I am not soliciting to sell this item, as a mechanic and inventor I am asking for your impressions of this tool.
The AERO DRIVER is A LOCKING TURNAROUND BLADE SCREWDRIVER.
Patent # US 9539719 issued Jan. 10 /2017
The AERO DRIVER combines two of the most used tools in your tool box. A tough flat blade screwdriver and a magnetic bit holder screwdriver allowing you to carry one tool saving time and space.
The AERO DRIVER is designed for the professional mechanic. The blade ball locks into the handle and will only come out when you release it with a slight rotation of the lock ring.
Under the handle end you will find four drive bit storage tubes, each tube holds two drive bits, rotate the selector to the desired tube and empty the needed bits.
The handle incorporates a flat end cap allowing you to set it on its end to load a drive bit when you have only one hand free.
At the moment, there is no commitment from a manufacturer to build the tool.
When it is built, like two of my other patents, the MAGRAIL TL socket rail and STRIDE/MILBAR REVERSIBLE WIRE TWISTER, it will be of professional quality.
Thank you for taking the time to look. Attached are few prototype photos. Also thought you might enjoy a photo of a few Aero Driver accessories for the different trades.
Ron G
Ron G
