Not sure where to begin as I am feeling quite overwhelmed at the moment.
I have a 60 gallon Quincy 3.5 hp compressor not yet installed and that is the genesis of my questions. Please help!!
I have power to the compressor and have fixed the defect which the compressor had new from Quincy - they said bring it to the repair facility which was 50 miles away. Unfortunately, I have already destroyed the pallet it came on and didn't want to reload and haul the compressor, so I said send me the part and I do the repair - and so it was.
Now for the plumbing: I plan to run a car lift, motorcycle lift, PRG540 air riveter, Blue Point air hammer, air ratchet, 1/2' impact, bead blast cabinet, plasma cutter and to air up tires.
I believe all these things will run at 90 PSI, but that has to be confirmed. I will need at least a total of 6 drops in 2 rooms.
After reading lots of Garage Journal I have decided to use either Rapid Air or Pex for my lines and drops, probably 3/4". However, between the compressor and the rest of the plumbing I plan to use either 3/4" black pipe or copper tubing to make a few vertical lengths to cool the air and let moisture drop out.
I'm thinking two 10' vertical lengths of pipe would help to cool the air.
Question:
Is 18' of pipe enough to cool the air coming out of the compressor?
Any input?
