Blue Frog
Might want to be careful with that depending on what you typically do. Those were designed for tool room use, final fitting, aka careful use by machinists. With the over hung jaws and thin towers it's not one that you want to clamp a caliper hanger in and go to town.
Thanks for the advice, but I don't use a vise as most of you do - I'm a woodworker, so any work that I do is considered light duty by most in this forum.
Blue
I'd back the screw out with a very good fitting screwdriver (may need to do some grinding), clean off all the threads and then thread it in further. If it seems too stuck as is, a little heat from a propane torch or even heat gun to soften the paint would help.
