boosteddsm92
How I fill my tractor and other outdoor power equipment.
If you can find some of the older pre-garbage NATO cans go that route. Still can be found at some military surplus stores.
The gaskets for the "donkey ****" spout are hard to come by, but you can make then by cutting it out of a gasket sheet
So far I found this to be the best of the plastic cans.
I've had to get a few of the HD versions of cans with these
And they are not too bad if you remove the turn / lock collar. They work OK then without spilling fuel.
http://www.amazon.com/dp/B000BQO15I/?tag=atomicindus08-20
Not cheap I guess, but will last a lifetime and doesn't have that **** nozzle.
I know it's an old thread but I wanted to throw in. I would have liked to buy the Eagle cans but since they switched to the plastic handles for opening to pour, I won't buy them. Depending on how you hold the can as you pour, you'll sometimes put a lot of weight on that handle. Combine that with chemical reactions from gasoline and soon you'll have a broken handle and useless can.
I have several of the JustRite cans and I really like them. At first, I thought having all the controls, both fill and dispense, so close was going to be a problem but it really isn't. These cans, even the 5-gallon, are so easy to handle because you can use 2 hands to get them into position to pour and then easily squeeze the dispense handle.
Watch the video on the Amazon site:
Great rack!
I am going to reverse my original opinion and now I prefer Justrite over eagle. I will say that pouring and filling from an eagle is better, the funnel is better. Filling them is a real pain though. They do not open far enough. The Justrite on the other hand opens fully and is much easier to fill. I much prefer the handle/opening mechanism on the Justrite. Neither will leak in your car though.
Just another idea .... I've transitioned from pouring to siphoning fuel into my equipment. Much easier to control & fewer "drips".
