If you took one of my prototype couplers and suspended it from the ceiling and attached a 200 Kilogram weight to the plug then the coupling would fail.I've watched your videos, and am familiar with the intended function.
What I'm talking about is unintended tension on the hose. There is some amount of force which will cause any coupler, including yours, to either disconnect or mechanically fail. The question is whether or not that amount of force is low enough that someone could realistically cause it to happen by some strange confluence of events.
Personally, I wouldn't want to be selling couplers unless I knew that number.
Not trying to **** on your design- by all accounts it appears to function very well. It just occurred to me as something that, if I were in your shoes, I would want to know; and also something that you appear to not have considered testing.
I don't need to test it because I know the yield stress will be exceeded.
Chances are, I won't be producing this design anyway as it would probably be too expensive to sell.
