1/4" drive hex bits
928'er
Wine Country, CA
I recently picked up a new (to me) carbon fiber bike which has lots of small allen head fasteners with very precise (and low) torque spec's.
I have a nice SO 1/4" torque wrench, but all my hex sockets are either 3/8" or 1/2" drive. Can anyone recommend a decent set of hex sockets in 1/4" drive?
I suppose I could just use a 1/4" to 3/8" adapter, but where's the fun in that...?
bob15
Northeasten, CT
Snap On sockets. They aren't necked down so it you break one, just use a regular hex key to replace it.
Set: 110ETMAY (sae) or buy what ever sizes you need.
See e-bay for lowest prices.
Buy this style:
Not this style:
Starterwrench
Buy this style:
Not this style:
What problems are associated with the Sk bit adapter type? I have one of these since I did not want to spring for a whole set of hex sockets. Thanks.
bob15
Northeasten, CT
If that bit snaps off, you need to find a replacement. Example: that bit is 1/8 Allen and it snaps off. now you must find an 1/8 hex bit, with a 1/4 hex driver.
Take the Snap On (older Bonney & Proto's were similar style): That same 1/8" bit snaps off. Remove broken piece, take an Allen wrench, cut the "L" off it and insert back into the socket and you are back in business.
With the Snappy style, you can also custom size the length if needed as well. Can make super stubby or extra long. Cannot do that with the stepped down bits.
rodsnratfinks
California
Re: 1/4" drive hex bits
Trek Madone 5.2 with Velocity A23 rims laced on White Industries T11 hubs. ;)
That's a fairly bulletproof training wheelset. I have the same thing except with Dura Ace hubs, which I like because they're quieter. The white industries hubs though, are awesome. Is your bike equipped with Ultegra?
Sent from my SM-G920V using Tapatalk
928'er
Wine Country, CA
Yeah, full Ultegra. Just replaced the Bontrager saddle with a Fizik Arione.
My old road bike is a Mikkelsen SL/SP custom frame that I built out with the original Dura Ace back around '86.
rodsnratfinks
California
Wow. Mikkelsen's no slouch either! Do You still have that frame?
454ragtop
Carver, MA
I have a set of SAE in 1/4 dr., no markings on them, but they seem very well made, and very compact. Funny part is, I bought them used from an old timer who has since passed but they were missing a few. Found another incomplete set at a swap meet, that had the ones I needed, and a few spares.
Jim
928'er
Wine Country, CA
Oh yeah, they'll have to pry it out of my cold dead hands. It's a real fillet brazed work of art.
I'd been thinking of up-dating it for years, but decided to keep it old school and just get a new bike with all the modern bits.
scooternut
Pittsburgh, PA
If you have nice hex drivers already, why not just run a 1/4 to 3/8 adapter. That is what I run on my carbon bike. I have the teeny gearwrench beam inch lb torque wrench (made in the USA also, bonus) and just run my drivers with the adapter.
Fugio
There's just something about a brazed bike.
You guys are making miss my old Kleins!
hautpot
California
I use this adapter.
I disagree with the opinion that the neck down is inferior to the straight hex. But you should own both regardless.
rice rocket
Doh, I missed the part about the torque wrench.
You should still get the Betas, but maybe some Snap-On sockets to match. ;)
MrPretty
TX
I've got a set of Blue T11s laced to A23s too, its been a great set of wheels.
I would have to 2nd the PB Swiss bits, I've been using their bits and sockets for a while now. One thing that is nice about their sockets (or the style of the snap on ones posted above) is that since they are a bit longer they can give you some extra clearance.
An Example: when adjusting the stem bolts on a TT bar setup it can give you some space from the elbow pad/extension bars, which are usually mounted on the main (base) bar.
I'm hearing good things about White Industries stuff.
I've got a pair of White Industries Tracker hubset (from the 90s I believe) and they are still working great. I've replaced the bearings a couple of times but otherwise I don't have anything bad to say about them.
rice rocket
I had the WI ENO hub back in the day when fixies were cool. Now, I'm just like any other roadie, with carbon just about everywhere possible.
shockwave
Marietta,ga
Sunex makes a really nice kit with a wide variety for about 20-30 bucks
But for precision look at the single piece 1/4 from vim (called half cut too)
I have a blue point set that has about 40 pieces 2-10mm,1/8-3/8 hex p1,p2 slotted 5/16 and 3/8 t8-t50 torx and 4-10 xzn (triple square)
