What do you use to clean your box?
Mugen AP1
Toronto
I'm a Hydraulics tech, so obviously my hands are always covered in oil. I'm in and out of my box every 2 minutes. So even if i whipe my hands with a rag, my box (KRL) is also always covered in oil.
My question is: What do you guys use to clean and cut the oil but not dull the finish of your boxes?
Thanks
Chris
06wt
chicago 434 UNION CARPENTER
i use a 20 to 1 purple power to clean and wax it with dupont teflon spray wax. The dupont stuff ***** for use on my truck but its perfect for the tool boxs.
krusty the clown
Member Emeritus
niangua, mo
purple power is an acid based cleaner/degreaser at 20/1 it may be diluted enough but i used mean green (generic simple green) and then wax.
Skyline
Simple green is pretty tough on paint as well; it will definately strip wax. I'm not sure I would want to use that suff on any painted surface.
I've been using WD40, but that does leave a very slight film. But I would think one of those "Quick Detail" sprays would probably be pretty good (I think Mothers' makes one).
I have used Mother's spay wax without prior cleaning, and that works pretty well to clean things up at the same time.
KraftwerkMk1Jetta
Long Valley, NJ
no offense, but do you really need to ask how to clean up your greasy toolbox? Use a degreaser and be done with it already, its a toolbox, not a ferrari.
Mugen AP1
Toronto
It's my Ferrari :thumbup:
And to the rest of you guys, thanks for the input. I was thinking simple green was a good way to go. Or an orange cleaner of some sort. And i'll put that spray wax, that has been collecting dust, to good use. Like you said, it's garbage for automotive paint but it might be good on the box.
Chris
jshillin
PA
Just use a detail spray or waterless wash... Both will work fine unless it's really greasy and then you're going to want to step up to something like Optimum Power clean.
pjcforpres2020
Seriously? Whatevery works... just stay away from harsh stuff like brake fluid and brake cleaner that is meant for stipping rust, brake dust, and all that other jazz.
Personally, I just use some dawn in hot water, give it a good wipe down, then use WD-40 on a rag to reseal and protect it.
Flathead Red
Gulf Coast of Florida
I can't believe it took 7 posts before someone put a joke up about this. I was think that as soon as I read it but didn't want to be a smart a$$ because I am a new guy.
Funny
Flathead Red
stltikn
Colfax, Ca
I think the KRL boxes are powder coated, so the finish is pretty tough. Having said that, don't push the abuse too far. Don't use brake clean or strong acidic or alkaline cleaners. After all, this is a painted surface, use
products for painted surfaces. To remove heavy oil/grease, use a penetrating
oil, kerosene or diesel. Like you would do to remove tree sap/pitch from your vehicle. Follow that with a 50% or less solution of simple green. You want to remove the film of penetrating oil and save the paint. Wax and polish with the same products you use on your vehicle's painted surfaces. This is what I've done and it seems to work well. Stltikn
pjcforpres2020
New or not, jokes are always welcome. :beer:
Yes! More jokes! I thought the same thing, is this serious? And was going to make a wise crack too, but on reflection I decided to give the benefit of the doubt and give some real advice. I think he is just double checking for his personal sanity type thing?
Flathead Red
I have a Cman box pre roller bearings and it covered in stickers. So when i clean mine it is WD-40. One of these days I need to take some pics for the website
Flathead Red
wreckercologist
cyber-tool hell
That's not entirely true. They are now, and in every color. By box is old enough it has a red "E coat" while other colors of the same vintage were powdercoated. I think mine is roughly late 1990's.
Has anyone ever looked in the owners manual or whatever literature comes with the box for a recommendation?:headscrat
bennyy
San Francisco
for those who use wd-40 to clean the toolbox, after cleaning does you cloth or paper towel cover in your toolbox's color ? It happen to me.
nate379
Palmer, AK
Krud Cutter, Purple Power, Paint Thinner, Solvent from the tank, Greased Lighting.... you get the idea. Whatever is handy.
Now Leaving , NJ
only a nerd waxes his toolbox
only a nerd puts the lift down on the locks
only a nerd says good morning to the boss
only a nerd uses seat covers
only a nerd keeps the nametag on his shirt
