Drives - posting pic from my iphone dont know why pics are sideways -vise is mine -found at an estate sale -im assuming the off set base was an accessory at the time of original purchase -i cant find anything on web about it
NYPD: keep taking and posting pictures as you have time and i'll straighten out this one before i have to run. very interesting vise and i wouldn't let that one get out of your hands anytime soon. NICE FIND
Joe - i own it -have you ever seen old advertisement for this vise -like to get more info ?
I found a wilton bullet vise at my FIL's and I disassembled it but cannot separate the 2 main pieces. I'd done lots of penetrating oil and have hit it as hard as I can with a brass punch and a mallet. It's not budging. Most of the other parts came apart easily with little rust. I am sure I am not missing any pin or something, this should just come apart imo.
Do I heat it, try to press it out (somehow)?
Agreed the vise is a simplex for sure and the extra base would appear to me to be the right shape size and color to be a simplex produced add on but that's just my opinion.NYPD, can't make out the logo on the side of the vise, but the collar puts me in mind of a Simplex or a Charles Parker.---Really nice set-up.---Makes a double swiveling B-----d out of a stationary B-----d.![]()
I bought a lot of 6, 2'' cast balls off EBay a year ago and just a 1/4'' more looked too big and gaudy.
VISE ALERT!
http://indianapolis.craigslist.org/tls/5783466379.html
Looks like a project, but not too far gone. Seller needs to learn his vise terminology. It's actually a Reed 403 1/2R. I'd go after it myself but I don't have the time. I hope a GJer gets it.
That's called making a Ferrari out of a Pinto, Bagged ... NICE WORK!
Sent from my SM-G900P using Tapatalk
Finished this Wilton woodworkers' vise for a customer. Not my favorite restoration but came out pretty good. It was pretty rough cosmetically. The aluminum handle was chewed up so I made a new one out of 7/8 solid aluminum. I also made a press fit pin to hold on the rear piece. Originally, I think these vises came with a cotter pin. The pin was missing so I decided to make a cleaner solution. This vise isn't perfect but my customer wanted a Wilton woodworkers' vise to match his Parker 974 I restored for him.
Is the base bolted to something substantial? If not, I'd try that first (without the swivel base). If not the whole thing is going to move when you try using the mallet and punch, and movement kills any chance of separating the halves.
The next step is to take the collar off the front that secures the main screw, remove the main screw, then use a dowel to pop the dust cover off the back. At that point put the whole thing in a bucket/barrel/etc full of diesel fuel for at least a couple of days and let it soak. There's a really good chance that's all it will take.
If there's a gap between the jaws using a pry bar between the jaws...but don't overdo it....just rock back and forth a little, and use something to protect the jaws like a piece of wood or sheet metal.
There's a vise repair thread worth checking, and posting the problem as well:
http://www.garagejournal.com/forum/showthread.php?t=252830
Thanks Kevin. This was the Parker I finished for him last year.
Question to the Record/similar quick release owners: when not in use, do you keep the QR engaged (can move dynamic) or disengaged (can't move dynamic)? And why do you keep it that way?
Bart, I found a 106R at an estate sale for you!
Imagine my excitement when I saw this in the preview photos of an upcoming distant, but not too far, estate sale.
I'm told what's left of the jaws are about 4.5" but I'd guess it's 4" or less. The left side has also been whacked. It sorta looks like there is some weld built up on that dynamic cut side face, and maybe on the static side. Could be to retain the jaw faces, which might be compromised after this much hacking. Looks like the very deep center notch may have been for some sort of special work holding.
I suppose what's left of the jaws would still be usable as a vise, but it would piss me off quite a bit each time I looked at it. That vise is for someone more forgiving. I'm guessing it will be over-priced - or at least not worth the risk of the drive.
Good point, Dutch ... I am talking about the later, handle activated QRs. If you turn the handle 1/2 turn left it activates the QR and the dynamic remains freely moveable until the handle is turned to the right.The lever type spring back on their own (don't know about the later Record handle only type, never seen one) so the dynamic will normally be locked, it may not lock with out a slight nudge to line everything up.
