Merkava_4
You guys have any idea?
Kent Moore p/n: J 37088-A
Fuel Line Quick Connect Separator
Those release tools aren't for Merk's buick. Those tools work well on Tahoes and Suburbans where you slide the release tool into the fuel line fitting to depress little steel fingers holding the filter. The Buick pictured above has an external plastic clip.
I'm going to ship my tools to Clovis and fix Merk's car for him..
Yes, they're called fingers. Squeeze together and pull the black part off.![]()
You're kidding right? Is your fuel filter going to be like your axles where we discuss all of the tool and axle possibilities only not to do them?
On the forward side of your filter is a 20mm hex nut that is part of the filter. The hex fitting that scews into it is 16mm. The little white/grey plastic tabs on the aft portion of your filter that go into the fuel line can be easily squeezed with your fingers. However, if you're worried about breaking a nail, you can use this type of plier for extra grip. http://www.thetoolwarehouse.net/p-2896-knipex-3891200.aspx
Ensure that the o rings inside the fuel line don't fall out.
i believe white tab and hose is 2 part. so white tab stays on there. you press white tabs and pull the black hose.
Facom do a set of plier I have them ill check out the part number for you
or equivalent.
Try:
http://www.thetoolwarehouse.net/specials/RedHotDeals.html
then squeeze the white tabs with your fingers and pull the filter loose. It's not rocket science, and should only take you a minute or two.
You're right. Sorry bout that.
I can hear Merk now, my car was fine until you touched it.... My car is making a new noise since you worked on it.... there's are scratches on my lug nuts from you removing them with an impact wrench.....
It usually helps on these to push the line towards the filter at the same time you squeeze the plastic tabs together, then just pull the line off. The plastic clip will stay on the filter. And as other's have said, this is about as easy of a fuel line connection as you'll ever deal with.
+1, the white clip stays on the filter, the new Wix filter will have a new clip with it, if needed. Look at the line Merk, you can see where the white clip sits in the line cutouts, comes of easy, no need to do anything with the "pin".
LOL, I thought of that too, hey Merk. it is easy, like tearing the bra and ******* off a drunk striper...............a little pull here, a twist there, and before you know it, you get your nuts off. LOL
Why are there 5 million different line tools on the market for then?![]()
the air hack cuts the tube of the fuel filter
then using a standard release tool and needle nose - pull the tube out
