KMScott
When I replace the rear pins in a Wilton I am going to do it this way from now on so it will be easier to tear apart and a much better setup. After clamping the vise up to a angle plate I had to find the hole center line then and run a 5/16:18 tap through the Static portion. The 1/4 inch pin hole is the size of a 5/16:18 thread. On this C1 vise I rotated the nut 90 degrees because the 1/4 inch hole was all washed out, I had to drill and ream the new 1/4 inch hole. The wood shown in the picture was a wedge to press the nut and cap tight before locating the new hole.
