I think it was like $17 plus $10 shipping from toolpan.Looks pretty nice! What did it set you back and where'd you source it from?
....Just be careful though, mine munches through batteries at a surprising rate.....
What do you mean that the SO ratcheting screwdrivers are "converted" with different shanks? I am very interested in this.
but I would suggest ordering it elsewhere.
Seller isnt big on communication
Yes they are converted to use the Snap-On soft Grip Interchangeable shanks. Is is an easy process. Remove the selector knob via snap ring in notch. Cut retaining washer and remove. There are a couple of thoughts on the reassembly. some people reuse the original cut retaining washer. Some people use a gm a\c seal 52477087. I work at a gm dealership in parts so I have easy access to this part. I have figured out that I need to reduce the OD of the washer by a few thousandths to get it to fit in the recess in the selector knob. I will be doing this weekend to see if it really is any better than just reusing the cut retaining washer. Reassembly is a little trickier but have found that a small pair of hemostats are perfect for holding the retaining snap ring while seating the selector knob in place. Now you can use the interchangeable Snap-On Soft Grip Ratcheting Screwdriver shanks. The shanks have a detent ball versus the original that dont. The a/c washer should help hold the shank as well. You can also insert a long 1/4 drive extention and attach your shank to it. I will try to post a thread with pics this weekend.What do you mean that the SO ratcheting screwdrivers are "converted" with different shanks? I am very interested in this.
After a month, this finally came in. My new spark plug socket
So I got this off of eBay for $26 shipped
Specific use for a socket that size?
Everything was Taiwan (even the singles), which was a nice bonus. Should also have the free Streamlight Nano coming from them some time down the line. Gearwrench 1/4" (120XP) and 3/8" (84T) sets, with fillers for the 3/8" drive sizes. My socket trays will be happyEverything was Taiwan (even the singles), which was a nice bonus.
Cyber Monday order came in from JB Tools, also picked up a couple discounted things from Home Depot.
Gearwrench 1/4" (120XP) and 3/8" (84T) sets, with fillers for the 3/8" drive sizes. My socket trays will be happyEverything was Taiwan (even the singles), which was a nice bonus. Should also have the free Streamlight Nano coming from them some time down the line.
The husky palm ratchet set I got for the 3/8" ratchet and 3/8" sq to 1/4" Hex adapter. The ratchet is the same as the one in the GW 1/4" set, just with a 3/8" drive. Figured it was worth it for $6. Phone holder was in impulse buy as it was clearance for under $2.
I was unable to find any manufacturer which still makes hacksaws in the USA... so I bought a used one. I was looking for one which could make flush cuts and this one turned out to be a good choice. My guess is that this one is from the 60s-70s and though it has surely seen much use, it still functions well
I believe that style hacksaw was produced by several manufacturers ove rhte years. The one I have is a Craftsman and I bought it at Sears about 40 years ago.
The large top tube can hold a couple of extra blades. remove the screw on cap to access.
Wow that slot chisel looks so good. Like something out of an industrial design portfolio. Where'd you get it? I am not finding anywhere to buy one when I search.
I wasn't sure which style is the old and new, but I definitely like the large printed "Wiha" version better. It looks nicer, and the sizes are easier to see at a glance, especially with the sizes also on the handle ends (assuming they don't wear off easily).It looks like the newer "large WIHA" version has the sizes printed on the handle ends.
Is that a vacuum handle for carrying glass panes?
Yeah, there aren't too many uses for those things. Yours looks a little different from what I am used to seeing though. Other than carrying around flat glass panes I have only seen them used for automotive windshield replacement and for removing and installing raised floor tiles in data rooms. Those are usually more simple handles with two suction cups though. I guess if you ever find another one you could always "Mission Impossible" yourself up the side of a glass high rise.
Here's some more detailed shots. I also noticed that while the metric set appears to all match at first, the soft-molded portion of the handles were not installed in the same orientation for every driver, causing the sizes to sit in different directions. [emoji53]
Both sets together:
- snip -
Metric:
- snip -
SAE:
- snip -
I haven't had a chance to use them yet, but so far I am very disappointed. This is something I would be bothered by on a cheap, low-quality set from China, and not something I would ever expect from a well-known German manufacturer that is known for quality tools. I plan to contact Zoro this weekend to see what they can do for me.
Sent from my XT1575 using Tapatalk
Did you exchange the tools should they both be green and not 1 orange and 1 green.![]()
