Jim Diesel
Yeah i agree that boot does look nice. Ill speak with my local rep and get a price for the Australian market.
I think I might have a problem...
Only if you don't use them.I think I might have a problem...
My tool expansion has been growing thanks to the garage journal lol
I bought the 2754-20 3/8 impact fuel based on all the recommendation here on this thread.
I had done the last wheel rotation my self and used a torque wrench, 80lbs all around a few months ago. Decided to rotate my tires on my Acura now, so perfect time to test out the 2754-20, first 4 lug nuts came out after a few second of just the impact struggling, the 5th lug nut is a one of those lock security nuts that comes from Acura. 2754 couldn't loosen it...what a let down, super disappointed in the hype. I had to use a breaker bar on it first then it was able to take it off.
It was able to remove all other 19 lug nuts after this one, including the other 3 lock nuts. I was puzzled as to why it couldn't loosen that one. It was just not strong enough, I guess.
My brotha from another mother decided to get the 2763-20 1/2" and I got to see in action last night. That thing is a beast! And of course why would I own little Timmy (2754) when I can own big Bertha who didn't even sweat at removing a Honda crank bolt. So I did the logical thing...Went and bought big Bertha lol
What happens is at the dealer people like to use a 1/2 air impact on full blast to install the wheel locks on... If the lug nuts are set to proper torque they should have no problems busting the lug nuts free
My favorite tool by far is the 3/8 impact. I use it all the time.
The portaband sits in my swag stand full time (I have an old corded portaband that is used for down and dirty work)
I just ordered a boot for my gen 2 impact drill today so I'm hoping I start using it more without worrying about messing it up.
You have to realize any reducer of any kind will lower the torque
Yeah I've had problems with those stupid lock socket adapters because they don't even fit tight in the socket they are designed for so you lose a lot of your hit. I use the 3/8" M12 FUEL for lug nuts very often and they will blast them off, except for lock lugnuts.
That one lug could have been tighter then the rest.
Get the boots for those impacts they are worth the $$$
My M12 3/8" impact will take lug nuts off if they're torque properly.. M18 one should do it fine if they aren't over torqued. I don't remember it ever not taking them off for me.
Of course the 2763 will either loosen them or break the stud in half, lol.. if you've got room to use it then it's hard to beat the power of that thing
I used it to pull a crank bolt off on an LS2 engine a while back.. the torque on those things makes a Honda crank bolt look like nothing. Took it right out though!
Got another box for my new 7-1/4" circular saw.
I just used my 2654 (granted, previous gen) to tear down a '92 Dodge D60 front. It did everything I asked of it, including all lug nuts and even using my Tiger Tool to press out the shaft u-joints. I did not try it on the spindle nuts however. This was on a compact 2.0 battery too.
But then I once had a single lug nut on a 1/2 ton Dodge (read: smaller thread than 3/4 ton, ie 1/2-20) that was a little seized or buggered up and it wouldn't remove that one.
Overall though my 2654 is a ninja: compact, agile and does almost everything.
What holds the band saw onto those SWAG tables? How does it mount?
After admiring your post 3 times I just realized how you mounted chargers inside the tool box lid, very creative![]()
Actually Milwaukee markets the boxes as specifically having charger mounting. No offense to whoever did it, but it's not really creative as much as just using the product as advertised.
Then below the charger I mounted a piece of Velcro with another screw so I can keep the cord from flopping around.
Anyone know the model number on the Mikwaukee M18 and M12 car charger? Have seen them before but can't seem to find them anywhere now.
How much of an angle was the u joint at and how long was the extension?Because the 2763 is so big, I had to use an extension and a U-joint which I know sap a lot of the impact but...
