Wear safety glassesI use a cordless impact driver everyday.
I'm just thinking if something breaks during the impacting, like the extension or the socket breaks and splinters fly; I might get hurt.
The only protection I have is a pair of gloves.
Does anyone have a bad experience with impact driving ?
Don't wear gloves when working with things that rotate ... you will never get the glove off fast enough, never.
I worked in a shop with a number of different grinders. Every one had a little sign that said, "Don't stop the grinding wheel with your hands, even if you are wearing gloves." Really? They had to put a sign for that?
Not many of you work with heavy stuff, but if you are, and it can fall over, DON'T try to catch it! I work on plastic injection molds, and the individual mold plates can weigh hundreds of pounds. First, we try to secure them so that they can't topple over, but if one does, you train yourself to get out of the way, NOT try to catch it. Steel safety toes get flattened by a 300 lb. plate falling off of a table.
... I was grinding flash off of castings, and the grinder motors where the size of a 5 gal buckets ... or bigger. You could lean on them with your full weight and not even slow them down.Don't hit the wrong nail with a hammer.
Not shilling unless you're going to profit, just good info.OK, enough shilling.![]()
I've got a scar on my left forearm from doing this when I was a kid
Was tearing apart wooden pallets in the basement using the claw of a hammer wedged in the stringers, hitting the head with the head of another hammer. A flaming chip off the corner of the head flew off directly into my arm and proceeded to bore a hole in it about 1/4" deep. Bled like a stuck pig, and you can still see where it was to this day.
to this. I also have a scar on my left forearm from when I worked in construction. A tiny crescent moon shaped piece of steel about 1/8th of an inch long came off the head of one of the hammers and embedded in my forearm halfway between my wrist and elbow. Blood was pouring off my fingertips within 2 seconds. Took a trip to the hospital to get it out. Could have easily hit my eye!Guatama: unless you own a company how can you buy these superior gloves? the video where a guy makes a finger painting using them looks like the ones i would use daily and these cut fingers might not happen again. thanks for posting and feel free to post more safety information as you think of them.
ALL: my original bandages are still on my thumb and getting ready to pull them off and put on a new batch and hopefully the cut is already healing.
cheers and wish me luck because even thought the cut was only about 3/4 of an inch long it was about 1/4 of an inch deep and the cabinet that cut it was over 100 years old so no telling what was my thumb that hopefully bled out.
I believe in using the right tool for the job.
Slow down and avoid being in a hurry to finish a job.
Always de-energize all related power sources when working on equipment, and
then check with voltage tester to make certain that power is off. No matter what!!
If you know you are taking a chance, STOP!!!!! Find a another way.
... From that point on became very aware of the fact that other people do give a **** about you and you had better watch your tail.
Witnessed another, tile saw and no glasses. Yikes. Anyone with an eye injury would probably cringe witnessing that.
I plan on doing this - but want to figure out a way to mount the jack stand on the plywood.A lot of good safety tips in this thread. Over the last couple of decades, I have become fond of staying alive as long as I can and have tried to be better about tool and work safety. I am a heavy DIY'er and for a few years had a pretty busy handyman side business. There are some really good recommendations but the posts about taking the proper amount of time and not rushing are right on the money. It seems whenever I rushed, something went wrong or I hurt myself.
One thing I don't think I've seen in the thread yet is using jack stands safely on asphalt. About fifteen years ago, I saw that the jack stands I was using in the driveway were digging into the asphalt. I worried that if they might dig in unevenly, tilt and fall over causing the car to crash down (maybe on poor old me). So I took some 3/4 plywood and cut it into square sections a few inches larger than the footprint of the jack stands and place them under the jack stands whenever I use them. I suppose that you could also possibly use them on dirt and gravel - though I have not jacked anything up on those surfaces.
I also double up on jack stands now when jacking up my vehicles and also use a pair as backup safety when I put a vehicle on my Rhino ramps.
Never use a non impact flex socket, especially a deep one. That might save you from having to have 4 stitches in your eyeball. While you watch!
Oh yeah. wear safety glasses
