I completed a project today. A few years ago we replaced the toilet and sinks in the master bath. The original owners had black fixtures installed and my wife hated them (hard to keep clean). I found a nicer white toilet and matching white sinks at the local Habitat ReStore. I didn't care for the faucets but my wife didn't want me to replace them. I could feel how cheap the valves were -- you can feel the difference between brass and plastic when you open or close them.
I lucked out when my wife mentioned that one of the faucets was dripping and keeping her up at night a few weeks ago. I knew I could purchase new cartridges or washers for the old faucets but I wanted something different and solid. To that end I didn't bring a cartridge with me or even check for a washer repair kit (Home Depot doesn't seem to carry just washers anymore). I showed her the new faucets at Home Depot.
My wife isn't really 'cheap' but anything more expensive than free upsets her. On the other hand, she has good (expensive?) taste and the only faucets she liked were waterfall style. I pointed out that they were hard to care for because a puddle of water always remains in the open tray of the waterfall when you shut them off. I also pointed out that only the ugliest (sorry, least attractive) of the waterfall faucets was less than $250 and we needed two.
My friend Google found a waterfall faucet at Amazon that was 'different' and didn't have an open tray. What it did have was an LED light in the waterfall that changed color with the temperature of the water, from
blue (cold) to
green (warm) and
red (hot). I was having visions of battery replacement issues and wasn't crazy about the feature when I read that the light was powered by a turbine in the pipe. OK, that's cool and I show it to my wife. She loves it and that's when I noticed the price... $46 (now it's $45.99 -- RATS).
https://www.amazon.com/gp/product/B0107P115A/?tag=atomicindus08-20
For $46 I expect another plastic faucet but it says it's brass. Hell, even if it's plastic it will do until a better one goes on sale. At that price I ordered three along with two new pop-up drains (the waterfall faucet doesn't have a drain stopper rod setup).
The old faucet came out with very little drama but because of its design, you have to remove the flat nut on top and drop the valve out the bottom (same as the new faucet).
The faucet came with everything needed for the installation except the supply lines and some plumbers putty. It even came with a roll of Teflon tape that wasn't needed with the style fittings used. A little cleaning of the porcelain and the first piece was ready to go in.
The faucets are indeed all brass and quite heavy. The knobs have a button that screws in the side and when unscrewed, exposes the setscrew that holds the knob tight on the faucet shaft.
With the usual "be patient" voice encouraging me, I managed to get the faucets screwed into the escutcheons on top of the sink (plumbers putty helps a little as well). Tightened the ring nuts from under the sink (more "be patient") and connected the faucets to the spigot through a Tee. Two supply lines and the new drain and it was done.... sort of.
I never do a victory dance after completing a project like this and I only did one faucet. Turned on the water, filled the sink and found no leaks. Tested the LED color change and it worked perfectly. I'm happy and my wife's happy but I am going to wait until after Christmas to do the second faucet.
Put the towels back under the sink and cleaned up for the day. The towels weren't wet until the second day. Took everything back out and checked again for leaks. The Tee was leaking but only when both faucets were wide open. Removed the Tee and noticed a hex opening inside -- found the right allen key in the collection and unscrewed the swivel. The o-ring is cut through! I may have done that but I think the swivel was not tightened carefully at the factory -- it came apart way too easy.
My packrat (hoarder?) mentality meant there were three possibilities. I could 1) open the third box and get the o-ring from the spare faucet, 2) go to a store and find the right o-ring or 3) check the Harbor Freight o-ring box for the right o-ring. Strike out! Wait, don't I have a collection of o-rings from the PT Cruiser A/C repair project? Yeah, right here in the tiny garage parts bin -- one of those green ones...
The second faucet went in today without any issues -- so far.
