http://www.engineeringtoolbox.com/pvc-cpvc-pipes-pressures-d_796.html
Maximum operating and required minimum bursting pressures at 73oF (23oC) for PVC pipe fittings according ASTM D1785 "Standard Specification for Poly Vinyl Chloride (PVC) Plastic Pipes Schedules 40 and 80 are indicated in the diagram and table below:
1.ASTM D2466 - 06 Standard Specification for Poly(Vinyl Chloride) (PVC) Plastic Pipe Fittings, Schedule 40
2.ASTM D2467-04e1 Standard Specification for Poly(Vinyl Chloride) (PVC) Plastic Pipe Fittings, Schedule 80
•1 psi (lb/in2) = 6,894.8 Pa (N/m2)
Note! The maximum operating pressures derates with temperature. At the maximum operating temperature for PVC - 140oF (60oC) - the strength is derated to approximately 20% of the strength at 73oF (23oC).
Be aware that maximum operating pressures varies with the fittings design. Consult the manufacturing data.
Here is right from manufacture, NO, NO , and NO !
http://www.usplastic.com/knowledgebase/article.aspx?contentkey=787
Can PVC or CPVC pipe be used for compressed air lines?
Article Title: Can PVC or CPVC pipe be used for compressed air lines?
Article Summary: Use of compressed air or gas with Harvel PVC/CPVC piping products
Article Date: 1/8/2008
Article ID: 787
Share This:
No, PVC and CPVC pipe should not be used for compressed air lines.
Here is what the manufacture has to say about it.
WARNING! The use of plastic piping with compressed air or gasses can result in severe bodily injury or death.
Harvel’s PVC and CPVC piping products are “rigid” thermoplastic materials. Harvel Plastics, Inc does not recommend the use of PVC or CPVC piping products for testing, transport, and storage of compressed air or gas. The compressibility of air and/or other gases result in tremendous amounts of stored energy, even at lower pressures. Should failure occur in a compressed air or gas system for any reason (i.e. improper assembly, mechanical damage, etc.) the failure mode will be very dramatic in nature due to the physical characteristics of the rigid piping in combination with the immediate release of stored energy. Under these conditions, the velocity created by rapidly escaping air and the resultant failure mode can throw shards of plastic in multiple directions (i.e. shrapnel/projectiles). This scenario creates a substantial hazard to personnel and property within the vicinity of the piping should a failure occur. Several cautionary statements and alerts against the use of rigid PVC/CPVC piping for use with compressed air or gasses are available through the Plastic Pipe Institute(PPI), American Society for Testing(ASTM), various other trade organizations, manufacturers, safety codes, as well as several State and federal Agencies(i.e. OSHA).
Compressed air or other gasses should never be used in testing. Extreme care should be used to assure complete venting of all entrapped air when filling the system with water or other liquids used in testing. Whether hydraulic hand pump or available water line pressure is used, any slow build-up of gauge pressure in a completely liquid filled line shows some entrapped air in the system. Pressure should be immediately released and the line re-bled. Failure to do this can lead to a catastrophic failure when the decompressing gas suddenly accelerates the solid water column if a faulty joint separates.
PVC and CPVC piping systems are not recommended for compressed air lines. Improper installation, especially poor cementing techniques can lead to an abrupt release of tremendous stored energy. Shattering of pipe and fittings is then apt to occur at directional changes and at point where the system is rigidly restrained due to instantaneous whipping action imparted by the escaping air. Internal surface cracks, due to the stress, ca be initiated which will tend to propagate and cause shattering, hairline or pinhole cracks over a period of time. There is also evidence that certain additives to system lubricants will initiate internal stress cracking which will again lead to similar failure over extended periods of time.
OSHA, NO ,
https://www.osha.gov/dts/hib/hib_data/hib19880520.html
