enough?
Your garage will encroach upon the alley, but you can permit the blocking of the alley.
ETA: Looks like there is a tree blocking the way. Maybe dig out his tree and store it. I suppose it would really depend on how much he would take for storage of your garage.
Move the garage out of the way in the least expensive way.
On the one end, you could box up the existing garage and move it completely out of the way, either off the lot or up in the air, far enough that regular construction wouldn't be impeded. At the other extreme, you could leave it where it is and excavate under it with greater difficulty and expense.
Play with the different methods and their associated numbers to get the most economical balance.
I've given you all the relevant measurements, over and over. And you can see scaling the Google Earth image what we are up against and why we want to work under the garage.Right now, without measurements of the lot and structure and photos of the structure, it's hard to say what can be done.
By the way, what are the limits the city will allow the alley to be blocked?
You certainly have the 10 pounds of **** in a five pound bag problem.
I would change things around and make the smaller structure the house and the larger one the shop.![]()
The garage is going to be a long way in the air from the basement floor. I think we could pour 1 or 2 temporary or permanent concrete pillars for the cribbing under the beams. Its no problem to get beams to put under it or jacks to lift it up. We could drill a 12' deep hole for a pillar at the start of excavation and it could sit on that for the entire time. We could knock them out when we are ready to set it down permanently.
These are the sort of ideas I'm hoping to hear about from this group.
structurally, would anything you do possibly affect the neighbor being as super close as they are?
are you worried about the neighbors structural integrity being compromised at all?
1. You mention enlarging your garage from 22x31 to 22x34. Can you give any more details about this?
Nope. He is retired. No interest in my garage.2. Can you sell your garage to your next door neighbor and move it next door?
Sure, but I doubt it would be cost effective.3. Can you demo your neighbor's garage, store yours on his property, move yours back and then build him a new one?
Yes. We'd have to put a beam across to hold up the roof trusses. Interesting idea. Where are you going with that ?4. Can you remove the front wall of your garage to give clear access to the site through the alley and garage?
Maybe you could build the bunker between house and garage, bring in precast roof panels this way, etc. to complete that phase and then pick the garage up and put it on that part of the bunker while you do the portion under the garage.
Nope. See above about the crane.5. Can you locate the lift outside of the existing footprint of the garage (between garage and street fence?) so you don't disrupt parking space, etc.?
I want the elevator inside the garage.Maybe you do a sidewalk lift type of elevator (http://www.aclifts.com/material-handling/Sidewalk-Lift.asp).
Might become the bane of my existence !Looking forward to more on this thread.
Yes,
I would investigate this. Figure a 45 degree load from his foundation down and outward. You will need to consider this.
It isn't.Just went back and read the original post.
One thing I don't know if you have checked.
If you build this addition that connects to the house, even of the connected portion has grass over it, will that be considered lot coverage area?
Yes. For the third time I took all my sketches, ideas, lot survey, etc. to the city and spent over an hour with 3 of their top guys going over everything. Both sides asked all sorts of questions. They love the project because when all is said and done there is no visible change to the property, yet it adds utility.If so, you are probably exceeding the zoning requirements for lot coverage. You've checked all the zoning requirements?
Yes. Or we may bring the concrete roof to the surface and have a concrete patio in our back yard. We are undecided on this aspect of the build.Even if it is allowed, you need waterproofing over the top of the structure and enough depth of soil so that grass will grow, or another method of covering that area.
Yes. Lifting a garage is tricky too because their are no floor trusses to a) lift from or b) tie it together. Lifting a garage is harder than a house.In addition, some consideration of how you will place beams to lift the garage, needs to be made. You can place beams along the bottoms of the short walls of the garage, for support and lifting. But since you want access through the long wall from the alley, that beam needs to be placed, at least initially, near or at the top of the wall, and lift from above. If you want to access the area between the garage and house, so you can excavate that area along with the other initial excavation, then you will also need to place this beam at the top of that long wall. If you lift the structure enough, then you can excavate under that wall and into the area between the garage and house. If not, then a portion of that wall will need to be removed.
Nope. Purposely left bare inside until the completion of this project.Is this garage drywalled or insulated?
Nope, roof and singles are in perfect condition. Seems a shame to sacrifice them, but also seems to be the easiest way to do the project.Is it due for a new roof, and shingles can be removed to reduce weight?
Or 4 or 5 cars.All that i see you have missing is a lift in the garage connecting the two levels. It would be useful is getting any large items (including cars) to the lower level and just think of the looks from your neighbors, when you are able to park 3 vehicle in a building made for 2.
...I think dismantling the garage is the way to go...
That's what I tried to tell you.
It isn't.
I think we should dismantle the roof and throw away the plywood sheeting and the shingles. Then cut apart the 4 walls and store them somewhere close by, standing up. Hopefully the stucco won't crack too much ?
We'd then have an open back yard to work with. We could then build the bunker unimpeded. Once its done we stand up the 4 walls and rebuild the roof, reusing the trusses. Its probably less costly to rebuild that roof than it is to lift the garage and do the fancy blocking and work around it with a skid steer.
Myself with 2 carpenters @25/hour each could rebuild the roof in a week ? $2,000 labor. Materials would be about 1000 ft^2 of sheathing plus shingles.
It would be pretty reasonable to dig the hole unimpeded with a mid sized excavator.
How about lifting the roof as a unit, supporting it outside the building footprint, removing and storing the walls, and doing the dig. Then set the walls back on the new slab and dropping the roof down. The roof has a better chance of moving up as a unit by itself.
Sounds like "perfect" garage !!It's how ALL garages s/b built !! I'd love for my garage to have a full basement under it, and tunnel walkway the short 10 ft to the house. The breezeway between would be great place for elevator as right next to driveway.
OP . . Curious where the "elevator" can be and still meet code for any potential flammable vapors that might seep into the underground "live-able" space??
Also, where is "north" . . . is that north Canada, north Florida, or north USA !!
Update GJ Profile with location.
Looking forward to this build . . . sounds awesome.
