Is there any proof that WD 40 is anything else than gasoline mixed with some additives to make people believe that the main ingredient is not gasoline?
Kerosene & light oil....
I like it for cleaning motorcycle chains, hand tools, chainsaws, old/faded plastic, removing sticker residue and light oiling.
Actually I want proof that it is not fairy dust mixed with unicorn farts.
Where did you come up with this? If you want proof that it is gasoline buy a few gallon cans, wait till your gas gauge is on empty then throw them in your daily driver and see what happens.![]()
WD-40 will not prevent rust.
Sure it will. Why wouldn't it?
I use it on tools - all of the time, where the chrome has chipped off, or they are exposed steel.
Use it on shovels, Picks etc.
If i use it, no problem. If I don't, they will quickly start developing surface rust.
its NOT a lubricant it is a water displacer....if you want a lube use oil based product
Believe it or not I read some people use it for their joints. Supposedly assists in joint pain. But I believe the messaging it in is actually is what helps.
I read somewhere that the bulk of wd40 is fish oil. So that may be why it makes good fish bait.
